Pontiac Vibe - MPG-Real World Numbers
With the price of gas being what it is, your real world mileage is becoming more important than the estimates on the sticker. This is the place to talk about your real world on the road results!
On long trips, at extended highway speeds of between 65 and 70mph, I have registered as high as 40.2mpg. I am very pleased with the Vibe's gas mileage!
I am choosing between these three cars, and am quite confused. I am told by both the pontiac and toyota dealer that the 2006 vibe was built by TOYOTA. However, when I look at the crash ratings posted in Edmunds, they show different crash ratings.
I am quoted 36 city and 38 highway by both the dealers and my girlfriend who has the automatic transmission 2005 with 6 cd player. Any light on the fuzz? :confuse:
Anyone else compare the 3 and know more? How about others actual mileage on the 2006 vs. 2007?
As to real world mpg, I have a 2006 base Vibe with auto transmission (the way probably 95+% of 2007 models will be equipped). I have never gotten less than 25 mpg around town. At 65-75 mph on the highway I get in the low 30s, but I have only taken a handful of 2-3 hours trips, nothing longer.
the ratings on the 06 on the lot is 28 and 33.
I'm disappointed to hear 25..
However, it is built in the US at a plant in California that also builds Corollas and Tacoma pickups. It's twin, the Matrix, is built in Canada.
I'm not sure why the crash ratings would differ, but it may have to due with whether one test sample had side airbags or not. You might want to check on that. Obviously, cars with with side airbags do better in the crash tests.
As for mileage - I can almost GUARANTEE you will get above 30mpg in both city and highway driving, unless something is out of whack with your vehicle. The Vibe has the best gas mileage of any "GM" vehicle. I've never done worse than about 33-35mpg (I have a stick shift) in all my driving situations.
(2) The thermostat may be stuck open or partially open, not allowing the engine to fully warm up to normal operating temperature. The computer has the injectors shooting in more gasoline than normal because it detects the engine as being "cold".
FWIW, my vibe returns 28 MPG summer and 26 MPG winter. It is AWD AT and the EPA sticker reads 26/31. For winter, I use Semperit Ice Grip tires. As far as city/hwy mix, I'd say it's 70/30.
Also make sure the temp gauge is reading very close to the middle: a thermostat that opens to soon will kill your gas mileage AND wear out your piston rings AND let gas get into the oil which will kill the rest of the engine.
This is the base Vibe, automatic.
Replace the caliper and rotor and pads. A wraped rotor or a sticking caliper will cause a pulsating sound when the brakes are applied. A sticking caliper can cause the rotor to get red hot, which may be the cause of the smell. If it doesn't smell when you drive two blocks to the store but smells when you are driving on the highway then a sticking caliper is likely the culprit. IMHO you also need to find a new mechanic.
Question: I've noticed that when I initially go in reverse (rolling backwards out of driveway)--as I shift into 1st there's a single clunk sound that I hear from the back. That's it--just one clunk. I will bring this up at 5000 mile check-up--but any thoughts from anyone.
I've been thrilled with the car so far. I had the alignment done at 1500 and the pulling to the left is pretty much over--thanks to those of you who said to take care of it immediately. I did.
Also, has anyone installed an MP3 jack into the stereo system? I'd rather have that then a plug in but I'm not sure it's do-able or worth it...
Good luck!
Although things seem to have changed a little recently, not too long ago one would expect their compression to rise through the first 10,000 miles of operation. oil use may be high initially. i purchased a new truck in 1988 that burned a quart of oil in the first 500 miles, but pretty quickly settled into normal useage. if you have been driving the vehicle mildly (low rpms, low throttle, proper warmup) you would expect break-in to take a little longer, and in the end, your engine would be better for it.
I am aware that many now beive to break in hard (VERY HARD), and this doesnt cause the problems you would expect because nowadays there is an initial break-in at the factory. i am happy to report that mild break-ins have kept the engines in my 05 GTO, 99 Yamaha R-1, and the 7.4 litre in my yukon quiet and trouble-free.
on the other hand, 30.7 is pretty good, so i wouldnt expect it to get much better.
enjoy your car- my big-blocks are keeping me off the road!!!
Re-set the trip meter after each fill-up. Fill the gas tank up to the very top each time.
Divide the miles driven (from the trip meter before you re-set it) by the gallons shown on the gas tank.
MPG = miles driven / # of gallons used.
At 70 mph, my new '08 Vibe w/manual transmission runs at less than 3000 rpm, guessing 2800 rpm. I'll check 60 mph and post back.
I averaged 35.85 mpg first time I calculated gas mileage. It was all highway driving, no more than 70 mph.
At 60 mph, my 1.8L manual Vibe turns at about 2300 - 2400 rpm.
