Matrix Electrical/Lighting Problems & Solutions
PF_FlyerPF_Flyer Pennsylvania Furnace, PAPosts: 9,196
Having an issue with the electrical system or lighting on your Matrix? This is the place to ask for help and offer solutions!
Silver 2012 Nissan Versa Hatchback & White 2019 Nissan Rogue S
Need some roadside assistance? [email protected] - or send a private message by clicking on my name.
Just purchased or leased a vehicle? Write your own vehicle review
«1
  • After hearing some crunching sound when shifting in and out of Park and Drive, one night while driving, I noticed there is no light luminating thru the PRND2L window corresponding to the gear I am in. I think the peanut bulb on the automatic shift lever has come loose and got crunched.
    Anyway, has anyone gone into this area of the center console. I see a screw on the shift knob, but how do I remove the cover to get at the bulb, which I assume is at the base of the shift lever.
    Any ideas?
    TIA
  • gwmchunggwmchung Posts: 1
    I have the same problem. Did anyone figure this one out?
    Gloria
  • fear_hopefear_hope Posts: 90
    Doesn't the way the outlet cover is constructed limit the use of the outlet. How do you use it with larger plugs? The ones with an adapter at the end seem to be at a total loss... :confuse:
  • herzogtum71herzogtum71 Posts: 470
    You're right. At least on the 2003 model, both the cover and the position of the outlet make it next to useless. When we first got the vehicle I wanted to test the outlet to make sure it worked. After trying several devices with plugs that didn't fit, I tried a small desk lamp and an old electric radio. Not likely to need either of those devices while cruising in the Matrix.
  • bearabull1bearabull1 Posts: 3
    I have a 2003. I'll have to check it out. I now Sams Club sells an outlet converter which will angle. Would I be able to use the laptop on a cigerette converter if it's under 100 watts?
  • freedom2freedom2 Posts: 1
    Has anyone found an answer to the light bulb problem on the shift lever? Our lights on the odometer etc are also out. The dealer's service center failed to correct the problem and the car is now 1 week out of warranty.
  • mcdawggmcdawgg Posts: 1,682
    A week out of warranty?? Just call Toyota (800 number in your owner's manual) and explain the situation. I almost guarantee that they will cover it, considering you're only a week past. Also explain that the dealer screwed up, and they will make it right, free of charge.
    mcdawgg is right. As long as the problem was brought to the dealer's attention before the warranty period expired, Toyota should still cover the repair. You probably will be asked to provide a dated receipt from the service department as evidence that you tried to address the problem during the warranty period.
    Even if it was shortly AFTER the warranty expired, Toyota will more than likely cover it, if you call them. I know this from experience. We were a month or so after it expired, and Toyota picked up the bill. You will have no problem - just call Toyota (customer service center in California.)
    Toyota might pick it up without a fight, or they might not. I have a friend who was denied a claim for something a couple of weeks after the warranty expired.
  • My check engine light came on the other day and it wasn't the "normal" check engine light, the one for regular maitence. This one simply says in the manual to take the car back to the dealer. So I made an appointment. The service department thought it might be that the gas cap wasn't on tight enough but infact it turns out to be my ECU. They conuldn't fix the problem on that day so they had me come back after the part was in. When I came back I found out that the part ordered was not the right one and the one needed for my 06 Matrix is on NATIONAL BACKORDER. I'm interested to find out if anyone else has had this issue and if it's been resolved.
  • budhbudh Posts: 109
    Most laptops use voltage between 12 and 24 volts and current less than 10 amperes.
    (The Dell Latitude D820 which I am typing this from is about 5 amps. As a general rule, any electronic device can be used with the plug. It is the devices with major motors or heater elements that may draw too much current, such as electric drills, electric heaters, possibly a small vacuum might be too much, also).
    Bud H
  • aws1aws1 Posts: 1
    i have a 07 matrix and the other day i plugged my cell phone charger into the outlet and i guess it was too much and it fried the electrical system like blew the fuse is my guess.....any ideas on a quick fix so i can have the radio and clock back on in the car?
  • kiawahkiawah Posts: 3,666
    Replace the fuse
    You should take care when plugging in your phone charger outlet. Note on the male plug, where the side metal contacts are. Look in the female plug, and see where the metal sides are continuous. You want to put the plug straight in so that the metal contacts on the male plug, make clear straight contact down the side. Push it straight in, and don't twist it while putting it in. What generally happens is the male plug shorts out the contacts if it is loose enough, and twisted around.
  • harkyharky Posts: 13
    Hi all
    I have a 2005 Matrix XR 4WD (39K miles on it), and few weeks ago, the air-bag warning light came on. I parked the car on the side street and turned off the engine. I waited few minutes, then when I re-start the engine, the light disapperaed. But, today, while I was driving, the air-bag light came on again and it won't go away. Is this something that I should be really worry about? If anyone experienced a similar situation, would you please share your thoughts? Thank You
  • I have a 03 Matrix XRS, recently started acting like battery going bad, checked and replaced battery now 2 weeks later sounding like weak battery, now won't turn over r even click when try to start, battery good, alternater good, starter good, clutch engage switch good. can puch start and everything is fine, lights, running lights, radio, windows, until turn switch off. Having to park on inclines to get running
    Sounds like either your alternator is defective, or something is on draining down the battery.
