Hyundai Tucson Audio Radio MP3 iPod CD Stereo
Got a problem with your amp or want to upgrade the CD changer? Ask questions here and post your suggestions.
Correct, better not to be at the dealer at all...if you find the vehicle that fulfills this PLEASE let me know and I will abandon Hyundai in a hearbeat but you know, and I know there ain't no such animal. But,if like any mechanical thing it breaks it IS better getting it fixed for free AND many Hyundai owners do not have to endure "three" tries for a fix, which by the way is FREE!!
Finally, although Tucson sales may be down, I haven't independently confirmed this, it is most likely due to a trend that all SUV manufacturers are experiencing..high fuel prices..lower SUV sales... this is as plain as the, well, LCD readout on the gas pump..
My only problem is that I now have a CD stuck in there. When you press eject, you hear some motions in there but the cd do not come out....
Time to go to the dealer....
I have just bought a 2006 tucson gls v6 and so far love it, i will be replacing the factory radio with my clarion radio due to i have sirius satellite radio, and has music catcher with prerecorded songs, and is far away much better than stock radios, it puts out twice the power that stocks do sound quality is much better too, well i will post a message when it gets done.
I just bought my '06 Tucson a few weeks ago. It's been great so far. My only complaint is the stereo, which goes to a deep, bone-shaking hum/static when I pass under a bridge, under a gas station canopy, or at a car wash.
I've never run into this problem before, so I'm not sure if this is "normal" for the Tucson or not. At first I thought it might be because the external antenna was missing (was taken while it was on the lot). However, they've since replaced that and the problem persists.
Does anyone have any ideas?
Are there any viable options for improving this ?
Beth (a car dunce) :mad:
XCarLink MP3
Anyone else have any other ideas or have you used this company?
Anyway. Once things get sorted out will be getting an SE, 4WD. It has the cassette player. Anyone using the old fashioned cassette player adaptor for iPods? Are you satisfied w/sound? Does the Hyundai's stereo accept it easily?
Only paid $20.00 for two on Woot.com so not worried about it. Will use when I travel to Layton NJ for crafts camp.
Also, in relation to another question, I bought a Jensen cassette adapter for my ipop that inserts into the Tucson cassette player. Works fine. Sound is good. The trick is to turn your ipod sound up fairly high, and keep radio dial low, which eliminates any potential hissing sound.
I am new to HF and I am glad to finally find a place where I can get advice on my car. I have a 2007 Tucson (V6 automatic transmission). It runs perfectly and I enjoy it very much. However after I took it in for service in June (exactly a year after buying it), I noticed that my CD player is not functioning well. It skips a lot and also is not able to move to the next track and appears to be stuck on the end of the track and keeps repeating like an old record used to do when the needle got stuck. I thought it could be that it is dirty so I bought a good CD player cleaning disc system, but it had no effect. I have read the manual and all it says about CD player problems is to remove the fuse and replace it which will reset it. I have tried that and it did not work.
I am quite frustrated and I wonder if anybody has experienced this problem. I would very much appreciate any guidelines as to how to fix this and also wonder if I am entitled to warranty on the CD player if I have to contact Hyundai or the dealership for a solution or a replacement.
It doesn't do it all the time but sometimes when we are just driving down the road we'll hear this wearing sound or low pitched whining sound from the front end. Not like the grinding sound from worn pads or the tweet tweet from the "low pad" springs (if these vehicles have them).
It may be associated with the pads because if you touch the brake peddle the sound stops; take your foot off the brake and it comes back. We pulled the front wheels from both vehicles and the brake pads are fine.
Also, if we swerve left and right the sound stops while the wheels are turned but returns when they are straight. Really, you can drive down the road rocking the vehicle left and right and as the wheels pass through straight ahead the sound happens then disappears when the wheels are off straight ahead.
Any ideas?
Pete
However, today the radio/MP3/CD/XM stoppped working totally. When you press the power button, a clicking noise is heard in each speaker in a sequential pattern then it repeats itself.
This is a standard equipment radio. From what I hear, many auto companies merely buy their radios from well known radio manufacturers.
When I called the dealer today the service appointment taker stated that this radio is actually made by Hyundai which I'm sure is not true. Apparently there are other radio failures in the Hyundai Tuscon and the dealer will be replacing mine under warranty.
Internet research reveals that Hyundai buys their radios in bulk from companies like Clarion and pays them $50-60 per radio and buys them 100,000 units at a time.
This is probably true since I've never had a radio that has failed when the vehicle is only one month old.
Anyone out there with a similar issue?
I could not find any reason for this to happen. Is there anyone experiencing the same issue? Is there any fix?
I just purchased a 2007 Hyundai Tucson and everytime I go and play a CD "Error 5" appears on the display and the CD pops out without playing. Do you have any fixes for this as it is very frustrating.
Not exactly your problem, but variations of the fuse reboot idea can be found in the How to Remove a Stuck CD guide.
I just purchased the 2011 Tucson .... have not even picked it up yet. I was reading a blog that several people said the blue tooth does not work ...... I have an I phone 3G(rogers customer).....any comments.
Loaded up a 32GB flash drive with approx 5000 songs and let-er rip.
Heck with the radio, XM, CD's, or even iPod, this is the way to go IMHO.
The USB port on vehicles is getting to be more common but most of the other small SUV's we looked at with their dated design didn't have this feature. This was a must for me when I'm spending this kind of money on a new vehicle.
Did I mention I just luv this vehicle? :-)
