Mainstream Large Sedans Comparison
134689134
  • averigejoeaverigejoe Member Posts: 559
    An all aluminum motor nowadays means one which has an aluminum block and aluminum heads (and probably aluminum intake manifold too).
    It does not mean that every ounce of metal in the motor is aluminum.
    The valves and springs, piston rings, crankshaft and camshaft, gears, sparkplugs, threaded fasteners, etc. are going to be steel, not aluminum.
  • quietproquietpro Member Posts: 702
    Yep...I was just being funny...or so I thought. :)
    Regarding DOD's effectiveness, I've played around with it on my SS. Of course I didn't have any instruments to help me but it seemed I could hold a max of 65 mph on flat terrain with no head wind and DOD engaged. Behind large trucks or groups of cars, I could sometimes manage a little faster but it was understandably inconsistent. Where DOD probably makes its biggest difference is in my mixed commute. In those instances, once acceleration is accomplished, I can cruise the majority of the trip in 4 cylinder mode. Is it worth it? Probably gives me an extra few miles per gallon. Fleet wide, it reduces consumption and in times like these, every little bit helps.
  • martin22martin22 Member Posts: 53
    Oh dear, Captain, Lucas electrics was practically all we had at the time but mostly they worked OK. Just had to keep the plugs and points clean and change the occasional fuel pump.
    Now, I must respectfully disagree with you on the question of power vs torque which provides acceleration. It's been a long time since I was at college so, unashamedly, I googled for a good definition of Newton's second law of motion and came up with this:
    "Newton's second law of motion explains how an object will change velocity if it is pushed or pulled upon.
    "Firstly, this law states that if you do place a force on an object, it will accelerate, i.e., change its velocity, and it will change its velocity in the direction of the force.
    "Secondly, this acceleration is directly proportional to the force. For example, if you are pushing on an object, causing it to accelerate, and then you push, say, three times harder, the acceleration will be three times greater.
    "Thirdly, this acceleration is inversely proportional to the mass of the object. For example, if you are pushing equally on two objects, and one of the objects has five times more mass than the other, it will accelerate at one fifth the acceleration of the other."
    There you have it - the force we have is called torque - a twisting force {lb ft, by the way - not ft lb}. For comparing car against car, one should consider the torque at the driving wheels (to compensate for gearing differences) and of course the car's weight.
    Power, on the other hand, is an entirely different animal, defined as work (ft lb) over time. (You may recall 1 HP = 550 ft lbs/sec) Power is basically what a vehicle needs to acquire energy, both kinetic and potential, and overcome air resistance which will ultimately determine its top speed.
    For sure, torque and HP are related in the sense that a big engine will give you lots of both. However, it is torque that gives you the acceleration and personally, I like to get it in the low rev. range say between 2-3000.
  • plektoplekto Member Posts: 3,738
    Amen to that. :)
    Not having to downshift is a big plus. Today I was riding with my father - they were buying a new LCD computer monitor and wanted my input. Fair enough. He has a 2000 LeSabre, which is exactly the type of engine/car we were discussing.
    Twice he had to move quickly, and while it did, there was a noticeable "thunk" as it downshifted and revved to 4000rppm. After a full second delay or so since he isn't in the habit of stomping on it to get it to respond. It was very much NOT refined and once it actually was a bit jarring like a big turbo kicking in.
    This sort of behavior is what I personally detest. In a small car, you can get around it with a manual transmission and/or a good power to weight ratio and tightly spaced egars. But in the Avalon and GMs with the 3.8L engines - I figure for that much car, it should be at least somewhat refined. This lurching up to speed is purely a matter of gearing. Any jump from 1500-1200rpm to twice that will result in this, no matter what engine it is.
    The V8 - no such jarring. Plenty of oomph at low rpms to make a modest speed change without it panicking and going into a lower gear... or two in the case of the Avalon when stomped hard in city traffic. The Avalon should be better and more driveable, but the darn transmission tries to be smarter than you. So instead of getting a 5-4 and get up to speed decently well, it does a 5-3 downshift and you're back in GM-ville.
