What car company has the best AWD system
Exactly what the title asks^ Also retains to Subaru AWD system and Audi AWD system.
Acura has the best AWD system bar none. Next topic !
Rocky
I would think owners of Porsche, Mercedes, Audi and BMW AWD cars would argue that point.
Subaru has at least two different systems:
(1) A viscous coupling system used on manual models; it's reactive, but is 50-50 when not locking up.
(2) Clutch packs on automatic models; it's pro-active, but is 90-10 divide on most models when no wheel is about to slip.
Audi has used at least three different systems:
(1) The models in the early years involved manual engaging locking . . . not recommended;
(2) Torsen system with mechanically pro-active response, but heavy with the complex worm gear etc..
(3) Haldex system on some if not all models in the last few years . . . lighter but robustness is yet to be long-term observed.
But Subarus don't get traction/stability control to go with their AWD unless you are spending a gazillion dollars.
NOW, in the gazillion dollar range, we have lots of good systems, although I still prefer the Audi Torsen, which again can be set up to run the wheels 50/50 all the time, or any of a number of other ratios if the manufacturer prefers.
As for trucks, I still prefer the old-school systems, but those are mostly going away in favor of electronics that decide too much stuff for you. The new Land/Range Rover systems really go over the top, with variable mapping for the throttle and suspension settings and all the rest of the mumbo-jumbo. They are nothing more than a ton of very expensive repairs waiting to ruin your day in the near future, and for what? These $50-75,000 trucks are never going anywhere but the mall anyway, and even if they did, they've got what - 35-series tires on $2000 18" alloy rims? I give those about a minute before the first puncture, and probable rim destruction at the same time.
I agree with your whole assessment of 4X4/AWD systems. every new device that is added will be a repair bill. You can expect it to last at least 2 months past the warranty. Then get your wallet out. We had very little trouble with our 4X4 trucks until they added electronic activation of the hi/lo transfer case. And of course ABS is useless with 4 wheel drive. It may be different with continuous AWD. I have never owned one.
ABS is only useless off-road if it doesn't know it is off-road. If the ABS computer has different braking algorithms for different surfaces then it does fine.
For example in sand mode the ABS system actually allows the brakes to lock up for a split second so that sand builds up in front of the tires and you stop sooner.
Rocky
Can you be more specific? Has it been used in racing vehicles and proven? I would have to drive it on glare ice to give an assessment for myself. I don't plan on being anywhere near icy conditions now that I am retired. I did my 37 years on ice and snow.
Rocky
Do you think Acura will give an objective performance rating? Has any of the car mags done a head to head comparison?
Edmunds did a AWD comparo and the SH-AWD won by a landslide pal. How couldn't it ? The system doesn't just send power to the front or rear wheels, it also send torque to the outer wheels that need it most. This uniqueness is what makes it #1 and improves the handling of the vehicle. The RL has a 0.90 g's on the skidpad pal.
Rocky
I'll try to find it on inside line, hold on pal.
Rocky
http://www.edmunds.com/apps/vdpcontainers/do/vdp/articleId=106555/pageNumber=1?s- ynpartner=edmunds&pageurl=www.edmunds.com/reviews/comparison/articles/106555/art- icle.html
http://www.edmunds.com/apps/vdpcontainers/do/vdp/articleId=104808/pageNumber=1?s- ynpartner=edmunds&pageurl=www.edmunds.com/reviews/comparison/articles/104808/art- icle.html#
Rocky
Rocky
Rocky
Rocky
Rocky
And honestly, I don't see much advantage in the Honda system over a simple old-school 50/50 viscous center coupling with a limited-slip on the rear axle. The Honda system might see some small weight savings, I suppose, but considering they are only installing it on vehicles weighing near 4000 pounds or even more, I am not that excited.
Please explain your distinction between reactive and proactive as you are using the terms here. I would have thought the best AWD systems would be reactive in that they can vary the amount of power to certain wheels or axles based upon actual slippage input from the cars computers. Now if there is a "pro-active" system that can tell in advance when I'm going to hit a patch of snow or get my left rear wheel stuch in mud, I want to know about it. Not that I'd buy the vehicle, but I'd get the engineers to rig me up a stock trading computer for the hedge fund I'll start.
