Nissan Altima Engine Failures
Discuss the problem here!
MODERATOR /ADMINISTRATOR
Review your vehicle
The National Highway Traffic Safety Administration said that the 2.5-liter engines in the cars "may experience excessive oil consumption as a result of improper performance of the piston rings," a condition that could lead to an engine fire.NHTSA said if engine oil is not maintained at least at minimum levels, engine damage is likely and a fire is possible.
Owners can contact Nissan at (800) 647-7261 or NHTSA at (800) 424-9153.
"In a separate announcement, Nissan North America Inc. said it would recall 200,000 Altima and Sentra sedans from the 2003 model year to fix a faulty sensor that can cause the engine to shut down in routine traffic."
http://www.detnews.com/apps/pbcs.dll/article?AID=/20060713/AUTO01/607130390/1148- /AUTO01
Nissan is going to take the cheapest way out. Second letter went out Nissan still has no solution. I have been offered a motor Nissan said it would expedite sending it to the dealer. That was the end of June. Still no word. Second offer for a motor came just prior to arbitration with BBB Nissan stated it would be available in 90 days. Give me a brake they were quick enough to take my cash but left me hanging. Also the oil blowing back through the exhaust will damage the converter. That's why they tell you not to over fill your oil. If they change your motor make sure they change the converter also. If I don't get a buy back through the BBB I'm going to park the car IFO the dealership with the biggest signs I can buy stating "ASK ME ABOUT MY NISSAN LEMON AND HOW NISSAN TREATS IT"S CUSTOMERS!!! I will keep you all posted.
I have been reading some of your posts and for sure there are some pretty unhappy people here. I am presently in the final stages of purchasing an 06 Altima 2.5 SE Special Edition. I now own a Pathfinder which has been one of the best vehicles I have ever owned. I have talked to the local dealer and I have been reassured that the issue of the oil consumption will be resolved fully before I ever take possession of this car. The deal too is unmatched by Honda or Toyota, almost $4,000 difference in price out the door. They have an 84 month extended warranty as well as free oil changes/tire rotation for life. That is pretty hard to beat. My feelings are that Nissan is a company that has been around for a long time. They generally produced some pretty remarkable vehilces and this oil issue will be resolved. Unless I missed the boat here I think they have covered most everything and I'm getting quite a good deal.
Something sounds fishy, here. Catalytic converters are covered under Federal law for 8 yrs./80,000 miles regardless of failure cause.
Finally, let me alert everyone to the recall for the subframe. I live in new englad and the entire thing corroded in less than 2 years. I have a new subframe but my brakes corroded prematurely and now there are tons of rattles. I feel that I am driving a tin can. Best of luck to everyone with lemons like mine.
I have been told that a recall of the power valve would solve this. However, the power valve has since been replaced, and now its happened again this past Friday, 9/8/06. I am currently in a loaner car at this time until further diagnosis. My husband seems to have noticed that there is damage to my original, like new, Nissan spark plugs, which could be a sign that there is something loose in the engine that is hitting the spark plug and causing unusual damage to my plugs, and as a result may be the cause of other problems that Nissan is not yet ready to admit to having with my model vehicle.
I've been researching the Altima 2.5S and the Impala LT and we've pretty much decided on the Altima. However, after seeing this oil consumption problem I'm a little leery. Where\how can I find the build date of the car? Engine sticker somewhere?
Thanks!!!
Hang in there, Jim
I'm thinking of buying the Nissan Altima 2006. Looking at this discussion, it is very scary. Is this problem fixed, or better stay away from Nissan Altima 2006?
In general, I'm a new shopper. Do such problems and recalls happen in Toyota/Honda too?
Do you think I was crazy?
