Ford Ranger Transmission Questions
12357
  • jawtinjawtin Member Posts: 2
    I'm shopping around for a used ranger, 2000-04. In a couple of them, when you're coming to a stop and it's down shifting, it is a little clunky. What is this? I found a nice one today, '00 with 54k, but it also has this clunky down shifting right before you come to a stop. Is this a bad thing?
  • pat93pat93 Member Posts: 1
    I have a 95 Ranger that shifts into gear without a problem but won't move. Any ideas?
  • 93teal93teal Member Posts: 1
    just got a 93" 4x4 5spd and it shifts but when I let out the clutch it dies?????? :confuse: Droped the drive shaft to tow it home.
  • cwac1959cwac1959 Member Posts: 1
    I HAVE AN 09 FORD RANGER WITH A 5 SPEED TRANSMISSION. IT HAS 32000 KM ON IT @ 20,000 MI. I'M ON MY 3RD SLAVE CYLINDER. I'M WONDERING IF THERE IS A PROBLEM IN THE CLUTCH AND TRANSMISSION.THIS SLAVE CYLINDER HAS 2000 KM ON IT AND I'M ALREADY GETTING THE WHESING SOUND TELLING ME I HAVE TO TAKE IT BACK IN TO HAVE IT CHECKED.
  • cruse1cruse1 Member Posts: 1
    I have a 1994 Ford Ranger. It has a V6 automatic transmission. (3.0).
    Can I replace the transmission with one out of a 1996?
    Try to find a salvage that has a nice guy at the counter. They have books that show all kind of exchange info.
    In general, I would guess the tranny would match.
  • brian1974brian1974 Member Posts: 2
    I have a 94 4x4 with a 3.0 engine and automatic trans. The trans will not shift into 3RD gear until I let off the throttle and alow the rpms to drop and then step back into the gas. Somtimes I have to feather the throttle little to make it shift. Any ideas ?
    First thing I would check would be the vacumn modulator on the transmission and the line going to it. Bad modulator or leak in the line.
    If your tranny fluid is going down, the modulator is gone - leak in the diaphram and fliud is being pulled into the intake and burned.
  • bemad1234bemad1234 Member Posts: 1
    I HAVE A FORD RANGER 2000 AND IT WILL GO INTO DRIVE BUT IT WANT GO IN REVERS WHY?
    Thanks for the suggestion, but I may have an internal problem in the trans.
    modulator is new and the lines are ok.
  • lenny15lenny15 Member Posts: 1
    i have a 2000 ford ranger 4 cil. 2 rwd, i replaced the abs vehicle speed sensor, i have problem with shifting , fluid level ok, replaced screen every 15000 mi.
    Yes, there really isn't much that can be do-it-yourself repair on an auto, or even the manual, transmissions. If the fluid level is ok, the modulator on automatics is ok - if there are problems, it's probably going to take a visit to a shop.
  • drygulchdrygulch Member Posts: 1
    I have a problem with shifting first to second. Sometimes at low rpm it shifts really hard and late. Also when cruising then i step on it to pass,it down shifts to nothing and winds out bad like no gear there. Also the overdrive light starts flashing. Is this gears or electronic?
  • willfire67willfire67 Member Posts: 1
    86 Ranger, 4x4, 2.9L, manual trans. While driving one day heard a loud pop and truck stopped moving. Will go into any gear just fine as well as shifting into 4x4, truck just sits there like it's in Neutral. Someone said it may have been the transfer case belt or chain??? Not sure about that one. Can anybody help me narrow this down? Thank You.
