Visitor Agreement.
Pete
Rafael
Most folks have combined the two wiring breaks with a single dpdt switch (you can tap the parking brake signal via the pink wire - pin 64 - on the same DVD harness).
You said by cutting the VSS......
will also cause the Nav to lose its location and will require either a slowdown, full stop, or possibly a power down (engine off) to re-find itself once VSS is re-enabled, depending on how far you've driven with it off.
So If another toggle is added to bypass or trick the VSS, I would have to do one of the actions above in order for the NAV to reset itself. That sounds pretty scary and may be a problem. So, my new question is this ...... How long of a slow down, stop or power down is required? Is it really worth it? I would really like to have the DVD option but at what cost?
I don't normally use it for DVD's, but for menu uses, so I have not had extensive experience. If you're driving around town with DVD on, you'll probably find that stop/go driving allows the nav to keep reasonably close.
Net/Net It really is convenient to have.
Pete
One other issue; unrelated. I keep getting chips in the plastic(?) front air dam and the touch up paint won't stick. How do u guys repair these paint chips and dings?
OOOPS, I forgot this is the nav forum now, never mind...
On another point, however: You CAN actually watch a DVD on the Nav screen when the car is parked, and without the Nav Fix. Just make sure the parking break is engaged.
Pete
In my case, especially with no VR for Canadian destinations, it just might be that I'd like my wife to find a nearby restaurant or alter a destination or look up a phone number while I'm driving. Sorry if that offends anyone as terrible behavior, but I don't equate it with engrossing cell phone conversations, let alone movie watching.
It's not the same thing if the passenger is doing whatever, you are correct, of course, and no one would argue that with you.
How 'bout we all just move on at this point ...
Some give you reminders when the name of the road splits. I remember coming down route 7 from Danbury ct to Norwalk ct and being told to continue straight about 10 times in my Acura TL.
No way to fix this....navigation is trying to help you.
Pete
On my M35 Nav System it appears that circles show up on busy roads ...this appears to vary with the amount of traffic on the road but I'm not entirely sure. Does anyone know what these circles are and how the system actually gets the data if indeed the circles are an indicator of how much traffic is on the road.
TC
It's a convenient feature that lets you retrace your path if you're exploring and just want to get back to where you were. I also find it useful for quickly seeing how close I am to my next turn on my frequently traveled routes, without having to bother to enter any destination. It's just there, ready and waiting.
You can turn it off or on again by going to:
Settings > Navigation > Address_book > Stored_tracking > Current Route
Here's a more advanced use for this feature:
You can save your current tracking and do that several times, to save multiple sets of Stored Tracking data. You can rename each of them, and have them permanently displayed on your map (or turn them on and off).
Imagine that you very frequently go to a certain tricky route, that you know how to get to the beginning of it but can't remember how to do the whole thing, and assume you only go to that area for that one destination. If you save that tracking when you get there, then rename it and display it on your map, you can follow those circles whenever you go there without even having to bring up a destination. They'll always be there on the map when you get to that vicinity.
Pete
A very useful feature.
TonyC
The 2007 G35 seems to have a significantly upgraded nav-system. It is hard-drive base, and includes traffic monitoring and voice-recognition control of the navigation, radio, and climate systems. It also tells you which precise lane to be in for freeway navigation.
Is the navigation system in the 2007 G35 more advanced (and have more features) then the system on the 2007 M35/M45?
Below is a description of the 2007 G35 nav system from someone's review: "The Navigation Package consists of a GPS-based system employing a 30GB hard disc drive (which displaces the in-dash, six-CD changer to the trunk and contains a 9.5GB partition for user-recorded audio tracks); MP3-capable compact flash media slot (also used to copy audio to the HDD and update the map database); lane guidance, which preps a driver for a left or right exit ramp from a freeway; voice recognition for climate control, audio and navigation; and a three-month trial subscription to Sirius or XM satellite radio, the latter including real-time traffic information where available."
Pete
What if you had inputed final destination in M, and you wanted to find rest stop, gas stop etc. en route using voice activation? Would you be able to do it????????????
I have found several addresses where data and directions are not available due to incomplete data. Hopefully there is a way to report this so that it may be corrected in future versions.
I understand that it is the individual municipality who turned in the bad information in the first place, but it sure will be nice when there is a painless way to report errors.
p.s., he let me go with a warning, even though I hadn't done anything wrong!!!!
I contacted Zenrin USA, Inc. (the company that produces Navi software for Infiniti) and they confirm that although Hawaii map data is available, they have no plans to include them in Infiniti's DVD.
If I understand the Zenrin web site correctly, it does indicate that Honolulu, HI is covered in Nissan's MCA 10 (an upgrade CD) with detailed coverage of Honolulu. Will this CD work in the M's DVD system? :confuse:
Navigation systems in Audi, Acura, BMW, Mercedes, Porsche, etc all come with Hawaii maps so it seems Infiniti alone is not aware that Hawaii is part of the US. Does anyone know if any other brand of data DVD will work in the M? Can anyone suggest another solution?
Many thanks for any help with this problem.
Aloha,
Richard Wells
Yah, you have a good point. Local residents always have a laugh when our freeways are labeled "H1 Interstate or H2 Interstate". They are so named via Federal Requirements and the drive to California is not only long but very damp.
Aloha............RW
Greetings from AZ .... 108 today.
Bart :shades:
Germany is about 10 years behind Japan in this department.
