Isuzu Trooper repair manuals
I'm looking for a 2000 trooper repair manual. The manuals that are readily available are a little too brief for me. I do most of my own wrenching and need a really comprehensive manual. I just purchased the 2000 trooper and it's the first Isuzu I've owned so I'm not very familiar with them.
The vehicle is a little cold natured and runs rough early in the day after just being started, I suppose it needs a tune-up, also the A/C needs a little attention, not quite cold enough, as it cycles there are times when it's blowing warm air. otherwise I'm happy
Can anyone hook me up with a manual recommendation, or web site, or whatever.
Thanks in advance
Thanks in advance
The rough idle at cold might be either a bad EGR (Exhaust Gas Recirculation) Valve which does not fully close, and that lets too much air in while cold. On my 2001 Trooper the EGR valve is known to go bad around 70K miles because the valve was poorly designed (a GM part) and the replacement is supposedly better and should last the life of the engine. Or there could be an intake manifold gasket leak, the intake manifold is built as a heat shield and is a complicated gasket, sometimes they crack.
The not quite cold A/C might be the extra fan in front of the radiator, it was added when Isuzu Trooper began using the new formula freon coolant, some Troopers with the new freon were built without the extra fan. I had a 1995 with the old freon, it was instantly ice cold, even on the hottest days I could not run it on high too long or the family would complain of being cold. Or you could be low on freon.
Opinions will no doubt vary on the quality of the product, but as a stop gap solution, this would be the way to go if you do not want to tear down the vehicle.
A full line auto parts store should have or know where to get these boots. Basically, you remove the old rubber boot and clamps, install the replacement boot kit which has (typically) an overlapping seam that allows installation around the joint and new clamps that keep it closed and in position once it is closed around the joint.
My experience is that the worst part of the installation is the removal of the old clamps that hold the original boot on the axles. You also need to regrease the CV joint while you are in the process of putting the replacement boot on. If you have some mechanical ability and tools, this is not an impossible job. Otherwise, a mechanic,not necessarily a dealer, would be able to do this for you as well.
Here is what alldata says about the original parts and labor time, which might help you decide if you are getting ripped if you go to the dealer:
1999 Isuzu Truck Trooper V6-3.5L
Vehicle Level Transmission and Drivetrain Drive Axles, Bearings and Joints Axle Shaft Assembly Constant Velocity Joint Boot Parts Information
Parts Information
Part OEM Part Price
Front Axle
Boots
Outer Boot Kit 8971172210 $109.45
Inner Boot Kit 8971172200 $109.45
Labor Skill B
Level Mfg.
Warranty Standard
Replace
Front Axle
One Side
One 3.4 hr
Both 3.9 hr
For a dealer under warranty, they were allowed about 4 hours per side and the parts cost to perform the work...so about $440 for parts and 8 hours for the replacement of 4 boots and both axles. Dealer per hour charges vary. The replacement aftermarket boot is definitely cost effective. Look around. One owners opinion!!
https://isuzusource.com/v2/store.php?category=3&visitor=yes
http://www.helminc.com/helm/search_service_owner.asp?Style=&class%5F2=AIM&mscsid- =SF0KT1TKTU5F8MA2L5XRJJVRF4SU8873
Expensive but I saw a site that rents access to info for $20/day.
I just bought '99 Trooper (69,000 mi) in May. I check the oil every tankfull and have an OBD II scanner for piece of mind. Right now have code P0440, which I believe is an indication that the EGR system needs attention. Looking for info on how to R/R.
Carlos
The Power Control Module (PCM) checks the validity of the signals used in the ION Sensing module at the following engine operating conditions.
The Deceleration Fuel Cut Off (DFCO) test is performed to evaluate the Combustion Quality (CQ) signal pulse width if it is below a predetermined value, the value it is expected to be during DFCO conditions. If the CQ signal pulse width is above the predetermined threshold, the fail counter will be incremented. If the failure counter exceeds the calibration, then the test is complete and a failure will be reported.
The Power Enrichment (PE) test is performed to evaluate the Combustion Quality (CQ) signal pulse width if it is below a predetermined value, the value it is expected to be during PE conditions. If the CQ signal pulse width is above the predetermined threshold, the fail counter will be incremented. If the failure counter exceeds the calibration, then the test is complete and a failure will be reported.