    Gimmie a small V8 every time. (though the Lucerne CXS *could* stand to shed about 400-500lbs)
  • captain2captain2 Member Posts: 3,971
    if this were true - then why are not the best cars out on the roads (in terms of acceleration) not things like diesels? How about because that they don't develop that power, work over time as we agree, nearly as quickly as a gasoline engine? An admittedly extreme comparison, but the the same "laws" apply. But, of course, the larger the engine the more HP and torque, all else being equal, and usually at the expense of fuel consumption.
    And yes, we could take all the cars in this group, divide curb weight by HP and come up with a close order of finish 0-60, 30-50, quarter mile or whatever. IMO and based on road tests I've seen - 300C, Impala SS, Avalon, Maxima, Lucerne V8, Azera, 300/Charger 3.5, Impala LT, Kia, Five Hundred, Lucerne 3.8. Interestingly, doing the same on the basis of torque/lb., the results are close to identical, except for a notable exception - the 3.8 Lucerne which by the torque is 'king' rule should do better? And then you can do the same sort of thing with FE, and come up with almost a reverse order of finish EXCEPT for the Avalon and Maxima which DO end up at or near the top of both lists.
    Memories - As a former owner of several Healeys, Sunbeams, TRs, a Morgan - Lucas (6V positive ground notwithstanding) was fine until it looked like rain! Couldn't afford a Jag at the time - the XKE one of the most beautiful cars of all time!
    pletko, sounds to me like you really should go out and look at the new Maxima CVT, not only will you save a few MPG, but, you will feel even less of that 'annoying' shifting
    Yes, I personally love CVTs IF they are proper CVTs. This whole artificial "stepping" nonsense is right out. (Mini and several others use this to mimic an automitic and guess what - it DOES mimic an automatic - it turns the driving behavior into one. Duh move, I say.
    The problem with torquey engines is that they run out of gears. But they are quick to get up to speed, that's for sure. OTOH, who really *needs" to go faster than about 90mph? Now, a 6-speed automatic with super tight gearing and a big V8... oh yeah - now we're talking :)
  • louisweilouiswei Member Posts: 3,715
    Why not a 6-speed auto tranny with super tight gearing and a very efficient V6? Many V6s today are able to produce V8-like power and theoretically speaking would give you better MPG.
    I think Mercedes has some 7-speed automatics out now.
    actually I guess the jury is still out on CVTs however - historically limited to lower HP/torque applications, and just now beginning to appear in 250hp (or ft/lb.) vehicles. The Murano one I can think of where it has not been causing any problems TMK - as opposed to many of these newer electronically controlled 5 speed+ (some new Lexus' have 8!)trannies. Don't know of any V8s currently available with CVTs, maybe a little too much power for them at least right now.
    Lexus has the 8-speed auto tranny on its new LS460.
    this more is better stuff may not be always good. Just read a review of a SL550 7 speed, a 100 grand car that has a transmission that apparently jumps all over the place. A number of these multiple gear computer controlled trannies do not operate as seamlessly as their 4 (or 5) speed predecessors. And while it seems logical and more economical to always keep an engine at a most efficient speed relative to load, think the jury is still out on these multiple gear electronic trannies as well, not to mention what I perceive repair cost differences.
    It's all the transmissions. Tall gearing means you need huge displacement and a ruler-flat torque curve to deal with it.
    GM and Toyota are odd in that it has mile-high gears and a high-revving V6(all the power is up at the top end). They need fewer gears if they are that tall. In fact, my old Buick with the Gm 4 speed automatic worked 100% better if I manually locked out overdrive and ran it around town as a 3-speed. 200% better if I manually shifted it between 2nd and 3rd around town. :)
    The Lucerne has enough torque to make use of the tall gears, so it's a good match. Toyota - their gearing is still silly high - it's almost as if they just added a second overdrive gear on their old 4 speed.
    BTW - this is why Volvo and BMW had such a good reputation for sporty sedans for so long - they match their engines up with gearing that's purely made for performance. Revs quickly, has gearing to perfectly match - and enough gears to make use of it. All for a couple MPG loss. Well worth it, IMO.
    I don't think you had a chance to test out the new Toyota 6 speed with the 2GR. I don't know about the one on Camry but the ones one Avalon and IS350 definitely rev very quick and have a very peppy feeling with it.