P.S. The unfortunate reality with Subaru not getting much credit for anything is that they just don't have an upscale image. My father in law swears by his Subaru Legacy Wagon which he logs 20,000 miles a year in Maine. But it's not a common sight in more affluent areas and doesn't have the demographic support of an Acura, Audi, Mercedes, BMW, etc. to get much press. And they have the aesthetic appeal of a tool belt - which suits my FIL perfectly, but not the neighborhood soccer mom.
(1) I prefer systems that run ALL the wheels ALL the time, because they don't wait for wheels to slip before engaging, which is my definition of reactive. Audi's Torsen-based system, as well as old-school center-VCs, get my vote here.
(2) Beyond that, I have been lead by PR hype to believe that some systems are more proactive than others, including Subaru's VDC. I must confess I do not know all the details of this, which is why I need one of the hard-cores to chime in (I assume default torque splits of 50/50 help, as well as yaw sensor input and the like).
But SH-AWD is proactive in one sense, which I like: when you stop, the computer automatically routes part of the power to the rears until you reach a certain speed, meaning that in hard launches you will have all four wheels trying to get traction. Now unfortunately, the power split in those conditions is like 80/20 I believe, so you don't have MUCH of the power going to the rears, but it reduces the amount of time the system needs to react when the fronts begin to slip. Several magazines testing the RL when it came out stated they could slip the front wheels a lot more than they liked before the vehicle would find traction.
You hit the nail on the head, Nippon.
Rocky
But the truth lies somewhere in between. Honda has had various evolutions of the SH-AWD system going all the way back to the Preludes of the late 90s, where it was a special trim that almost no-one bought. And at the time the press said the same thing they still say - you can't detect the difference on the street, and while you can feel it working on the track, it is only good for a gain of fractions of a second, not worth the extra expense most of the time.
And I dunno about you, but I never took my brand new Acura to the track...do you routinely go to the track?
Bottom line: this is an AWD discussion, not a Honda discussion, so I will just say that I think SH-AWD gives Honda the bare minimum it needs in order to avoid having to pony up for a larger RWD platform for its luxury cars, but in the world of AWD it is just one of many systems that are just as capable.
edit...BTW, I went and looked at Subaru's own technical explanation of VDC, and I will give you that one. Theirs is merely a brake-based traction- and stability-control system with a center diff. While this will accomplish the same thing as SH-AWD, I have always felt that systems that sent power to the wheels with traction by braking the wheels on the opposite side of the car were rather inelegant (and in fact, I have often wondered if this wouldn't lead to substantially reduced brake life if one were an aggressive driver). So I will give that one to SH-AWD, but I still prefer Audi's Torsen-based system to both.
I see GM has a so-called "intelligent AWD system" on the GMC Acadia I'd like to learn more about that. I wonder if its a smart track knock-off from the olds bravada, or its the same system used on the Cadillac STS ? The STS employs a F-40/60-R system and that isn't intelligent. I also confidently believe that its a Torsen system also ? IMHO that is old school and even infiniti, and subaru, have better systems than that. I'm not sure how good the 4-matic system is from Mercedes, or BMW's AWD system really is. However based on my limited knowledge on the subject I'm yet to find a more advanced system then Acura's SH-AWD. If you can find me one that's technically better I'm all ears.
Rocky
The thing I never understood is that the Legend and Vigor and the first-gen RL (and maybe the first TL) were set up like a normal longitudinal RWD-based AWD system, except that they were missing the main driveshaft and rear pumpkin. The transmission had a parallel shaft inside the case to drive the front wheels. Honda could have made them true AWD anytime it wanted.
So he calls me on his cel phone and after I laugh for several minutes (he hates that), I drove out to the beach in my Land Rover LR3, wrapped a tow strap around his chassis (had to dig down almost two feet to get there), and pulled him out pronto...
The LR3 wasn't even breathing hard.
I have been calling him "Sandy" ever since...(He hates that too)
I believe that settles the arguement...
Keith :shades:
I have had to tow friends off the beach before in my 4Runner...it always makes for a good story to tell later on. :-)
AWD on cars seems relatively new for Ford...wondering how the execution went... :confuse:
In which case, I say, ehhhh. A decent to so-so AWD system suitable for driving around wet and perhaps snowy but plowed roads.
Wanna know who will have the greatest AWD system man has ever seen ? That is none other than Mitsubishi.