  • chadlo87chadlo87 Member Posts: 1
    my transmission had something wrong with it about a year ago but too broke to fix it at that time but drove it anyway.......i would have to drop it into 2nd then into drive for the trany to engage........i drove it like that for a year and last couple of days it would go into drive the normal way i was doin but it would engage when i would rev the motor to the rev limiter and after 3 sec of hitting the rev limiter the tranny would kick into drive but the other day it wouldnt do anything besides reverse.........please help me get an idea of whats goin on thanks
  • vicavica Member Posts: 3
    Before you start tearing apart the transmission take it to a dealer and have them do a check on your computer.....I had the same truck in a shop for 8 months tryin to figure out the transmission problem and it was the computer the whole time....I got a used one at a junk yard for $50 and it was fine. But only the dealer can run the right kind of computer test.
  • blakefblakef Member Posts: 1
    I have an 85 ford ranger 4x4 and i need to change the clutch slave cylinder in it but its not the original transmission is what ive been told so i need somebody to tell me what models came with the slave cylinder on the outside of the tranny instead of the inside.. thanks
  • kjcowboykjcowboy Member Posts: 1
    93 ford ranger 4x4 4.0 5 spd. - I was driving along and heard a "Poof' sound and vehichle jerked and then, kept going as if it were fine. A couple of miles down the road, it quit pulling and a little smoke came up through the shifter in the floor. I pulled over, the motor ran fine but tranny wouldn't go in gear. The shifter worked, but wouldn't go anywhere. Had to be towed. Help please!!
  • outdoorsladyoutdoorslady Member Posts: 1
    HEY friends, I am looking for a car for my 17 year old son, and found a sweet looking ford ranger truck.....am wondering if you like yours did you drive it forever....is there a certain point when you should get rid of them as they become expensive to maintain? he would not be a heavy driver......just looking for good or bad feeedback. thanks in advance. :)
  • cfowleroncfowleron Member Posts: 14
    Hey there;
    I bought myself a 1999 Ford Ranger XLT (2 wheel, 6cyl, A/C, pwr windows, manual trans) about a year ago.
    Good Feedback: Drives great, plenty of power for hauling small loads, the engine is the shared Mazda design - reliablity is HIGH with these - the 1999 Probe LX had the same engine (had one of those prior to this truck), easy to fix / maintain, plenty of parts at the local scrap yards, plenty of room in the cab, A/C is COLD, heats up quickly in the winter (thank the lords!), engine purrs even after 11yrs. I'm not exactly certian on this issue but mine has a tough time getting into gear from time to time. Its been suggested that this could be due to a poor slave cylinder where the clutching is concerned. I'm waiting for it to stick completely in gear before changing this though simply because I'm uncertain - I don't know that this is a common issue with this model / year but it is frustrating enough to mention.
    Poor Feedback: It's a truck & as such, winter tires are (just my opinion) a requirement - pretty greasey in the rain / snow - even with added weight in the bed. Due to recent electrical issues (minor) the reading I've done suggests that there may be a control module that requires replacing in the steering column, apparently this is common to this year of Ranger. Mine came with a single key and to have another key made they basically have to give me a new key system & that is expensive! This is due to the Anti-Theft technology they used at the time. If I had a second key, the third could be programmed from the original two but with only one, Ford has to work some magic I'm told (as per a couple dealerships).
    Would I purchase / recommend a Ford Ranger to others, YES definitely. At least the 1999 I would. I'm happy with the way it drives, it always starts and it's got plenty of power when hauling a load and gas consumption, full or empty is fair - at least comparable to the '99 Probe I got rid of to get the truck. Hope this helps.
    Cheers,
  • xscoutxscout Member Posts: 141
    I have had two Rangers over the years, both with manual transmisions. One was a 1983 when they first came out and the other a 2008 which I got last year. Both have been dependable and trouble free for the time I had them. I live where it does not snow, but keep in mind any pickup will be a little more able to break loose in the rear. On the other hand I have been hit hard in my 2008 ranger once already and the car that hit me paid a heavy price compared to the minor damage I received. A truck is also much easier to work on, better access.