    Sure, the 6 speed fixes the 5-speed's gearing, but honestly, - the number of problems the mega-speed transmissions are having and the insane $3500 cost to fix them... That extra $1500-$2000 for the transmission repair over the GM V8 buys a lot of gas.(not to mention the cars have terrible finincing options and cost a fortune, even used).
    Let's say 5mpg better economy out of the Lexus. 12K a year. $3 a gallon for gas(to keep the math simple)
    60K miles in the Lucerne(20mpg avg)=3000 gal/$9000 in gas.
    60K miles in the Avalon(25mpg avg)=2400gal/$7200 in gas.
    Hey - guess what - exactly what you pay extra for the transmission in the Toyota. :lemon:
    Except... $3500 is enough to crash anyone's budget. It's really hard to absorb compared to $1500-1800. That's why the mega-speed transmissions make such news. It's a really expensive repair that's a significant chunk of the car's entire value. And the look of a $3500 repair bill on a customer's face - It's a look that you see many first-time Mercedes and BMW owners have at the repair shop. They start wondering if they made the right choice. The next time they go shopping, that silly price they paid for the transmission is first in their mind - so they look harder at the completition. Unless they are made of mney, that is - but those types usually buy a Mercedes or BMW right off.
  • barnstormer64barnstormer64 Member Posts: 1,106
    That's why the CVT (which you can get on the Five Hundred .. easiest way to ensure that is to get the AWD version) is so nice.
  • havalongavalonhavalongavalon Member Posts: 460
    Let's say... (you said):
    Hey, plekto -- do you realize this is a classic example of false economy?
    First, your $1,800 represents annual recurring savings, so you will save another $1,800 (or more, if cost of gas goes up and up) every year of ownership. On the other hand, your transmission "savings" is a one-time event (if at all).
    Second, there is no history of Avalon's 5-speed transmission needing repairs; but let's suppose my Avalon transmission will fail some day. For about $1K I bought the 7-year extended warranty that will cover this repair (at Zero cost to me) and will cover as well the many fairly common things that can fail, such as sensors, electronic this or that, or power this or that -- the typical, and expensive, failure issues of any recent model cars.
    So for me, having spent what the Avalon was worth, plus $1K for the 7-year warranty, represents a recurrent savings of $1,800 per year and peace of mind for 7 years of ownership. Optionally, if I want to sell my Avalon before the 7 years are up I can count on its deservedly higher market value, since the extended warranty is transferrable.
    By the way, I have owned my 2005 Avalon XLS for over 1 1/2 years and driven over 32,000 km so far, and I have spent $0.00 in anything beyond gas -- my first 4 lube & oil service calls were free with the extended warranty package.
    I think I'm not alone in buying into this car investment model. It's worked very well for me in owning 3 Toyotas since 1987, and it seems to work well for greatly increasing numbers of Toyota owners, worldwide.
    Let's see... $1,800 x 7 years = $12,600 in savings... Hmm...
    to assume that a transmission must be replaced within 60k miles or even 150k miles - if that is what you expect out of a car you shouldn't buy it in the first place. And yes I've owned several 'japanese' sedans and never had to replace a tranny, 2 out of the my last three Suburbans did need $1200.00 rebuilds before 100k.
    As far as those 'old fashioned' GM trannies, you had better get them while they're hot anyway - given FE and safety system requirements in place with our erstwhile government, they too will soon be replaced by these more expensive to repair electronic ones. Besides which, the consumer seems to want these 5, 6, or 7 speeds, even if they are not really needed!
    Never heard anybody try to justify real fuel savings against assummed repairs, especially with something like a Toyota - kind of amusing...
    source: Intellichoice.
    5 year Cost of ownership 06 Avalon Ltd - $37680.00, excellent rating
    5 year Cost of Ownership 06 Lucerne CXS - $48584.00, poor rating.
    Cost of ownership includes depreciation, money costs, insurance, repair estimates and fuel usage.
