I am thinking of buying Mazda3 4-door s-grand touring in about a month. I was thinking about getting the Bose premium sound option. But is it really worth it? I know that Bose is the best but I personally don't have any experience with neither Bose nor mazda. Would it just be better to have it installed at an audio shop? Any other suggestion are welcome.
Only about one in 2,000,000,000,000 audiophiles would agree with that statement. Seriously. That said, I have the Bose system in my MS3 GT, but only because: 1. I didn't have any choice in the matter; to get Xenons and the OBC I had to take the Bose, and 2. I don't intend to keep the sled any longer than 1-2 years at the most. I'd say bring an iPod and/or some favorite CDs to your dealer and audition both systems. Only you can decide if the Bose "upgrade" is worth the extra money.
ash!
Best regards,
Shipo
anything else i should know about my car? anything interesting?
ash!
When listening to the stereo everything seems normal until the volume is turned past 34 or so. When it's turned up everything distorts! One click of the volume and it disappears. The HU does have an automatic volume adjustment that increases the volume when higher speeds are reached but the distortion happens with or without this feature being turned on.
I have tried to search this problem and came across the same issue on crutchfield's website. The ground was checked, and the LOC was changed to make sure that was not the issue. I am lost.
I thought maybe it was the HU itself and it should be changed out by the dealership but I know what they are going to say "it has something to do with the aftermarket products added".......bull. My girlfriend seems quite sure this was a problem prior to the factory speakers being touched but I can't recall. Any help.....PLEASE.
Plus, does the Mazda solution show song information on the display?
I do appreciate your help here.
Naturally I need to add the following disclaimer:
-- "I've yet to do this myself so everything I've written is hearsay."
I'm wondering if anyone out there has or has used the Mazda ipod adapter. Can you completely control the ipod remotely using the stereo controls on the dash, like select playlists, podcasts, etc? I'm assuming it charges ipods? I find the aux-in connector cheesy. One of the speakers always seems to have a flaky connection when I use it, and I'd prefer to keep the ipod and all cables hidden in the glove box or similar.
If you have one, what do you think of it?
Wish Mazda would just throw in a USB port like Hyundai.
I miss the days when you could rip out the stock stereo for an aftermarket model that had the features you want.
Anybody have any advice on Fix vs. Replace ? I'm guessing Replace the whole audio/entertainment unit will be the answer. I assume I can find a replacement in the junkyard market for 150 or $200, then I need an installer.
One more question: I think I'd prefer the 2007 model if it's compatible, because I believe it has the iPod input hole ? Can anyone confirm 2007 has the iPod input, and confirm 2006/2007 compatibility? Thanks.