  • ptombptomb Member Posts: 1
    While driving about 70 mph in 5th gear on the Interstate, there was a "clunk" and the engine began racing. Cut the throttle, stabed the clutch, pulled over and found that while shifter worked fine, only 4th gear would engage. 2nd makes a slight grinding like the gears are barely touching ... and nothing in 1st, 3rd, 5th and reverse. Anybody had such an experience? :sick:
  • klick1klick1 Member Posts: 2
    Just bought 2000 ford ranger automatic with 120000 miles drives great except when it get up to third gear it starts to slip and the rpm's start to red line. Do i need to rebuild my tranny or is it something else if any one can answer my question it would be great. I love the truck just wish i could fix this problem without dishing out tons of money,if anyone has had similar problems and know what to do it would be great if you could let me know what you did to fix it.
    My truck is a 3.0 4x4 if it makes a difference thank please give me any you have thanks
  • romabukromabuk Member Posts: 2
    Yes. My orginal is 1993 (I bought new and still drive it) extra cab, 4l, 4x4 manual transmission, and the larger tires (at the time) currently 260km. Archilles heel is the slave clutch cylinder is expensive to replace and is known to fail. Front door mounts eventually wer and the door can sag. The box frame mts rust out (same problem known with F150) everything else is normal. I used it for 4x4ing camping, road trips, cruising, fire wood. Great all around down sized truck. Prefer crew cab next time.
    My ranger is 1993 xlt 4x4 manual with 4L engine. The whining sound is normal or has been there in mine for years. It is slight or hard to hear.
  • tank9tank9 Member Posts: 1
    This also happened to me and it ended up being the flywheel.
    Before it happened I would hear a whirling sound when I accelerated and less
    of a whirling sound when I let up. As I kept driving the flywheel totally broke
    away from the transmission and the truck coasted to a stop. Where the flywheel
    attaches to the transmission was completely ripped off. ($97 for flywheel $400
    for labor.) Had to drop trans and exhaust. 1996 4x4 4.0 extended cab Ranger.
  • wenchrgswenchrgs Member Posts: 1
    My boyfriend keeps having problems with his 00 ford ranger not wanting to go into gear replaced steering colum now he thinks its the steering cable any suggestions before spending $120 on a cable that may not be problem
  • byrd2765byrd2765 Member Posts: 1
    I have a 1992 ranger with a 3,8 v6 and it shifts hard and very hard to down shift 5th gear and reverse is espacally hard any idea?s
  • lacrossesoakedlacrossesoaked Member Posts: 87
    1991 Ford Ranger V-6, 4.0L: I have read the manual eight times but I am still not sure I have the proper amount of fluid . Checking it cold, without the engine running (is it supposed to be running when you check it cold?) the level is just below the hatchmarks on the dipstick; fluid covers both of the holes on the dipstick. Checking it after driving on the freeway for 25 miles, with the engine running, the dipstick is clean, no trace of fluid. I let it cool down for 30 minutes, checked it again (engine off), fluid reaches the bottom hole on the dipstick.
    I am not comfortable with the dipstick being "clean" after the freeway driving. Please HELP !
    THANKS !
    Interesting. I don't know a whole lot but there should be fluid present on the dipstick both when cold and hot although when hot it may be extremely low! Keep in mind that once the engine is running the fuild is moved about via pumps so there will be less from the point you are measuring from. Although it sounds like your truck is a manual transmission which means you should be checking the fluid when the engine is OFF & cold (takes a lot longer than 30mins for an engine to be cold to the touch).
    First off, cold means that the engine hasn't been running and is cold to the touch.
    Automatic transmission - check the fuild level while the truck is running.
    Manual transmission - check the fluid while the truck is off.
    Remove the dipstick & wipe it clean - re-insert & remove again & the fluid level should be between the high & low marks on the stick - the two holes. Keep in mind that when the truck is running pumps circulate the fluid which means less in the area you are measuring from - perhaps a LOT less.
    Bottom line... if you're not experiencing hard shifts or noises while shifting then you're probably okay but if you've a real concern about it, you should take it to a mechanic & have them check it or for what little it costs, have them change it out. They can also tell you about the color - red=healthy, brown to black = time to change.