Mitsubishi, has delivered a AWD system that is so advanced I can't even believe it. Hell it might just be the most advanced drive train in the world. It is called
Super All Wheel Control (S-AWC) The 08' EVO-X will be among the best handling cars in the world. The car also has a improved Active Yaw Control (AYC) and an all-new four-wheel independent active-braking system.
Well here's a good run down from edmunds on how this system really works.
A hotter platform for hotter shoes
Just to recap the basics here, the current model's incredible grip comes from its Super AWC system that combines electronically controlled all-wheel drive, Active Stability Control, AYC and an Active Center Differential (ACD) that distributes torque between the front and rear wheels. The ACD works in conjunction with the AYC, which splits torque optimally between the rear wheels, thus enhancing grip and steering response.
With the Evo X, Mitsubishi has further optimized response time of the AYC unit and fitted a new active-braking system that automatically takes over when the AYC/ACD's grip levels have been compromised, supplying braking force independently to all four wheels and restricting slide and sideways movement.
At the track, this clever marriage of stronger AYC and independent four-wheel braking combined superbly to deliver just the right amounts of power and steering response, leading us to quicker times through the slippery slalom course. The car's rear end was more composed as it tucked in, cleanly following the line traced by the front wheels. The amount of steering input required was reduced as well, turning in sharper and more precisely than any Evo before it. The system does not and cannot, however, totally restrict slides. Sure, the tail will go when provoked, but the new braking system will engage only when you've exhausted the S-AWC's ability to maintain four-wheel grip.
Freaky-good control
If you want to throw the car around, you can, and the feel of the steering is as natural and progressive as the current models. But when you want to bring the car back into line, the task is made that much easier by the revisions. And what of those revisions? Sawase says he's not finished yet. His team wants to further fine-tune the new S-AWC by incorporating steering and suspension upgrades that all work in unison with the central AWD-AYC-ACD-brake package. This will propel the Evo X in the fall of 2007 to the next dimension in cornering potential, a dimension that, well, doesn't exist yet.
Rocky
P.S.
So I might not be necessary wrong now but by next year I'd be wrong if I ignored Mitsubishi's new AWD technology.
But I think you may have gone too far towards the accronym addicted side of technology, with your call on the Misubishi. S-AWC? ASC? AYC? ACD? Did I leave any out? I hope these systems don't ever require repairs. Joe Mechanic may replace a Y where a C was needed or vice-versa.
Bottom line for all of these systems is - let's see how they really work in the cars that people really want to buy. My biggest gripes about the Acura SH-AWD in the RL is that, in spite of great technology, the RL is not "super handling". Give me a 530i sport anyday. And the Audi system, while the cat's meow for some, is in cars that are so heavy they fell like you've taken a water buffalo out on a date (when you are driving alone).
Mitsubishi has an added problem for me. They don't make a car I would remotely want to drive or buy. Or many others that can afford an Acura, Audi, Mercedes or BMW. So they could have the best system in the world in the EVO, but the likely response will either be "What's that? or "Who cares?".
It's really hard for me as you know to admit when I'm wrong or to be convinced I'm wrong. I guess I'm very hard headed and some of you probably think thats a understatement.
So habitat, you don't like the EVO-X styling ?
Did you watch the S-AWC hardware in the Lancer test mule ?
They said there was a huge handling improvement over the last generation.
Rocky
Seeing is believing. Watch an Audi go up against any SUV or other AWD system as long as the ride height is not a factor.
http://globecareers.workopolis.com/servlet/Content/fasttrack/20070308/WHWINTER08- ?section=Engineering
Top of the article you will notice Ted Klaus, Honda/Acura chief engineer for research is involved with this article and this is what he says.
"Every system has its advantages and disadvantages, depending on their intended use. Klaus, for instance, says xDrive is flat-out the best on dry race tracks and Quattro is the king if pure traction is what you want."
As for Mitsu's AWD technology... Subi has Vehicle Dynamics Control (VDC), Variable Torque Distribution (VTD) and Traction Control System (TCS). Pretty much same as Mitsu's yet this has been out for years.
General Subi's AWD system overview.
http://www.ertlecars.com/subaru/allwheeldrive.php
The new Mitsu S-AWC is by a large margin the most advanced AWD system in the world.
Rocky
Serious buyers only for the new EVO-and Mitsu is going to find a lot of buyers for this new car toy racer.
http://www.youtube.com/watch?v=Q7dVFY5CxT0
I'd bet after watching this there's going to be a whole lot of discussion.
Enjoy....
Bubaa
