You do know that the Denali and Escalade clusters will fit also and get a trans temp gauge with it that plugs in at not much more cost that the one for the Silverado.
HELP
bulbs
Switch/relay
Module
drewr1981@yahoo.com
I have a 2004 Silverado Ext. Cab. The backlights on half of the steering wheel controls have gone out, as well as the backlight on the battery voltage indicator, the driver side heater contol, and several controls on the radio.
I am in the military stationed in Germany. There are very few GM dealers over here. Any help would be much appreciated. Thanks.
SLT switch
Several people have reported that it's a simple plug and play procedure requiring about 5 minutes to complete and gives you access but not limited to fuel mileage, range, gallons used, V8/V4 mode notification, tire pressures, tire sensor learning, key fob learning, chime volume, entry and exit lighting schemes, lock and unlock schemes (including automatic lock/unlock), unit and language choices, engine hours.
Is this what you're looking for?
Dave
Any help will be appreciated.
The ABS warning light and the brake warning lights stay on. I have taken it to the dealership and they ran a scope on the electrical system. I have brakes, just no ABS. There is "no communication" with the computer on the one line yet, the transfer case can be read which is tied into that line. The grounds were checked for the module that runs under the driver's side door, cleaned and re-installed. Is there any recall out there from GM on this? My truck is just out of warranty. This has the dealership baffled as well as everyone else I've talked with.
Thanks...
Joe
Most likely the same problem described by "azjas" (#148 Intermittent Computer Problem)
I just don't have that type of money at the moment, but that's another problem. I am told the switch is about $175.
FYI, during my warranty period they performed the following electrical repairs: alternator (under charge), alternator wiring harness (wild overcharge swings,bulletin PI.73170D), reprogrammed the radio module (no volume, bulletin 02-08-44-020B), replaced airbag sensors upfront, 6 software updates for the 4WD, AC pressure switch (shorted), 4WD drive light on-reprogrammed transfer case module (bulletin 02-04-21-006A).
And now the wipers won't turn off at times.
