Waning enthuiast
I have not found out much regarding the throttle or transmission lag. I will post results after my service appointment.
2001 X5, 4.4, 83,000 miles
Put new battery 2 weeks ago when the old one was dead one morning. 3 days ago the new one was dead.
Mechanic checked says all fuses ok nothing wrong with battery but something is draining it. :sick:
So I have been observing when I turn the car off the blower (to the floor of the interior)comes on (no matter what I do with the vent/radio/monitor) and runs for a while so I timed it tonight it ran for 30 minutes (only after a 15 minutes drive from cold!! Very odd). :confuse:
One suspicion I have is could the Oxygen sensor need a replacement? I dont think it has been changed since I bought this car brand new, have 83,000 miles on it.
Please note that I dont have the Aux vent programmed to vent the car when off, also I do not push the "Rest" Button to direct engine heat into the interior when car off.
OOPs forgot to mention that Sunday night battery dies after two false Car alarms, does the alarm come on when battery gets low to prevent theft by dsconnection?
Anyway it was off for only 3 hours when it died.
So last night I disconnected the battery what a pain and reconnected it this morning and it started ok. Tonight after blower would not go off I pulled the fuse #64 and it stopped it, hopefull yI dont need a jump tomorrow to go to dealer, any ideas?
Thanks in advance.
Sorry if the previous message #362 does not make sense, this site removed my initial message cuase it had my email (I did not know was wrong) but they left my reply..continuation to that post #362 so now it reads funny?
For future reference everyone, the warning about posting e-mail addresses is there under the "Post Your Message" label.
thanks!
shifty the host
On another matter, can anyone recomend a snow tire for this vehicle. I have 255/50r19 michelin Diamaris oem tires in the front and 285/45r19 in the back. I'm driving up to canada this winter & I need to find something. Thanks
Did they solved your problem? And if so what was the solution?
I'm getting @#% tired of all this crap from bmw...I should have bought a lexus instead ...they are 10 times more durable than bmw and the resale value and warranty is much better than bmw.
randomly on 4 separate occasions! 3 times on the freeway in heavy rain. it scared the
heck out of us. twice my wife escaped a crash by a hair. she is now to afraid to drive
our "luxus safety vehicle" in the rain. only after the engine is turned off and back on it works again! we live in the pac. north-west!!
are there other X5 owners with the same problem out there?
The wiper system works like this; you turn on the stalk it sends info to the "ZKE" and it controls the relay, in turns controls the wipers speed. Hope this help
What is the fix. I have been to 4 dealers and each time it cost about $1,000. with no fix.
The dealer has given me back the car several different times over the past nine months only to have the temp gauge go the red and the service engine light comes on. I explained to the dealer this inconvenience was unacceptable. My friends joke around that I have a permanent BMW loaner. I did not want the vehicle back until they proved the X5 was repaired. The dealer called to tell me after exhausting all efforts for the past nine months they want to return my unfixed car to me and get their loaner back. I was told only seven X5's in the country have this problem. BMW determined the problem was in the Software DME component. BMW would work out a repair sometime in the future. I obviously do not want a car back that is not repaired. I have not been able to get BMW nor the dealer to work out a fair resolution to the problem. I have a little reservation going with a new X5 however I don't believe BMW has made me feel good about this SAV. The dealer told me they would consider a trade-in however my vehicle has lost value since it is unlikely they will resell the X5 but rather wholesale it out. Why is that my fault? Can anyone out there tell me if you have had a similiar experience and what the resolution was? Does BMW care about keeping me in the BMW family or not?
Still waiting, after a month, for the sun roof replacement. Water continued to leak causing my passenger side floor to become exremely wet causing mold.
Love driving my X5, but now that I have to wait 2-3 days to get the window replaced, I'll be looking for another SUV as I can see more problems a coming.
I posted a message #389 a while back about my check engine light coming on on my 2001 X5 one week after purchase. Princeton BMW said it was gas pedal and replaced my gas pedal. The light came on again 1 day after I picked it up. They then said it was fuel bank 1 and 2 and that I need to replace the harness.
You gave me some helpful suggestions. Since then I have been driving with the check engine light on. Last Friday, my transmission light came on. I took it to the dealer for a diagnostic test and they checked the DME for faults and found codes for mass airflow sensor, camshaft position sensor and crankcase vent control. Repairs are $1,250. They said the reason the check engine light first came on was because one of the above things failed, and now all three of them has failed which triggered the transmission light.
Are these repairs necessary? Do you think that's what the problems are? I feel so helpless because I do not know whether these are major problems or small problesm that could lead to major problesm.