    The only car from this group that is cheaper to own out of this group, the Impala LT! The Azera would seem to be a real candidate for a low number as well - too new for actual statistics
    You can certainly choose not to believe any of this, but 11 grand sure seems like a lot of money to me! Also 'discovered' the Northstar requires premium (?), turns right at 1850 rpm at 70 (the Avalon 200 rpm more), and road test mpg (C&D) was 15 mpg as opposed to the Avalon's 23 - although I personally don't believe that the Avalon really gets 8 mpg more - probably closer to 5 (away from the test tracks).
  • badgerfanbadgerfan Member Posts: 1,565
    I don't own either of these vehicles and never will, but I do recognize bad math on your part. The $1800 in projected gas savings by plekto is for 60,000 miles. So this would only occur in one year if you drove 60,000 miles in one year. Not very likely if you are an average driver. More like 10-12K miles per year, so the savings is much less on an annual basis.
    Ooops -- thanks, badgerfan. I should have noticed that plekto started assuming 12K miles a year, but then did his/her calculation for 60K miles. Yes, the annual savings from gas is much less -- at today's gas prices, anyway.
    louis - don't think that the 6 speed in the ES or Camry has an appreciable difference in top gear ratio - meaning that rpm/mph is likely the same 5 speed or 6 speed in top gear. The reason - rated mpg (22/31) is the same. The 6 speed will simply have gears ratios closer together. The Avalon turns a little over 2000 rpm at 70, anybody out there with a Camry V6 3.5 or ES350 tell us what engine speed is at 70?
    'Silly high' IMO, way way off-base, that treasured V8 is only about 200 rpm less at the same speed!
  • oilcan2oilcan2 Member Posts: 120
    The new transmissions in the 05,06 Avalons and the new Camrys are mostly still under warr. so where are you getting this $3500 ? I am not a trans mechanic but if you have your trans fluid 100% changed once a year and/or use
    synthetic fluid I would bet most of these trans problems would stop.
    Unless your credit rating is 800+ you will never get the advertised 0%.
  • reject1reject1 Member Posts: 3
    Can someone post how Intellichoice determines the selling prices of the cars when new and at resale?
    If MSRP is used as the assumed new car sale price of both cars, but huge discounts from MSRP are only available on the Lucerne, the resale percentages would be way off, favoring the Avalon.
    $3500 is what it costs to replace a Camry 5-speed automatic at the local dealership in Pasadena, CA. The guy in there had a 4 year old Camry and was astounded by the repair bill.
    It isn't the Lucerne - it's nearly 20 GM cars with that 4-speed in them. It's no problem to find a shop to swap out the torque converter and get you on the road for $1500 or so by comparison. I used the Lucerne since it has the most thirsty non-Cadillac engine that uses the 4-speed transmission. A fairer comparison would be to use a LaCrosse. Nearly identical MPG as the Camry or Avalon.
    I surely don't want to pay up to $2K more for a new transmission. $1500 is nearly impossible to afford as it is when it happens.
    don't know thw answer to that and a point well taken, Buick sticker prices, in particular, inflated relative to drive out. Keep in mind though that any money taken off the purchase price also effects the resale immediately and down the road. If, for example, the $35k sticker Buick is actually sold at $30k (below 'invoice'), but the $35k Toyota is actually sold at $32k ('invoice'), there is $2000.00 of cost there that over time should be considered in overall costs, not only the principal but also in the cost of financing that money over time... Could reduce that difference a few grand.
  • imidazol97imidazol97 Member Posts: 27,740
    But you really need to compare drive-off-the-lot prices. The Buick may have some rebates and dealer discount.
    The Toyota dealer in this area is like to have added $1000 in pack, mudflaps, windwhield polish, etc., and add on hundreds in dealer fees after the negotiated price on the way out the door, well, just because he 'can.'
    yep, 'Detroit' sticker prices are generally 'designed' with a significant discount/rebate in mind - the Buick buyer anticipates 'something good', the 'Japanese' brand buyer will usually understand that those prices really are negotiated off sticker (or from 'invoice'). Buying an Avalon at invoice (10% or so discount) is a good price, buying a Buick at the same would be a rip-off.
    Those overpriced 'option packages' that you are talking about BTW, are generally from the distributor in Toyota's case, not the dealer - and you are right - it is because they CAN. If the 'Detroit' mfgrs. COULD, they might even be making some money!