    Hope this helps & cheers!
    Well, the post's title says 'automatic transmission'.
    I assume, like most auto trannys, the manual tells you to check after being warmed up with the motor running, in Park or Neutral. Right?
    You said 'Checking it after driving on the freeway for 25 miles, with the engine running, the dipstick is clean, no trace of fluid. '
    I think the manual says to run the vehicle until warmed up, then check. Running this far, if the outside temps were high (90 or more), might make it hotter than the manual is requesting. But, hotter would just push the fluid level higher.
    Anyway, after 25 miles, engine running, no fluid on the dip stick means obviously YOUR FLUID IS LOW!!!!!
    Look in the manual for the correct tranny fluid to use, and go buy some and add some. Add a little at a time, one cup, and recheck. When it starts to show on the stick, it will come up quick while adding a little fluid, a few ounces. Of course, with it off the stick you might have to add more than one quart.
    If it's this low, you have a leak somewhere. Or, the vacumn modulator for the transmission has a busted diaphram and the fluid is being pulled up the vacumn hose and burned in the motor.
    Thanks for the advice. It is an automatic transmission. Here is the back story: a while back, the truck was serviced at a garage. Sometime after that, I checked the fluid level (after a 25 mile drive on the freeway); it read really high. Truck was shutoff for 4 hours. Drove it back home (25 miles on the freeway); still read really high, way up from the top of the hatchmarked area. Soooooooooo, and this is where I must have gone sideways, I assumed too much fluid was in the reservoir. So I removed about 1.5 qts of fluid (so stupid). Having re-read the manual now, it specifically states that after freeway or hot day driving, let the vehicle rest for about 30 minutes prior to checking. I put fluid back in yesterday.
    Question now is: have I done permanent damage to the transmission or do I get a pass on this blunder? Drove it around 200 miles or less on the LOW fluid.
    I think you're okay. Sounds like you caught it in time & although you took quite a bit out you left enough to do the job so I don't think there's any permanent damage. The only real way to tell is to drain a bit in a glass & check it for color & impurities - metal shavings, dirt, etc... but I think you're fine.
    I also think you are probably ok.
    Low,low fluid will cause 'drivability' problems. Harsh or sloppy shifts. Not 'going into gear' quickly. If you drove it a while with symptoms like this, you might do damage.
    My somewhat simular story - A previous wife, before she became a wife, had a 69 Camero that everyone in her family drove and no one maintained. It was a 3 year old car. When we go so close that she would let me grope her car, I checked the tranny. Nothing on the stick. I buy a quart of Dexron and slowly start adding it. And adding it. And adding it. Got the entire quart in there - don't remember if it was on the stick or not. But it took about another half quart to get to the mark. I then jacked it up and looked at the bottom. For some reason, most of the bolts on the tranny pan were loose. One was gone. Tightened up the pan bolts and replaced the missing one and the fluid then stayed in it.
    And the car never missed a shift and was very smooth - with 1 1/2 quarts low.
    I did not notice any problems with shifting while driving on LOW fluid. Maybe I did get lucky this time. Thanks to both of you for your assistance.
  • thm728133thm728133 Member Posts: 1
    I have a 97 ranger does the same thing, I have installed heat deflectors, and wrapped hyd clutch line in tin foil. but on 85 to 90 degree days I had better not drive over 20miles or the clutch will act up, Let it cool 15 min and away you go.. I now carry a jug of water...for cooling..
  • alan60alan60 Member Posts: 1
    I have a 93 Ranger 2wd 4 cyl 5 speed. This will be my 2nd transmit ion replacement. I will be driving along and it just seems to go to neutral. I try to engage the clutch but it is not there. I roll to the side of the road. After about 15 mins my clutch comes back but the transmission does not.