The Combustion Quality (CQ) test is performed to check if inappropriate (CQ) signal status were detected. If missing CQ pulses or multiple CQ pulses or CQ pulse width calculation errors were detected, the fail counter will be incremented. If the failure counter exceeds the calibration, then the test is complete and a failure will be reported.
Conditions for setting the DTC
Ignition voltage is between 10 volt and 16 volts .
MAP sensor signal is between 26kPa and 100 kPa .
Fuel level is more than 10% .
Engine speed is between 650 rpm and 6500 rpm .
No Crank DTCs set.
No System voltage DTCs set.
Action Taken When the DTC Sets
The PCM will illuminate the malfunction indicator lamp (MIL) the first time the fault is detected.
The PCM calculates an air flow value based on Idle air Control valve position, throttle position, RPM and barometric pressure.
The PCM will store condition which were present when the DTC was set as Freeze Frame and in the Failure Records data.
Conditions for Clearing the MIL/DTC
The PCM will turn the MIL "OFF " on the third consecutive trip cycle during which the diagnostic has been run and the fault condition is no longer present.
A history DTC P1310 will clear after 40 consecutive trip cycle during which the warm up cycles have occurred without a fault.
DTC P1310 can be cleared using the Tech 2 "Clear Info" function or by disconnecting the PCM battery feed.
Diagnostic Aids
An intermittent may be caused by the following:
Poor connections.
Mis routed harness.
Rubbed through wire insulation.
Broken wire inside the insulation. Check for the following conditions:
Poor connection at PCM - Inspect harness connectors for backed out terminals, improper mating, broken locks, improperly formed or damaged terminals, and poor terminal to wire connection.
Damaged harness - Inspect the wiring harness for damage. If the harness appears to be OK, observe the moving connectors and wiring harnesses related to the sensor.
A change in the display will indicate the location of the fault. If DTC P1310 cannot be duplicated, the information included in the Failure Records data can be useful in determined vehicle mileage since the DTC was last set.
If it is determined that the DTC occurs intermittently, performing the DTC P1310 Diagnostic Chart may isolate the cause of the fault.
Good luck
PS. Do a forum search and I am sure you can find someone else who has changed a starter on your model.
This engine requires a timing belt change every 60,000 miles, and you can find lots of info on that with a forum search. It is a non interference motor, which means it should not be harmed if the belt does break, but who wants to find out the hard way? I would say you could try the spark plugs first as they are easy to do with right tools and least expensive option. The intake gasket replacement is considerably more time and effort.....4 to 5 hours plus cost of gaskets. The intake is a two or three piece, depending on engine. SOHC is easier to do but still time consuming.
Hope this helps, good luck.
Jim
I don't know of any diffs that have a level sensor that would set off the light. If you have later Trooper with SOTF then your front axle actuator may be sticking......
If earlier model, then transfer case sensor.......
IF TOD, then more complicated.............
Jim
The TOD module is inside the vehicle, if memory serves it may be under pass. seat. Check that connectors are still fully inserted there too.
The TOD sensors are an expensive part, so it is not like you want to buy them and replace them until you are sure one or the other is the problem. You will really need a service manual if you get to the point where everything else has been tried.
this is most common place to start. Once done, you can try it and see if it helps.
Hopefully, someone else will chime in to help. I am sure if you do a forum search you will learn more about the system.
He has lots of original parts and manuals, and I have bought many parts from him.
He is great to deal with. Just drop him an email telling him what you are looking for.
Where To Find Your Car Owner's Manual Online
PS> There is another 3.2 Direct Injected engine that is an Interference engine, but I don't think it was available in 97.
BASICALLY, I WANT + NEED A SPLIT BOOT TO FIX THE PROBLEM, ONLY EVERY PLACE TELLS ME "THE BOOTS ONLY COME AS A SOLID PIECE THAT SLIDES OVER THE AXLE, + REQUIRES THE AXLE TO BE OFF THE VEHICLE TO BE REPLACED."
I KNOW THAT atfdmike SAID IN A REPLY THAT THEY DO MAKE A SPLIT BOOT THAT DOESN'T REQUIRE REMOVAL OF THE AXLE.. WHERE DO I FIND 4 OF THESE SO I CAN FIX THE TRUCK WITHOUT BREAKING MY WALLET ???
