Ford Ranger Transmission Questions
                    I use a quart every 1000 miles or so. Leak is from front of tranny. Shifting happens too easy and too often.  Anything to try rather than a tranny rebuild?
Why won't you replace it? You've already been told...
The transmission also shift roughly, right?
On my 4Liter Ranger, it was right above the cat converter, I think. It is tough to see, but these are usually held on with one bolt, so you should be able to get a socket on it. It really shouldn't be that difficult to remove.
Have a BIG catch container. When the last bolts come loose, and the pan drops down, the fluid will start coming out all around the pan.
Very messy.
torque converter
tcc solenoid
trans wiring harness and filter $ pan gasket....all for a whopping $1023.42....
Thanks Rangerdude7
IS STUCK IN SECOND GEAR.
Paul
Only thing you might try - a gravity bleed. Just open the lower bleeder, take off/loosen the top cap, and just see if fluid will drain down and move the air out.
Only other guess - call around to other garages to see if you can find one with experience doing a Ranger, one that will say they can successfully bleed one.
I tried the gravity bleed as per the Haynes manual, but it doesn't flow out, it trickles.
If they can't get it soon, the Ford dealer is right across the street! I prolly shoulda taken it there to begin with. So much for trying to save a buck.
When you start the eng to check the trans level it's checks OK (cold). But you drive the truck for just a few minutes then check the level the fluid poors out. I checked the vent tube and blew air in it, it does not seem pluged.
The truck has not been driven much.
any thoughts?
I need to know what trany is in this year truck to order a shifter.
The pan has 18 bolts. :confuse:
I think yours is sticking for some reason. I don't know if flushing the fluid and refilling with new might help...
Or, it might have to have a new slave cylinder put on it.
It seems to be slipping, but not at the clutch. Are there known problems with either the trans or the rear end? It's only slipping a little bit like at the axle spline or maybe the tail shaft of the trans, not sure.
Thanks for you input.
AlamoRanger
I'm hoping that it's a simple fix...that since I actually have a D/OD that it'll be nothing internal, but i'm no mechanic.
Thanks for reading.
Do I have to drop the pan in order to do so? If yes, is
there a gasket to replace? Is there a filter in the
transmission?
This will be a small 'can' that plugs into the side of the tranny. It will have a hose, probably a combination of rubber and steel line' that runs from it to a vacumn source on the intake.