    You say the alternator is good, how do you know that? You need to have it checked under load, and any of the autoparts chains can do that for you for you, usually free. This is actually a combination battery and alternator test.
    If they check out, then you will need to measure the amperage draw on your battery when everything is off. If you find amperage draining, then you'll most likely need to get an electrical schematic to figure out how to start methodically unplugging fuses to find the culprit circuit.
  • We plugged in a Sirrus radio to cigarette lighter and now cig lighter and radio do not work in our 2004 Matrix. The manual shows 2 sets of fuses but we can only find the one in the engine. The book says #28 fuse could be the one but can't find it. It is not under the lower left side of the instrument panel like someone from the dealer thought it would be. Any one else had this problem?
  • Did you get a solution? I have a 04 Matrix and lost radio, clock and cigerette lighter.
  • I have an 03 matrix xrs and I have been having the same problem. Toyota has replaced my battery and It's still going dead. Have you found the problem?
  • nippononlynippononly SF Bay AreaPosts: 12,726
    It means there is a problem, probably electronic, in the airbag system. It is likely that right now the airbags would not deploy even if you were in a bad accident. It would be a good idea to have your mechanic check it out.
    You can check with the dealer to be sure, but I think the airbags are covered under a longer warranty than the bumper to bumper, so it is likely any needed repairs would be free.
  • etchedetched Posts: 6
    Any clue to how to get doors to stay locked when shifting into park? I have a 2009 T Matrix X FWD w/auto, power doors, keyless entry. I read the manual as did my spouse, but it still won't switch to keeping the doors locked when in park. I shift into drive, they lock, into park they all unlock, very bad. I also can't believe (as stated on page 421) that I have to go back to the dealer to have this customization done.
  • It sounds like that was designed into it, with the expectation that when the car is in Park the passengers will want to exit the vehicle. Once you are outside you can use the remote to lock the doors again. If you want to lock the doors while still inside the car, remove the key after shifting into park and use the remote lock. Yes?
    thanks for the reply, but I already thought of that. There's a thing going around where young men circle a lot to see if someone's about to park and they jump out and grab a back door handle to see if it's not locked when you are parking. They jump in behind the driver's seat and I won't go on from there. This is a dangerous set up. Even hitting the master door switch may not be fast enough.
  • That scenario crossed my mind but I hoped it was not what you were worried about. Now I totally agree with you that the feature must be defeated. I hope the dealer can do that for you. It's clearly a security issue.
  • Personally, I find the unlocking of all doors absolutely brilliant. The efficiency and convenience was well thought out. The owners manual is very explicit about "customization" of the door locks in automatics as versed in the sub chapter "Customization" residing in the "Vehicle Specifications" chapter near the rear of the manual. Again, efficient and convenient. The default of opening the doors while putting the transmission into "PARK", can be customized to OFF. Setting and canceling these functions resides in the sub-chapter of "opening, closing and locking all the doors" in Chapter 1 of "before driving".
    1. Close all doors with engine switched to "ON".
    2. Shift lever to Park or Neutral, then hold the driver's door lock switch (on the arm of the driver door) in the door's lock position for 5 seconds.
    3. When the setting or canceling operation is complete, all doors are locked and then unlocked.
    Otherwise, your Toyota dealer can complete this function.
    Ah, I would suggest that not parking in such a parking lot where "young men" circle the lot is the best prevention. The more direct route of assaulting the driver extricating themself from the vehicle, is more effective then vaulting over rear seats through unlocked back doors. Should they enter the back seat, pull out the keys and leave, thus immobiling the vehicle. Then press the panic button on the key remote to signal for assistance.Then run for safety. May the safest and secure driving follow you.
    Irishtiger,
    I tried those steps already and still it doesn't change. So, I tried contacting Toyota's chat line, that was a bust. Called the dealer and he said they could do it in seconds, we shall see.
  • I recently had body work on the rear door and quarter panel my 2004 Matrix that caused the shop to disconnect the battery. When I picked the car up, I noticed that a portion of the radio face plate's LED screen is unreadable. A small bulb behind the screen must've blown out. Of course the body shop insists that nothing they did would've caused this to happen, but it seems unlikely that it would have happened coincidentally.
    Anyone with any thoughts on this?
  • kjtkjt Posts: 8
    I've tried the Pontiac forum and thought maybe someone with a Matrix could help on this problem. I have a new 09 Vibe, luv it, but you can not turn off the headlights at night with the ignition turned on, not even to the park lights. The headlights work properly without turning on the ignition, like any other car you can turn them to park and then to full headlights, but as soon as you start the car all that goes away. Very frustrating when you are sitting somewhere needing to dim your lights to park for any reason, the only way you can do this is to shut the car off. No luck whatsoever with GM's customer service on this issue and the local dealer told me that it was built into the computer that way. He told me that the Vibe was Pontiac's low end car and what did I expect to get from a low end vehicle anyway. Well I didn't think it was asking that much to be able to have some control over your headlights at least. The one thing I did learn from all this is that the local Pontiac dealer in North Platte, NE will never get any of my business again. Any ideas from anyone?
  • Here's instructions on how to add a separate switch to control the headlights:
    http://matrixowners.com/?showtopic=12523
