Toyota Tacoma Engine Questions
Occasionally when trying to start the engine there is no response. After 2 or 3 tries it will start. I have a new battery and have checked the "valet" switch on the factory alarm. All lights come on like normal but no turnover. Please help. Thanks John
need anymore info, feel free to email me. I've done major research for the 05+ tacomas, and I keep looking around all the time for anything new in the market.
I think it is 5 or 5.5 but want to know for sure.
I have a 2000 Tacoma that repeatedly does not start when it is hot. I never know when it's going to be. As a result of this frustration, I had the alternator, battery and starter checked. They said everything is fine, yet yesterday it would not turn over twice in one day. Once it cools down, it starts. Please help with any suggestions.
Thank You,
Jane
Heck, if it was just displacement, my 5.9L Cummins diesel shouldn't need 13 quarts when the 6.1L Hemi uses about half as much (7 quarts).
They said they had to "remove excessive dirt and carbon from the throttle body". They said it seems to have fixed it, but if the engine light comes on again - they will have to "replace throttle actuator control unit for $1,335". And that I should be using high octane gas.
That doesn't sound right to me. Am I being unnecessarily suspicious?
Has anyone experienced this issue?
if i put it on the head gasket, would that be a bad thing? would it not withstand the pressure over time?
Jack
thank you for the replys