    I would like to know what is going on? What transmissions can I look for to replace it. What years will bolt up and if a different make like Masda would also work?
  • mwillisjr57mwillisjr57 Member Posts: 1
    edited June 2010
    hey guys, new member here.............I recently had my reverse band break in my 99 3.0 v6 ranger automatic tranny, I am having financial troubles right now so I decided to pull the tranny out myself....everyhing was going great till I got to the top bellhousing bolts...........lol now I have no idea how to get to them......any tips???? I can't reach from the top or bottom and I am really frustrated cause once they are out so is the transmission!!!!!!!!!
    does anyone know where I could get a picture or the tranny or where all the bolts are????
    thx guys
    Mark
  • blk4x4blk4x4 Member Posts: 43
    edited June 2010
    you need to remove the cross member holding up the rear of the tranny and lower the back down to give you more clearence to the top bolts and to get to them you need a swivel socket or one with a socket on it 3/8 is what i use and you will need a 24 inch extension or smaller one hooked together and a breaker bar to break them loose then back them out with your ratchet or impact,dont forget to take the bolts out of touque convertor also,,good luck
  • daddyj1daddyj1 Member Posts: 2
    edited June 2010
    I have a 91 ford ranger just rebuilt motor v6 3.0 an drove for a week an trans went to crap in a hand basket. Took it to two shops both said lots of arms legs & i think some teeth.1200.00 to 1500.00 so i found 92 ranger good runner i thot, the 4cly went in about 3 weeks,bought 92 for 400. it has auto trans 4speed od will the trans in 92 4 cyl bolt to 91 v6 3.0 both automatic 4 speed odrives. thanks for any incite.To ad i found a 5 speed manual in a91 ranger v6 3.0 do i need to take computer out of the one with manual trans an put it in the one that has the auto trans? i have all the pedals an steering column for the swap if need be.but rather go auto to auto easier
    just checking
  • forder1forder1 Member Posts: 1
    how do I bleed my manual transmission line on my 1995 ford ranger
  • ohmicronohmicron Member Posts: 1
    But only when all is cold.(early 1993, 3Liter w/ 175K miles.) When engine is reved slightly w/ truck at rest trans will reenter w/ a slight jolt and I'm on my merry way. This also happens in reverse. I find myself shifting to neutral prior to stopping when engine is cold. This is very un-nerving in traffic. External linkage has no slop in it and seems to work properly. Fluid level is normal and has never been cooked (flushed and changed @ 100K mi.). This vehicle must be seen to be appreciated so letting it go isn't an option.
  • coldmamacoldmama Member Posts: 1
    i have a 99 ford ranger. had no problems. my abs light on my dash came on and my speedometer went from 0-15-0 again while traveling. started shifting hard. flushed trani fluid and checked front wheels , no wobbling, no problems with barrings or brakes. can anyone help. ?????????
  • alfredralfredr Member Posts: 3
    my oil seal blew out ,is my trans blown or need a new seal and coverter
    MY FRONT SEAL BLEW OUT,DO I NEED TO REPLACE THE CONVERTER AND TRANS OR JUST THE SEAL
  • 2007ranger2007ranger Member Posts: 1
    Have a 2007 Ranger XLT V-6 4.0 5 speed auto. Having occassional clunk noise from tranny or drive line (like a bad u-joint) after turning a corner and accelerating. Same thing on highway when I de-accelerate then accelerate but not all the time. Ford shop says everything looks fine and can find no problem. Last time service "expert" says thats the way its designed to eliminate excess torque between drive line and tranny so the clutch doesn't have excess wear. Have 46500 miles and tranny flush at 45000. They said fluid was "slightly" burnt and failed to save me a sample that I requested. Any ideas???
  • jshadowjshadow Member Posts: 1
    It still moves a little bit in reverse but it acts like it's in nutral, but drives and shifts fine in drive. Anyone know whats wrong? The cicker I had it sold to a guy and he was going to pay and pick up today, damn my luck.