    A friend just bought a Toyo from this dealer. I had walked his lot. The Corollas had one dealer pack on them and the Camry had a double-cost dealer pack on them for dealer installed options on a separate Maroney sticker. It was a dealer sticker.
    She still hasn't hinted how much extra they added on after that. She doesn't like to negotiate, didn't want to take her daughter or me to help.
    I believe the pricing GM uses is with discount by dealer or rebates in mind. It helps the image, at least it's needed until the blush or halo finally wilts off the foreign, Accord and Camry types, where people believe they are the only perfect car ( and that's finally in question--read the discussions of problems here).
    there is no doubt, at least right now, that the quality/reliability gap has closed between the Japanese and American brands - largely because a very good portion of what 'Detroit' is selling (old technology - the 3.8, the 3.0DT, the small block V8s, the 4 speed trannies etc.) are about as perfected as they can be after that many years. And it won't stay that way, as Detroit 'catches up', the GM 3.6/3.9 V6s, the Chrysler/Fords 3.5s, 5 and 6 speed trannies etc.). Expect 'Detroit' reliability to take a hit in the near future because of new product intros, much in the same way that 'Japan, Inc.' has to some degree. There is a lot of truth to the old adage 'don't buy a car in its first year' and even the Toyotas/Nissans/Hondas of the world are not exempt from that.
    As the US big 3 continue to close plants and move production to wherever, it will be interesting to see if the American car buyer begins to understand that the most 'American' cars probably have foreign names!
    strikes me that your friend probably wouldn't want you to negotiate in her behalf anyway - they might have had to call security! ;) Toyota dealers with sometimes haughty attitudes and dealing with someone used to 'Detroit' style' discounts probably not going to give you the time of day! Toyota's attitude lately seems to be more like 'let me do you a favor and sell you this car' - at least from my own experiences...
    Sad, but true I afraid, and the funny part is that they continue to sell more and more every month!
    The mindset of some, some people is that they are perfect and are the 'best' car to buy. They don't realize they pay more to begin with, pay more at the services, and get a little more if they do trade in. Whether that's worth it to me is for me to decide, but lots of people buy based on media image and others sources of image. I read Edmunds so I believe regression to the mean is occurring. (Save the flame posts.)
    That's the experience I had the one time I was on a Toyota lot. Sorry, but they couldn't convince me that their car was worth more than a Ford. Yes, their resale would be higher after 10 years . . but not by more than the extra they were charging up front. When you present value out the differnce, buying the less expensive car makes more sense. (Bearing in mind that in MY experience, the Toyotas/Hondas haven't had any better reliability than the Ford products I've owned).
    To be fair, I think we ALL do. Some more than others, though, I suppose.
    But it's our PERCEPTION of the "image" that differs.
    and understand that car salespeople are paid based on commissions and/or volume incentives. As such, they would naturally NOT spend a whole lot of time on a 'hard sell' when the alternative is the other 10 guys in the showroom who really want the product. And this would apply to any sales person selling anything, it is human nature and better for his pocketbook. To be fair, however, and not excusing what I do consider to be usually 'difficult' salespeople - the fact, is if Ford (in your case) had a car that was in the same sort of demand as the Avalon is, the Ford would treat you the same way for the same reasons!
  • windycity7windycity7 Member Posts: 24
    toyota is having a lot of problems with their 2006 camry and avalon. they are riding on reputation. you should look at Hyundai Azera - chosen by JDPower as one of the best. i test drove the Avalon, ES330, and the Azera was hands down the winner. i don't want nav so it was never an issue. and saved $4K over the Avalon!
  • hardhawkhardhawk Member Posts: 702
    The Azera is a fabulous bargain. I will look at it hard before my next purchase. The Avalon is nice too, but not so much nicer to justify the price difference, especially with the rebate the Azera has. The Toyota top US guy was at Chicago for the Tundra premier and said that Toyota's biggest concern was Hyundi, soon to be followed by the emerging Chinese. Never did he mention the big 3.
  • floridabob1floridabob1 Member Posts: 1,190
    The Azera is a good car, but if you trade often I believe that you can get hurt with the resale or trade in value.
