Ford Explorer Engine and Diagnostics Problems
I have an Innova OBDII Diagnostics Code Reader. Have used it successfully on several cars including a 1999 Expedition, 2002 F-250, 2001 Mustang, Toyotas, VWs, Lexus, etc.
When I tried it on my 2004 Explorer, it did not work. Talking to Innova, they explained that by 2008 all car manufacturers had to upgrade their diagnostics to the "CAN" diagnostics and that my Explorer had already updated to this standard.
This appears to be the case, but does anyone know if there are other alternatives, as the CAN software is expesive; i.e., $500+.
Any info is appreciated.
not ready to give you my opinion, yet.
But aside from that, the system that controls your 98 is OBD II, and the 93 is OBD I. You'd have to take a number of sensors off your 98 to use them on the 93, and hope there weren't any changes so that everything mates up.
Here's the kicker...In many states, it isn't legal to put an older engine in a newer vehicle. But if you do it yourself, who's going to know.
My guess is, on a scale of 1 to 10, the swap should run at a 6 or less.
In the case of the V6 in my Explorer, is it wise to change the belt now? Is the engine an interference engine? What is the risk if the belt/pulley breaks?
Thanks a lot for the info guys!!!
Get a new car now!
I am looking into Hyundai. Can't beat the warranty and the models are great.
Run to you nearest dealer and trade in now before you have my problem.
The mechanic said a seal in the engine block failed, allowing coolant to flood the engine which caused major engine damage.
The dealer gave me a quote of $4800 to replace the engine. Ford has refused to take any responsibility for this issue and has basically told me it's not their problem.
I am extremely frustrated and angry with this company. This truck has very low mileage and this should never happen. I've changed the oil every 3000 miles since buying it new in Nov 2001.
A $34000 truck is now basically worthless and Ford doesn't care.
I would advise everyone to avoid Ford for two reasons: their product stinks and the company does not care about you or their customer service reputation!
I will be tearing into the electrical system over the weekend, I highly suspect it is electrical because (1) I've had an odd intermittent thing going on with the 4WD and windows not working; and (2) I heard a buzzing/shorting-out sound coming from under the dash, next to the steering wheel, last week. It is likely the windows and the starting issue are 2 different things.
But I appreciate your mentioning that your dealer replaced a relay and your Explorer was good for a few months. That confirms my suspicion that this is very likely electrical and not mechanical. If I can figure out which relay(s) it is, I will post detailed information including replacement part numbers once I have it fixed.
Bailey
Have you received any answers to this issue? Overall, my SUV has run very well since I purchased it in 2000. But fixing this problem has been very tricky.
thank you for any help you can give
it's not a major problem... shouldn't damage anything.
OBD II has no power to it (pin 16)
Did anyone find out what was wrong and how to repair it?
Tkx
bcooper88@cox.net
I would start it up fine, take it down the road and after about a min or so of driving it wouldnt go anymore. You could press the gas and rev it up all you wanted, but it wouldnt go anywhere. My dad and i really wouldnt like to buy a new/used transmission, and would love to know if anyone has any ideas about our problem.
fyi, we checked the transmission fluid and it was actually above what was needed.
THANK YOU
Ed :sick:
problem of car feels like it is missing at speeds between 35-40 mph. Mechanic says he found on internet that problem is in the torque converter not catching up in the
transmission. Says nothing can be done except replacing transmission! I would like to know if this is right or should I just live with it.
Hugh
