Toyota 4Runner Real World MPG
How's your mpg doing? Please give us a report and include any details that will help others compare their mileage to yours (commute, driving style, city/highway mix, mods, etc.).
Drag losses due to wind resistance increase exponentially with speed... double your speed, and air becomes 4 times more resistant.
Actually, the drag force varies with the square of the speed so it is not exponential.
Oh yeah, and the V-6 4WD manual has a curb weight of 3885 pounds. It is more than 10% lighter than the new model from '03 on, which is good for gas mileage.
Like chiefjojo, 23 mpg is about the best I can hope for in an all-highway trip. However, it is very consistent under those circumstances, so it never drops much below 23 either.
Anyway, averaged only 22 mpg overall, not my best work! :-(
(2000 V-6 4WD stick shift)
But, back to the 4runners - I expected to see greater differences b/w newer 6 and 8 cyl. engines, esp. with full time four wheel drive...
This is helpful - I'm thinking of getting one and will use it for occasional boat towing. Need to do much more research. Thx.
My '06 gets about 19+mpg mixed city/highway and have gotten as high as 24.5 highway. Mind you that was doing 65mph for 400 some miles.
They are great vehicles.........
Regardless, I think you'd be happy with a 4Runner. My negatives are road noise, rough ride, wind buffeting, and the HVAC controls. The Sport models, the airbag suspension equipped Limited models, and any of the V8 models ride better IMO. For 2006, Toyota put thicker windshield glass, and rumor has it, thicker front row door glass in all the vehicles to help reduce road noise.
BTW, I got my hands on a Tahoe and Yukon today while looking to replace my 4Runner. They sure don't seem any larger in the cargo area than my 4Runner, and they all come equipped with a useless third row that has permanent seat rails mounted above the floor surface whether you want a 3rd row or not.
But I was driving faster than I usually do in stretches - this thing can really gulp down the gas if I push it to 75 mph on the uphill portions. After that, all the downhill coasting in the world can't pull the average back up enough! :-P
(2000 4x4 V-6 stick shift).
Anyway, point here is that the total mileage for the day was 262, and I put in 12.4 gallons of gas, which is still about 21 mpg, which I thought was pretty good given all the four-wheeling.
I have not verified it yet with my GPS but the Camry's odometer is off (low) by 1.5%. It's probable that the 4Runner may be as well and if so then the manual calculations on you FE may yield a lower result than actual (by about 0.3mpg on a 300 mile tank).
I was holding the speed to the limit and driving conservatively except when I needed to pass, and it seems to have paid off. That might be my best mpg to date. :-)
(2000 V-6 4WD 5-speed)
I'm currently running Michelin CrossTerrains. I have noticed that my mileage goes down ~1 mpg when I put on my snow tires in the winter.
Anyway, total was 273 miles, 11.9 gallons, which is 23 mpg. Not too bad, especially considering the temperature was below freezing the whole time, sometimes 30 or more degrees below. First time I have ever been in temps cold enough to experience the power steering system unwilling to do its job because of the cold (I've seen it mentioned in the owner's manual, but never witnessed it firsthand).
2000 V-6 4WD stick shift.
1. Warm up for 30 seconds, even in the coldest weather. I drive gently to warm up the vehicle.
2. Keep 70 mph as max speed on highways. Trucks are not meant to go much faster. The aerodynamics are parachute-like.
3. Use cruise control a lot and maintain steady speed when not using it.
4. Don't lead foot it unless necessary or I feel like it.
An acquantance swears that replacing the exhaust system with larger pipes would not cost much and result in higher MPG's. What do you think? Anyone try this?
I'm considering buying a V6 "07 because the back window rolls down to provide cross venting for my dogs and would sure like to get the mileage up to 20 combined!
thanks...
So she just sold the car. :P
Check out the K&N Air Filters, bolt-on power? discussion - opinions are all over the map, but actual data seems scarce.
Actually, it increases quadratically but your conclusion is correct.
Unless I can figure out how to drive like
pmschneidau - very impressive! However, I drive on Texas roads - and cld get shot for going less that 70 on the freeways!
I mainly want to use this feature for quick stops when I'll turn the engine off, and leave the windows down.
im confused...any correct answers. thanks in advance
Dave
I agree about the Tahoe. The cargo space floor is too high and those rails are intrusive.
The 4 Runner seems the way to go, with its good tow weight numbers. Of course most of the time is spent NOT TOWING, so the real world MPG numbers are important.
Kip
