Isuzu Trooper Brake Problems
                    Hi All,
My ABS light flashes intermittently when I am driving. I have replaced brake pads and rotors on all four wheels and I still have this problem.
Dose anyone know how to get the Diagnostic codes for the ABS on a 1995 Isuzu Trooper 3.2L 4x4? I have tried to use the jumper on the DCL(3 Wire Connector)but that gives me the diagnostic codes with the CHECK ENGINE light flashing, not the ABS Light. I think one of the other plugs is specifically for the ABS diagnostics but I am not sure which one. I don't want to start putting jumpers here and there and possibly causing another problem. If anyone knows how I can jumper the ALDL connector to read the ABS errors I would be forever thankful. Here is a picture to let you see what I am looking at http://jjoker.250free.com/1995TrooperALDL_DLC.JPG
JJ
JJ
http://www.carspace.com/atfdmike/.59a54262!v=
http://www.carspace.com/atfdmike/.59a54263!v=
I only find a 16 pin connector left side (not OBD2), I don't have diagnostic hardware. Can I do it only sending to ground the connector?
my rear anti-lock brake light is on and my brake light is on...and to top that off my rear wheels are locked...i have a 1994 Isuzu trooper 4x4... Can anyone help me to figure out why this happen and how to fix it
thanks much
There is a diagnostic link for the brakes located behind the left kick panel. If the ABS light is on, a code is probably stored.
The light illuminates also when the Parking brake is on ..checked that? or the brake fluid level is low. Once those are checked, and if abs light is on, then code should be set. the rear wheel anti lock system is different from the 4wal, so more info is needed to be more specific.
JJ
my rear anti brake light is on and my brake light.
my back wheel is locked like it is dragging
i checked the fluid and that is all good.
i have a automatic trans..
i just bought this trooper 3 days ago and dont know much about it yet
this all happened when i changed the tail light and had my daughter hold down the brake pedal to see it the light worked.that is when i seen the lights in the dash were on and then i checked my brakes by driving backwards and then forwards and noticed it was locked and dragging
With IGN OFF, connect #1 terminal with #3 terminal (GND). Then turn IGN ON.
Keep #1 terminal connected with #3 terminal (GND) during DTC display. (If #1 terminal is separated from #3 terminal (GND) during display, display will stop.)
How To Erase Code: Connect and disconnect jumper wire between #1 terminal and #3 terminal (GND) at least 3 times within 30 seconds.
There is no time limit to "opening", but "each grounding" must be more than 1 second and the entire 3-grounding sequence must be completed within 30 seconds.
I would have to wonder if the caliper itself is locked, and causing the combination valve to signal uneven brake pressures to the ecbm.
You could try a hard application of the brakes while moving forward and then backwards to see if the caliper unfreezes, but that is unlikely and not a fix, as it will likely just lock up again if that is where the problem lies. You should inspect brake tubes and hoses for pinch or kink, and then check the abs connector as described in this thread. If you get a code other than 12, post again and I will try to find it. Good luck
JJ
The abs light and brake light are on. I am not getting any codes. I'll pull the wheels tonight when I get home. I was hoping you had some info.
I'm new to forum and in need of tech help for a friend. We are working on a street rod that has been placed over an Isuzu frame and running gear. At this time we are working on the rear drum brakes. I have all of the hardware and shoes removed.
Could someone assist to identify what the year, make and model might possibly be when ordering parts at the local supply. The drums are six bolt. The emergency brake activator is the spring loaded cable and stop passing through the bottom of the backing plate. Self adjuster located above the center line on the upper portion of the shoes. Drum max diameter 10.059. Shoe width 2.0 inches.
A vin number that may be from the original vehicle's records indicate from the tenth position, letter "R", as a 1994 but what model? Are there any stampings or casting numbers that we should locate? Is there a limited amount of models and years to narrow the search? Is there a vin number location on the frame to confirm what the model may be?
Thanks in advance! Mike...
I have a 99 Isuzu Trooper. The right and left rear brake lights stopped working at the same time. The center brake light on the rear door still works. I would appreciate any suggestions on what the problem may be and what I can do to fix it.
Just curious if you were ever able to find out what was the problem. I have been reading that there is a ABS relay that could be bad?
Fluff5 :confuse:
It's a 3.1 Diesel and i think it's a 92 late model
Has any one solved a similar problem please?
I have a 3.1 diesel
The 3-wire DLC wire jumper for diagnostics only gives the emmision diagnostics associated with the Check Engine Light, not for the ABS.
Has anyone ever retreived an ABS fault code from a 1995? If so, how?
thanks, Matt
Currently my rear brake caliper has busted parts and I need to replace it. However I can not find the proper place to order or part number for such a caliper.
I'm not sure if a U.S. part will work, and since it's a grey import, (grey = imported bypassing the dealerships so may not be up to spec for this country), I'm not sure if I need the Japanese or the Australian part.
Either way I can't get a straight answer on these brake calipers... I need two new ones and have no idea what to get.
If anyone can help me, please contact me, I'm stuck in the middle of nowhere without the ability to stop, which is important to my wife. I know.. she's picky (-;
VIN UBSSSFK-7104227
MD UBSIVF BB/JA
ENGINE RLF TRANS RMN
BODY TYpe v4v
Matt
Matt
