Visitor Agreement.
Eddie
Is it a fuse? HELP!!
(2006 Silverado 2500HD).... dicemd at YAHOO.com
does anyone know how to get my engine light to quit flashing when only that one code comes up for the module or what the problem is??? and if i, as he is suggesting it may be the computer, what yr/truck do i get teh computer from???
he says he checked the vin with chev and with his code reader and both say its a 95 but he can't figure out why it has a ;96 - 2000 wiring harness.
any replies would be appreciated and can be emailed to me if possible to, snooky71@hotmail.com
mike d
Does this truck really have the mileage reminder for oil changes that
notifies you when its time to change the oil? :confuse:
Can you tell me what fixed your truck, I have the same problem with my truck...
MY TRUCK DOES THE SAME THING WITH THE GAUGES,
DOES THE IGNITION SWITCH FIX IT? AND WHERE CAN I GET IT?
1 HAVE A 2000 SILVERADO
I will check fuse. Where will the fuse be located?
If fuse is not the problem what else should I look at?
Thanks.......................larry
Engine. 109000 miles. Only on cold mornings/days
does it stall and idle really rough and missfire. Here is the strange part: if I unplug the MAF sensor, it runs
fine. If I plug it back in, goes right back to crap. So I
thought i had found my problem and replaced the MAF Sensor but to my surprise it did the same exact thing. It is throwing a coolant temp sensor code so maybe
that is the culprit. My question is if it is a bad coolant temp sensor, why does it run fine when I unhook the MAF? I also tried unplugging the coolant temp sensor but it still does the same thing if the MAF is plugged up.
- CJ
Do I use the 87 computer (1227747) or should I use the computer that came with the 94 (16146299) and just not hook up the temp sensor that is in the left side cylinder head as there is no provision for it on the 87 wiring harness. Thus only using the temp sensor in the inlet manifold?
Thanks............
Why is it that only my wipers will work on "High" and if I shut them off when their moving thats where they stop. They don't return down to the bottom of my windshield. My cruise control wont work either. Can I just replace that lever on the steering column? Thanks for anyone input.
kcram - Pickups/Wagons Host
After leaving Utah and heading to Salida Co when twice this thing over heated to the point both the engine temp and the trans temp went all the way over,it boiled out the antifreeze to the point I had to add a half gallon.
This truck has pulled the Mountains two to four times and never had a problem.
Since this happened my fuel milage has gone down to about 11 to 14 empty.
GM said they don't find a thing wrong,so if I leave AZ. pulling my 5er what the heck you think I'm going to get.
Trading it is the last thing I want to do,any ideas??????????? Is it the computer its got me.
Seabeemax :mad: :lemon:
Seabeemax :mad:
With my new truck, I will have to use a ladder to do that...
the flasher is located?
Thx
Never mind......I figured it out. Its for the acc. power and trailer wiring feed. Thanks anyway
Well mine is over 100000 miles and the speedometer went to 120 for a day and then the next day it apprears to be ok.
I haven't checked the mileage yet with my garmin to make sure that it is correct now.
It is too bad a lawsuit is required when GMC knows they have a defect. Our Volvo had an issue and they voluntarily extended the warranty on the part to 10 years or 200,000 miles. Too bad GM does not get customer satisfaction or understand that you get customer loyalty if you stand behind your product.
My new 2009 5.3l Silverado has an erratic voltage display. When driving, the voltage gauge will move up and down from 12 volts up to 15 or 16 volts. I went to see the dealer and they told me that it was a normal operation and that the computer controled the charging.
Is this true? He also said that should the light come on, I would then have to bring in the truck for servicing and to ignore the gauge.
It's a trange thing seeing the voltage change that way. I've never seen this before unless there was a wiring problem.
Any help/suggestion would be greatly appreciated.
Since then, I have been very observant on what the battery has been doing...and SINCE I got the battery replaced, I have noticed the same as you...but have never had any other issue, so I assume that this is a normal thing.
Normally I notice it most on the highway...but even with iPhone and GPS and any other crap plugged in, it's been fine.
I've learned that the dealer's are not always aware of the bulletins, so it helps to bring the info.