  • rpfingstenrpfingsten Member Posts: 154
    Jean&waldo
    Hi there.. glad to hear you like your Lucerne.. I was in the car market just 2 months ago and like others here, I test drove the Lucerne and then the Avalon and I have to tell you in all honesty, it was a tough decision for me but I ended up with the 07 Avalon. and am now happy that I did..I will admit to you that I think the Buick has a "softer" ride. As far as styling goes, I thought they were about the same, but when it came to comparing specs, that's another story.. first of all the avy comes standard with a 268 hp engine.. you have to pay extra to get the 275 hp northstar.. also, I traded in a cadillac with that northstar engine when I bought my avy, and the reason I was trading it in was because that engine gave me alot of trouble. In fact, at the time I traded it in I had to because the cadillac dealership told me I was getting antifreeze in the cylinders and it would cost me about 3 grand or more to fix it. So while I enjoyed the rush of the power the northstar provided, my previous experience with it told me no thanks. Interior wise, no comparison, in my opinion, the avy interior is much nicer. Not to mention the avy gets superior gas mileage..and theres that Toyota reputation for dependibility that GM products just don't share yet. Just my thoughts on the subject.. good luck with your buick though.. hope you have years of good service from it.
    Roland
    Average auction price from Manheim last week on 06 Azera Limited with aprox. 12,000 miles was 20,600.00.
  • janeandwaldojaneandwaldo Member Posts: 6
    Hey thanks for the message Roland. Always nice to hear someone talk nice instead of flaming. I hope we don't have the same problems with the Northstar but I tell you I do love that rush of power. I did opt to spend the extra money and got the 6 year 90,000 mile warranty and I am sure we will run the mileage before the 6 years. We already have close to 20,000 on it since February and knock on wood not even an inkling of a problem with anything yet.
    I am glad you like the Avalon I am just really partial to American cars and it probably shows but I just will not buy a foreign car and put Americans out of work. I know they are probably made i nthe US now for the most part but either or.
    Also if you look at Reliability ratings I think it was JD Power rate Buick higher than Toyota as far as Reliability. But when you start getting into the reliability realm of Toyotas and Buicks it is really probably 6 of one half a dozen of the other.
    I had 212,000 miles on a 91 leSabre when I got rid of it and I have 170,000 on my 97 right now and never any major issues with either one.
    My 91 I had to do a valve cover gasket a fron axle and an alternator in the time i owned it.
    my 97 I had to do an intake gasket, an alternator and the ignition has been issue a couple times.
    So with those few problems in that amount of mileage I will take it.
    Anyway good luck and thanks for the input
    Walter
  • bobwileybobwiley Member Posts: 241
    Walter: My final 2 choices were the Avalon Limited, which I bought and the Lucerne CXL w/Northstar. My biggest issue with the Lucerne was 1st year reliability. I was impressed with fit and finish, room, very quiet and good looking. I checked over 10 Lucerne's back in January and the attention to detail was impressive. I've since learned that they've experienced some quality control problems. I've previously had 3 new Buick's and they were great. I just felt, $$$$ 4 $$$$ and since the price for each car was comparable, the Avalon got better mileage--even better than the Buick V6 and the resale value was much better. When US automakers wake up--they've been "bashed & battered" by the Japanese for over 30 years--and they build cars that rival the long term reliability and reputation of the Japanese cars--Americans will buy them. If I managed Cadillac or Lincoln manufacturing operations I'd want to know why the greatest nation on earth can't build a Lexus quality luxury car. Its a sad state of affairs when the 1st name people think of in terms of a luxury car is Lexus--not a Cadillac, Lincoln or even a Mercedes-Benz. I can remember when a Mercedes was the automobile standard. The Complacency and the apathy of US car buyers in the 70's----we just bought whatever GM, Ford or Chrysler told us to buy---is gone--people want quality for the $$$ they spend. I WANT to buy American----I'm retired Air Force----the challenge---- Detroit PLEASE build a $20,000-$35,000 sedan that equals the Camry, Accord or Avalon. Not just initial quality--but one that earns a reputation for years of trouble-free service. I also say that Toyota and other Japanese car makers better watchout for Hyundai and Kia---they're like Toyota was 20-25 years ago--THEY LISTEN to what their customers say and strive for a better car each year! Mmmmmmmmmmmmm ya listening Detroit? Its a shame we're closing plants in the US---don't blame the buying public--blame Detroit.
