Toyota Tundra Shocks and Suspension
mongrelkoi
Member Posts: 1
in Toyota
Needed some help with rear squat. I have a 2005 TRD 4wd StepSide V8 - Titanium Silver Ext Cab. We just upgraded our boat to a 5500 pound beast and the tongue weight is a little too heavy for me. Causes too much squat.
So I have been looking for some air shocks, in order to beef up the rear tongue capacities a little, but I have run into a brick wall. I need some air shocks or heftier springs or something.
The GCWR and everything is met OK and the truck pulls just fine. We have pulled the boat ~400 miles since we got it and have had no problems.
Any advice would be appreciated.
I would think it is wheel bearings, but I get no shake from the disc with the tire off. I am at a loss. I took it back to the mechanic in S.C. who did the work, and he told me he found out that the front tires should be lower in pressure than the stated pressure from the tire manufacturer. He was giving me the slip because he knew I was leaving to head back to Canada. Told me that it would 'wear out' after a couple hundred miles. I knew better, but didn't have time for an exhibition.
Please let me know if anyone else has experienced this.
Oh, it is a 2000 4X4/V8-SR5.
As long as the freeway is new, or decent asphalt, ride quality is good, but at typical freeway speeds, it is verging on unacceptable on old concrete.
Put a load in those suckers and the ride will smooth out.
Bob
jc
