Chrysler Pacifica NAV System Questions
This is the place to discuss navigation questions for the Pacifica.
Kevin
I am using a pocket pc with a bluetooth GPS..It work great.
go to http://www.bensbargains.net search for Dell Axim X50v it has a very very good deal. ONLY $400 dollars for all the stuff that you need to start. I pay double when i buy it. Let me know, If you have any question
We opted for the Garmin StreetPilot 2720, their top-of-the-line automotive unit. It appears to actually have more features than the factory job and of course, is transportable from car to car. Retail is nearly $1200 but can be purchased new from reliable eBay stores for around $825. You can read the specs at http://www.garmin.com/products/sp2720/"
After looking at many different cars over the past few months I finally purchased a 2006 signature edition most almost everything. This forum gave me alot of insight into the vehicle before the purchase; thanks!!!!!!
My question concerns the nav system; when I entered address into the address book it puts them in the "in-motion" folder instead of asking for the correct folder. Has anyone else experienced this problem or offer some assistance. I am sure the is an operator error problem.
Thanks in advance.
Pac.
Over here we are pretty limited in what we can get unless you order from the factory and want to wait 9 months or more. So, I decided on a Butane Blue FWD Touring. I should be getting it in about 3 weeks.
My question is, its coming with the Navigation system and
Chrysler states that they won't claim that the system will
work outside the CONUS 48 states.
Has anyone ever modified, changed chip, replaced the
Nav system so that it will work in Europe?
I'm thinking that it should just be a chip mod in the
DVD system (to make Region free). But thats why I'm
asking!! :P
Thanks in advance!!
start!!
I'll keep everyone posted.
Best regards
Markus
1.) I own a 2004 Chrysler Pacifca AWD equipped with a navigation system. The problem is that I live in Germany and that the navigation system does only know where to go in the United States (because of the US navigation-disc), but not in Germany. Does anybody know if I can get a german navigation disk for the navigation system? I know, I can buy one at my Chrsyler Dealer, but the problem then is, that the german disk is region code 2 (for Germany) and not 1 for the US. So it will not work in my navigation system. So, what can I do? Is it possible to make the navigation system region free??? I have heard that it should also not be possible to run a region free CD-R copy of the german disc. Do you know if this is right?
2.) My Pacifica is also loaded with the six-disc in-dash DVD-Changer. This DVD-Changer is also region code 1. To watch german DVD`s I need to make it also region free. Does anybody know how to make the changer region free??
Thanks for your postings.
Best regards
Markus
I've been told that if you take it too a European Chrysler
dealer that they can "modify" the system so that it works.
Probably something like changing a microchip and such. But
it is not known that if you do return to the states with it,
that this process is reversible. I'm not so sure that I
want to go that route.
check my earlier entry and there is some info on how
to contact Alpine Navagation. Feel free to give it a
try. If you do get some info from them, please pass it
onto me??!!
Alpine Electronics
2710 Hills Tech Ct.
Farmington Hills, MI 48331
Attn: Daimler Chrysler Navigation Unit
011-248-489-9440
or
1-800-421-2284
Hope to hear back from you.
Kevin
I finally got ahold of Alpine last night and they basically said that the US Spec Nav unit will NOT work in Europe and
they DO NOT have a software disk (European disk/NTSC format)
to offer. So I guess I'm stuck either modifying
the US Nav system, or replacing it with a European model
all together!! :confuse:
If anybody has anything to add...PLEASE DO!!
I wonder if it will include additional detail or more accurate detail as to your exact location?
I tried to make a backup copy of my disk just in case the original wears out (yes...they do go bad from heat, age, vibrations, etc.). This way, I could store the backup in the car in case the original failed for any reason.
The file was too large to replicate using MS Media Player.
Now...if it wears out or becomes defective, I have to spend $150 for the updated version.
so...if you bought one...please speak up.
thanks!
I'm trying to get 'AE' myself through the dealer network (getting anything through the border is a very expensive hassle) but so far Chrysler Canada hasn't a SKU for anything past 'AD'.
Thanks for the tip. I live in Jersey too and find the detail to be woefully inadequate. They don't even show the street you are driving on unless you zoom down to 1/8 mile.
So...how much was it and was it worth the money??? How did you order it??
Many thanks!
Vic
That's a fortune just get a few more colors!! Wow...I was expecting much less.
Sure could use a Plan "B" on this one.
Vic
You 'point' at a location with the arrow keys to position the cursor then hit ENTER to prompt it to ask you what to do with that location. One option is to add it to the address book along with an optional phone number.
Kay in ARkansas
wcz@comcast.net
If you need a Nav system to find your home from 100ft away you have BIG problems.
My navigation system is working... will it continue to or is it something the dealer might have payed up for the month? Also, the CD- the previous owner took it, I guess... the only thing I found was the empty case.
If you all could give me a basic intro on the whole thing... any tips- that would be great!!
The DVD case is empty because the disk is being used in the GPS Navigation System located in the rear compartment of the vehicle. The disk is needed to operate your nav. system. If your nav is operating then don't worry about an empty case. GPS Navigation is a free service to all GPS users and you will NEVER be charged for the service. The only OPTIONAL cost would be if you ever wanted to buy an updated DVD disk with more current information such as new streets and services since your model year 2005.
I wonder if anyone burns a DVD backup of the disk in case it goes bad??? The 10 meg file is too large for a CD.
It might be worth it to get the new disk. Boston's "big dig" tunnel system is not shown as complete on our 2006 disk. We did a needless detour until I figured it out that the thing doesn't know the major interstates now connect correctly.
I am going to try and hook my NUVI to the Pacifica screen via GVN-52 connection
My question is this: Can you set the system to find the quickest route (time) or shortest route (miles)?
I am getting some crazy directions from this thing when I test it to certain known places.
Misty
buying the dvd from navteq will cost 200.00
if you want the update consider the following. there isn't much more on the ae disc then the ac disc. you should know the ac & ae difference if yo've been reading this thread
Were you successfully hooking up your NUVI to the Pacifica screen via GVN-52? I am very curious to know..
Have they done much updating with the 033AE version? Don't want to pay $200 for the same old data. :confuse:
It's a 2005 with an Alpine unit I believe.