Thanks, if possible can you please get back to me asap, I am supposed to take the car for repairs today at 10:00 a.m.
I have an appt to take it to Princeton BMW this Wed. They are the ones who initially changed the gas pedal, they won't charge me again for diagnostic. The funny thing is I was going to have someone else other than the dealer who diagnosed the airflow sensor, crankcase valve and camshaft sensor last week so I took it to a place specializing in foreign car repairs, he opens the hood and low and behold my mass airflow sensor was unplugged. Yes, unplugged. Apparently Essex BMW left the darn thing unplugged and they could not give me an answer why. Do you see why I'm mistrustful?
This mechanic said he scanned OBD2 system and found no input signal to ECM from several sensors such as MAF and Cam position and others. I don't know what all that means. Can you explain.
The next day, they scanned it again and the code PO102 Mass or Volume Air flow circuit low input.
PLEASE HELP ME UNDERSTAND ALL THIS JARGON. I am still trying to get the codes from Essex BMW.
I'll email you as well to make sure you get this. Thanks a bunch.
Were you ever able to find out why the transmission indicator light was on, I'm sorta having the same problem on a 01 X5.
Did you have any serious problems as a result or did you find out what was wrong?
I took the car to the dealer again today. Now they are saying I need to replace the wire harness. They also said there may be a problem with the mass airflow sensor and possibly camshaft. They want to fix the wire harness first and then see about the rest. I am trying to get them to do the mass airflow sensor first and then see but they are reluctant to do that. What do you think I should do. Remember the other dealer said it was mass airflow sensor, camshaft and crankcase control valve.
Another service place and Auto Zone only came up with the code P0102/Mass or Volume Air flow circuit low input.
Now these people come up with the wire harness. This is the same place who said there was something wrong with the wire harness back in my first post and you told me not to let them replace it. Should I go ahead now and have them replace?
Please respond, I am desperate.
The reason the dealer got a OBD code for no input to ECM was because the MAF was not connected. After reconnecting it the codes should be reset. And hopefully they will not return.
IF you have anymore trouble, rerun a OBD test and let me know what you got.
Feel free send me a email if you have any more questions
I would talk to them and ask them, if they got a reading from the mass air meter, and asked them "lets just try it, make me happy" (with a new MAF)but heck they can always say they did try it and it was not the problem, so they will still push for the harness, Asked them what they think is wrong with the harness, is it a cut wire, damaged pin? dig alittle ,if its either one of those it can be fixed ,they should be able to fix either one of those issues.
If you do get them to change parts for you, always ask for the old ones.(put a small scratch on it so u can tell if they really changed it)and to make sure the parts they gave u as old, really came off your car and not the scrap bin
Ask them why they think its the harness and not something else?
Have they ohnm checked the wires from point a to b for the problem, if so, ask them what connector and pin numbers. then email it to me.
Ask, if you change the harness and it does not fix it you'll have not to pay?
ASking questions to probe never hurt, especially if you gotta fork over alot of $$$$
I believe it's a 6 cyc, 3.0, no it's not under extended warranty because I can't seem to find a reputable off market warranty company. I pushed them to try the MAF but they claim it had nothing to do with the harness (2nd time they came up with problem with harness). They did not try the MAF, actually the 1s time in august they quote me 976, last week they quote me almost 2 grand for the harness, when I ask about the difference in price, they came up with some b.s., then said they would charge me the 976 (Scammers).
The problem is now the transmission light being on and the car actually jerks and shudders when I go to stop, what should I expect as it relates to this problem? They are probably going to come up with some astronomical repair to the transmission etc.? Any ideas, I am sure they will contact me tomorrow with bad news. Is it possible the camshaft is the problem? What about the shifter selector?
Thanks for your help and I will ask them for the old parts.
Kraig N.
With your tail lights do they go off and stay off for awhile or what?
With the windows is it all the windows or some and which ones?
IF you have a vacuum leak try this, with the engine running take a spray bottle of rubbing alchol and spray on the hose, if you have a leak on the air intake side you will hear the rev up some.
For you lean running you may also have a bad O2 sensor
For the dealership telling you need a new harness don't buy into it.
And from the sound of it I would try to find another dealership sounds like these guys are clueless and dont care
Email me with this info put in the subject heading BMW X5, I'm working 12 to 16 hr days so it maybe a few days before I can get back to you
Trickle chargers? Just plug 'em in. Read the instructions. Most are designed so that they cannot overcharge a battery---they'll just shut themselves off.
You should not accept the excuse that a car's battery goes dead in 5 days, if in fact that's what they are telling you.
Something is wrong there.
Mlock