Yeah - crazy like a fox! If your cars' build dates are more recent than June '06, I do not believe you got rebuilt engines in your new cars, either. I believe you got new engines that had the latest modifications applied during build. The 84 month warranty is a bonus to alleviate purchase fears. Keep an eye on the oil level. Contrary to what some self-appointed experts claim, it is NOT unusual for any new engine to consume some oil during the first five or six hundred miles of initial operation while the piston rings are seating to their bores. Vary your speed frequently to aid ring seating. Driving at a steady 45 mph speed in hilly terrain is also very good. In both cases the idea is to let cylinder compression and vacuum effects in operation alternately load the rings postively and negatively which works to more quickly seat the rings without excess wear. Varying engine speed does this as does applying fuel with resulting positive pressure from power delivery when climbing and pulling a vacuum in the cylinders when you remove your foot from the accelerator pedal when descending a grade. Avoid full-throttle acceleration during the first 500 or six hundred miles. Limit the engine revs to between 2000 and 4000 rpm when under way during that period, too.
Why would you assume such a thing? Haven't you dug out the paperwork to verify what is and is not covered under the terms of your extended warranty?
(Unless your paperwork was issued by the automaker - Nissan in your case, it's NOT legaly a warranty. Non-automaker provided performance guarantees are legally "service contracts" and come under state insurance statutes rather than true manufacturer warranties that are subject to Federal Trade Commission enforcement provisions. Some service contracts are good (notably those from AAA and Auto Club), some aren't worth the cost of a match to light 'em up. Dealerships love 'em, though, because they get to keep up to half the purchase price and some of these policies require selling dealership service to maintain "warranty" claim rights. (The latter's especially attractive to dealerships because even if you negotiate a purchase discount on the service contract, the dealer's still happy knowing he'll make it up with service charges later - which the contract may even mandate service procedures well above and beyond what the automaker, itself, specifies. Cha-Chinggg) True warranties cannot be summarily canceled by the automaker. Service contracts can be canceled for any failure to have prescribed maintenance performed at a location defined in the policy or they can be canceled per insurance regulations as part of an underwriter bankruptcy filing. Many such companies file bankruptcy when their underwriters determine that the model year cars under coverage are entering the period where they'll be statistically more likely to become a financial burden. [Statistics: figures can't lie, but liars can figure.] After the bankruptcy, the company re-incorporates under state insurance department provisions under a new name and begins issuing service contract policies again - but prior policy holders are left naked in the cold since their "company" was permanently dissolved as part of a business bankruptcy proceeding. Is this a great country or what?
just wanted to get some feedback from others for now...I will be checking into this tonight and my car is going in the shop next week... just wondering what everyone else's outcomes were, if they had this problem and is there something we could do?
I drove about 75-80 miles per day, and in less than 3 months time had accumulated over 7000 miles9 by labor Day weekend of 1990).
We went for a 250 miles round trip drive, from Myrtle Beach, to Charleston SC( was in military at the time) on the Saturday of the 3 day weekend.
Sunday, went to start the car, to go to town, and nothing :surprise:
I was lucky enough to get special liberty and the duty cook to stand in for me!
On Monday, Labor Day, Nissan( 40 miles away) came and towed us to the shop in Georgetown.
Long story short: Timing Was Not set properly, and the plugs burnt up on one side.
They reset the timing, and repalced the plugs.
In June of 1997, we got a 200sx( 2 door Sentra, basically).
Not a bad car. But, by end of November 1999( 65K miles...)
went to start the car, and nothing(again)for this model, same as for the 90, but about 58,000 miles later, and right outside of the warranty :mad:
was told timing gear tooth chipped, chain slipped one notch, and messed up the timing. Results: New timing gear, rebuilt the starter, and igniton coil issues, and new spark plugs.
Had issues after that, too. check engine light kept coming on, hesitations in starting. We traded it for a Hyundai in 2001.
Read some reports of continuing engien issue swith Altima and Sentras, still, not too long ago :surprise:
What gives with these continuous engine issues?
Oil leakeage, stalling, not running at all, after 16 + years. Even Hyundai worked out a lot of negative issues in this time frame!
I would like to buy the Altima Coupe, give Nissan another chance, but after reading the recall notices, this forum.... think I'll pass for now.
take care/not offense.
Any help would be appreciated
thanks,
I would think, given the bad PR on this problem, that a buyer would want to see a rebuilt engine in there as a matter of record.
So long as the cylinder walls are just honed, and not bored. The crank could be machined as well, just depends on the cost difference to Nissan I suppose.
I forgot, we're not in the seventies...LOL!!
