Visitor Agreement.
Otherwise, a great car. wish i had the money to buy the 2010...mine is a 2008.
Shut it off by holding down the ODO button while pushing start.
After a sequence of flashes, the reset will be complete and the light will be out.
I have a 2001 Toyota Prius with 49000 miles on it.
Off-late I am seeing the the MIL indicator coming up (& staying on) when I insert the Key and turn it to 'ON' position. However the indicator goes away when I start the engine or drive. Does anybody know what might be wrong? Is this something I should be worried of?
http://john1701a.com/prius/documents/Prius_User-Guide_classic.pdf
As for the manuals, if I was you, I would search for some used ones on amazon.com, ebay.com and craigslist.com, etc. Hope this helps!
mzabovetheinflence@yahoo.com
2010 may be different.
Anybody else have anything to add to this?
See if they will replace it.
Did you roll the dial all the way to the top past the detent?
Or do you have it rolled down towards the bottom?
Normally I have had friends have their display set in day mode so it is too bright at night, but is yours in night mode during the day?
BTW the service manager at my dealer said that this is a common complaint,but the 2010s are a bit brighter.(helps me a lot)
69K miles on Prius 2005. No problems except water pump at 65000.
Went to start car and got error with PS, red triangle do not drive, tow to nearest dealer. Dealer checked and say it is the computer. The computer "went out" and is "shot, I need a new computer and it will be $2000.
I may try another dealer
They say it can happen if you hit a pothole. Gee I thought it was a car.
"recommend replace skid control ECU"
how much did yours cost?
The lights were still on when we got to the dealer, but when they went to work on it both times, the lights are off and they say there is no problem with the car.
Does this sound like a computer issue or a mechanical problem? Should we pursue it with another dealer?
Obviously we are concerned because this is a potentially dangerous situation as we could get hit from behind.
I just read your posting about your 2005 Prius. BRAKE, ABS & VSC lights on dash -
I have a 2005 with the same problem.'It has been to the dealer twice in 7 days. They say they can't figure out the problem.
When this happens i can not power down the vehicle. After a long wait (hours) i can power down but it will not power up.
what was your solution?
It is at the dealer now, any help you an give iw greatly appreciated.
Thank You Very much
Jon
