Dodge Avenger Gas Mileage Reports
Share your actual MPG with other Avenger owners.
Need help getting around? [email protected] - or send a private message by clicking on my name.
Dodge Avenger
But no way a R/T 3.5 gets 20.5 city driving.
Best I get is 16 and lucky if 25 highway?
Yes I have AWD which is 1 mile difference non AWD.
You can not go by car computer as it's not accurate!
Only way to know is old fashion way divide miles by gals. @ fill ups.
I beg to differ with Barry626...my R\T even with 100% city driving still gets 22.5...thats has nothing to do with the computer..i figure it manually with miles driven\gallons at fill up. Heck my R\T doesnt even have the mileage computer!
Maybe its the way you drive barry??? I don't hot rod all the time in the city but i am a very aggresive driver. Barry...how many miles does your R\T have?? Also do you use Midgrade (89 octane)as the book recommends for the 3.5??? It made a small difference in mine but not enough to compensate for a 6 MPG difference.
OH YEAH...check your air filter FREQUENTLY... the cold air intake on my R\T craps up really quickly (but I drive 1400 miles a week). I change mine at least once a month (6000 or so miles). I figure they cost 5 or 6 bucks and it DOES affect my gas mileage. It not only affects the gas mileage (drops 3 or 4 MPG when its stopped up) but also the amount of acceleration I get out of it. Make sure your engine can breathe!!
For those of you think its rediculous to change your air filter every month...At the rate I drive...3 or 4 miles to the gallon less over a month would equal around a gas usage increase of around 25 gallons....
270 miles\27 MPG = 10 Gallons used per day
270 miles\24 MPG = 11.25 Gallons used per day
1.25 gallon per day difference times 20 work days a month (Average) = 25 gallons x 3 bucks a gallon = $75!!
so spend 5 bucks a month on an air filter or $75 bucks more in gas?? Heck if I got 16 MPG it would make a difference of $400 a month in gas!!!!
Check ur tire pressure!! I also run synthetic oil....I think that can all effect your gas mileage. A little off here and there could make up for the 6 MPG difference!
Now, I commute 270 miles a day...my mileage has not varied from 26.5 to 27...every tank. That is roughly 230 miles highway and 40 miles in city. Not bad for the power and "fun" factor of the Avenger with the 3.5. Heck most the time I prolly average 80 to 85 on my way to work...so i bet I could get better gas mileage if i back off the gas?
Its kinda been a contest to see how much gas I can save but can ya blame me? I am single handedly keeping the gas station open in my small town...LOL...Just kidding.
AWD makes big difference in gas mileage.
The new cars are getting horrible mileage.
I only have 3,000 miles & I don't hot rod it @ all.
You have a great tip to use 89 octane, believe I'm using 87?
I also will keep in mind about the air filter, Thanks for the tips!
Mine is a 2008...rolled off the line January 17th, 2008.
Also i saw a big difference is gas milage at about the 5,000 mile mark...well not big but a couple of miles per gallon.
My last fill up I used 5.9 gals & went 108 miles. Wow 18 MPG?
Guess u are right & most likely will get better @ 5000 miles?
Question: I asked my dealer about synthetic oil & they use Mobil One.
They charge $64.95 & suggest changing oil every 7500 miles.
When I had my BMW's they used synthetic oil which was good for 15000 miles.
Any thoughts?
I have noticed now that winter is here and I don't run with the cruise on that staying around 70-75 mph my milage dropped to 19.8 and I don't think that it's because I idle it for 15 minutes twice a day before hitting the road, it's probably my foot trying to stay at 75 going up and down the hills. The temps have also been in the low teens which with my other vehicles has always improved performance, but I haven't seen any change. Although I am very impressed with the Avengers ability to start in the 0-20 degree temps. I have a block heater but refuse to use it unless I start to see a problem.
I do not need a concensus to report facts.
If I tell you a rooster dips snuff you can check under his wing for the can!
Soonerb
MPG is between 18-22 city so far. I only have 500 miles on the car.
jlo7
Seats are comfortable.Lots of room including a very large trunk. Car is fairly quiet with very little wind noise even at highway speeds. It has a smooth ride and handles very well with excellent brakes.
The dashboard controls are easy to use and are contrasted nice for easy viewing in the daytime as well as at night,.
The only thing I would like see changed is the indicator lights for the A/C, recirculating and rear defroster switches. These are hard to see and not bright enough during the daytime and while wearing sunglasses. They need to placed higher and made with a blue glow indicator rather than yellow.
The heat and A/C work great. The A/C gets ice cold even on a 90 degree day.
I have to say, so far its the best Chrysler product I have had.
Reviewers are split on the styling of the 2010 Dodge Avenger, but most agree it stands out from the crowd of usually bland mid-size sedans. Cars.com says "the Avenger's design is its greatest appeal," while reviewers at Edmunds point out that the external differences are few between the SXT and the R/T. All three versions feature styling similar to the Dodge Charger, leading Car and Driver reviewers to christen the Avenger the "Chargerette" and note its "Charger-like stance." MotherProof reviewers also love this 2010 Dodge, claiming that "the Avenger makes a statement. It isn't dippy; it's sharp and aggressive." However, on the negative side, Autoblog comments that the "rear quarter panel is an utter mess of shapes," while Car and Driver feels that it "fails to be either menacing or inviting."
:shades:
The best MPG I have achieved so far is 36.8 mpg! This is 100% highway driving doing 65 miles per hour.
From what I have heard, the 2011 Avenger will be better yet!
When I initially got in the vehicle, it was dusk, and the interior dash lights weren't illuminated. I reached down to turn up the brightness, in the area where every other vehicle has the dimmer switch. Nope, that's not it - good thing I didn't mess with it while driving. The dimmer is on the turn signal... Ok, good to know, but really not the greatest design.
I like the visibility, and like the way the vehicle drives. It's also very comfortable for me.
MODERATOR /ADMINISTRATOR
Need help navigating? [email protected] - or send a private message by clicking on my name.
Share your vehicle reviews
It has been very reliable. .An air pressure sensor in one tire going bad has been the only issue..
People who have ridden in my car have complimented me on the smooth ride and quietness. BTW, I have the 4 cylinder engine.
I can recommend this car. It is the best one yet.
My old 2010 Avenger used to get 22 city and 37.6 highway @ 65 mph.
Both cars have 18.5 gallon tanks, and 4 cylinder. Even in cold weather like we are getting now, I still got 20 mpg city.
Any thoughts?
I recently read elsewhere that some cars are having issues with dragging brakes with 4 wheel disc with abs and traction control.
I plan to take it back to the dealer to check that out.
Thnx Caaz
BTW, The 2010 that I had was 100% trouble free from the 1st day I had it. I bought it new.
This car has a 6-speed Auto trans. I use to get better mpg with a 2010 Avenger I had.
Anyone have similar or better experience?