    Bob
    Walter.. thanks for the kind words...for the most part these forums are pretty good, but every once in awhile you can tell theres a tone of bickering... sort of like "my car is better than yours ". The way I see it is I bought what I wanted and You bought what you wanted... and I sincerely hope we are both happy with our decisions... Like I said in my first post..my decision between the lucerne and the avalon was a tough one for me to make... In fact the weekend I decided to buy the car, My wife and I went to the local buick dealership and drove the Lucerne again... after we got back to the dealership and "got away from the salesman" for a few minutes to talk, my wife said to me, you're going to buy the Lucerne, I can tell... I was so impressed with the car that I was that close to closing the deal..the pros on the buick greatly outweighed the cons as far as I was concernced.. but 30 minutes later I test drove the avalon and it just impressed me more than the Lucerne..but like I said... i was "that close" to driving home the lucerne... as far as you having problems with the northstar.. you should be fine. That engine has been out a number of years now and they've worked the bugs out of it.. Remember my northstar was on a 96 model.. so even though it went to hell in a handbasket on me, it still provided me with pretty much trouble free service for nearly a decade... hard to complain about that... and yes, like you, I loved stepping down on that accelerator and filling the power the northstar provided...Fortunately my little V-6 in my Avalon provides me with almost the same amount of horsepower as your big 8 ( hahahaha,, my engine is better than yours ) JUST KIDDING. Actually I thought the cars were pretty evenly matched with a few exceptions so in my case it really comes down to a matter of personal preference...again, hope you get years and years of good service from your buick. Enjoy your Lucerne my friend.
    Roland
    Just get a 1-2 year old Lucerne CXS(Northstar plus Caddy suspension) or a 1-2 year old CTS with the V8 if you want RWD.
    20K and way better for that money than any import. So what if it's a year or two old? Let some other fool eat the initial depreciation.
  • alexstorealexstore Member Posts: 264
    Its funny, how some are bashing US cars. Almost every foreign car like Camry, Avalon, accord and Maxima are now US built. Toyota ( japanese company) is actually suffering the most as reliability fell across the board for them for US and Japanese made Toyota cars.
    Just read Toyota forums and you can see they now have more issues than Buick or Caddy.
    I drove buick for many years and now still have it as my second car. it still rides and knock on wood its supercharger still works trouble free after 12 years. I have maxima, but Buick Park avenue Ultra has almost same power and with GT suspension, it holds car flat on any turn.
  • nimiminimimi Member Posts: 249
    I wouldn't waste time looking for a 2 year old Lucerne - they weren't made prior to 2006.
    Heh. You know what I mean. Wait until next fall or get something that's a year+ old.
    But the real gem is the CTS with the 3.6 engine and stickshift. Low price since it isn't the loaded V8 CTS-V model, yet it has the sporty suspension. Like a Lucerne CXS but in a LaCrosse sized package.
    18K is quite easy to find. Way better than any new Sentra or Civic. It's a solid, serious car built to compete with the C class and Lexus GS - so bit better brakes, bit bigger engine, bit better seats... than a Civic or simmilar.
    Plus, even the cheapest Caddy cruises down the highway like a dream.
    People who have a bad image of GM need to look again at their upper-end offerings - a year or two old. Fantastic deals by then.
    You meant Lexus IS. The GS is in the same category as the E-class and STS.
    your inference seems to be that Toyota is having more problems because they are US built - an assumption I think is wrong. Toyota has been building the Camry in Ky. for 15 years now - would you have said the same thing about a '96 Camry?
    Think Toyota's problems are really functions of 2 things:
    1) Keeping up with demand - they are having difficulties finding enough qualified help at the factories and,
    2) New technologies - Toyotas are full of it, the Avalon engine/tranny a good example. Anything that is new and also complicated will by definition be more troublesome, Toyota brand or not.
    Which, brings us back to the "American" manufacturers that have almost exactly the opposite problem - overcapacity, more time than they really need to build a car and almost non-existent with new technologies. There should be a whole lot less problems with that Lucerne let's say that relies on an engine that dates back to the 50s combined with a tranny not quite that old.
