Toyota Tacoma Climate Control
How do you access the A/C condensation drip pan in a 1998 Toyota Tacoma pickup?
kcram - Pickups Host
thanks,
I feel like a true blonde!
howlingwolf1
Can someone tell me where to look for a solution?????
trkrdeb'04 :confuse:
I am getting water in my duct work, both when it rains and when I use the AC. And I am not talking about a drip here. If I hang a left I hear water sloshing all behind the console and it drips and soaks into the passenger side rug.
And if i hang a right, at times, no less than a gallon of water will pour onto my feet. Its at the point now where I pull my feet back every time I make a turn. And i am constantly in a small puddle.
Any help? I talked to a guy who used to be a mechanic and he said that I should have a drain in the ducts that is probably blocked.
But I don't know the first thing about where to look and any help would be appreciated.
If the blockage is really bad, it may be from leaves, dirt, etc. that have gotten inside the unit and ductwork. That would mean disassembly of the whole unit. It's a big job, but not impossible and it's way better than driving around with your feet in a bath tub.
