Ford Escort Engine Problems
in Ford
Have a question about an engine problem? Post it here and get the help and advice of other Escort wagon owners.
I have a ford escort 96 station wagon.
The "check engine" indicator had turned on and didn't turn off.
After a few days it turned off, and now it's not turning on when I'm starting.
Anyone know what is the meaning of that ?
Do I need the car serviced immediately ?
Lira.
Any ideas?
the rubber looked okay but was deteriorated and collapsing when at higher vacume levels.
when replaced it ran tip top
I owned a 93 1.9 Escort. I had 'overspeed' problems. No sensor lights came on. It turned out to be an easy to replace Throttle position sensor (You can buy online ... use Google with "ford parts escort". Now I own a 96 1.9 Escort. These are really reliable cars. Good luck
Dick R.
trying to fix my girlfriend's 92 escort wagon; it's hard to start when cold and idles very rough. but it also wants to stall at stop lights. the car has no power and has a very hard time starting out. also noticed it back fires lightly? just did spark plugs and wires. could it be a coil?? any help would be great thanx
I think you may have had the same problem and I am wondering what fixed that problem for you??
:sick:
My car and I need your help, thank you.. Jord
It ran out of gas and has seemed to have gotten worse as well. Thew only time in my life I have run out of gas and I think it will cost me. Off the start it has no guts and takes time to get going. Sometimes the idle is so rough it hurts me
Changed the fuel filter and air filter, thinking maybe the pcv valve change???
could this harmonic imbalance problem have been caused by the air conditioner repair? cause it sure seems questionable that my car would break down for the first time 4 days later.
any thoughts? anybody else heard of this repair? thanks!
the ac check was free with a coupon, but i've seen it advertised for 30-40 bucks for a checkup on ac. maybe the shop will put the check cost towards the repair??
sounds like what my car was doing. no cool air. compressor was fine.
At 120K engine lost two head bolts (cracked just past the head) on opposite corners ... right rear, left front. Replaced timing belt, water pump, shipped out the head (everything fine), etc. Since then the idle, when warm, stays at roughly (no tack) 1300 RPM for several minutes, then falls to roughly 600-700 RPM. "Give Ford $" light now stays on. Speed will not hold steady when car is ideling high ... I can't put it in 4th gear & hold speed, it falls, but not to proper idle. Mechanics have not fixed the problem. Over the last 10K, problem has increased in the duration (up to 2 minutes now) till normal RPM. This only happens when engine is at normal op. temp. & driven for 1/2 hour +.
Thanks for your advice.
it has 220,000 clicks on it and it runs pretty good till u drive it for a while then it starts to act up.
Anyone knows whats causing this ?
Would really apreciate if anyone could help me.
Tks...
I heard about several people having problems with Escorts, but would these problems still be there even if the original owner maintained the car extremely well, including all wiring and wiring harness?
But I heard the Escort engine itself is powerful, dependable, and reliable. And I've been seeing a lot of Escorts being sold cheaply for low miles. But, is it to make a quick sale for 16 to 20 year old Fords that were forgotten about or are they cars that you dump money in?
To buy or not to buy?
That was two years ago and now it has 120K miles. The car always seemed to have problems accelerating once it gets into 2nd gear. In 1st it is awesome and 3rd gear and up it is fast and smooth. But once it hits 2nd, it seems something is wrong. It could be at a dead stop, I would floor it: at the start I can keep up with any V6 or V8 car that wishes to race me, but as soon as it shifts to 2nd gear it seems to not accelerate much and over the past year, I have noticed a strange "gargling noise" as if it is not getting enough power, or fuel, or something. I replaced the fuel-filter and I keep all the fluids clear.
I wasn't too worried, but I want to upgrade to a cold-air intake and I don't want to damage something by putting way more air than it can handle.
PLEASE HELP!!! I'll accept any advise with appreciation.
:confuse:
Anyhow, we managed to get the RIGHT coil, (how amazing, the RIGHT one is VERY obviously visible!!) and the right plugs, and now everything is running fine again...!!!
I have opened the hood with the car running but do not hear the noise.
Any help out there?
I have Escort 1997 and I have some extraordinary vibration and noise when I start the engine. It does occur random (not each time when started), and disappears in 20-30 seconds. There is no engine check light on, but a noise as from a vacuum leak. The car runs good,there is just this strange noise, that is making me think something with the air intake might be wrong. Any ideas if it might be something else or where to track eventual leak down on the hosing???
Are they all loud? Is that the reason why? If so, can anything be done about it for a reasonable cost?
I wouldnt be able to say all escorts are LOUD! because i havent been in that many but i can say my dad owned a 94 escort 1600 , and i own myself now a 97 ford escort zetec , and i can tell you ..theyre not the most silent of cars
i remeber mine , getting to a point that was unbearable :mad: but eventually changed the wheel bearings to a smoother lot ...and had no problem since. but yes its still pretty loud... no idea why thou ..but they are good reliable cars soo.
