Jeep Cherokee XJ Mods
Hi everyone,
Im new here and was wandering if you could help me out, I just bought a 96 cherokee XJ Ltd.(4.0 auto) everything on it is completly stock. I am a budding Novice at the moment.
I want to modify it for off-road purposes.
Can someone tel me what is the stock axle type on this model?
Also i have a list of parts i wish to buy in the very near futre (a few weeks) and was wandering if you may tell me if i need to add anything else to make them 'work properly'!?
They are as follows:
SUSPENSION- Rubicon 5.5" XJ Extreme Duty Lift
(someone mentioned an extended driveshaft and yoke?!) ???
EXHAUST- Banks torque tubes manifold, American 40 series muffler, 3.00" U-Fit dual pipe kit, Ball flange kit 3.00" to 3.00", H- Pipe ends. ???
BODY- Rusty's XJ Fender Flares
WHEEL&TYRE- M/T ClassicII cast Aluminium Wheels (x4) and some Good year Wrangler 35 12 15's ???
I am so lost, i have tried to ask on another forum but no one replyed =(
Please help me, i need to know if i will need anything else to make all these parts work eg. slip yoke eliminator/ fender cutting etc.
I know its alot to ask but i promise you will be among the first to see once it is finished!
Thanks for taking the time to read my post.
Regards, Fingal
P.S I have seen alot of threads about the 'Turdonator'(turbonator) so to keep people quiet i bought one and will get it dyno tested in 2 weeks and send it back with - results (no i dont expect anything, just a scam)
Regards, Fingal
With that suspension lift, you will most likely have to buy a SYE and a double cardon joint rear drive shaft. Possibly even an extended front driveshaft. I've been told both ways on that one though. Some say they needed one, others didn't.
Be careful of putting an exhaust system on that is too free flowing. When you open up the exhaust too much, you'll lose most of the low-end torque that 4.0 is known for. That power will still be there, only it will be further up the rpm range.
Good choice on the fender flares and wheels/tires. My chart out in the garage says you'll have to trim your fenders to fit those big 35's. If you're only driving it on the street, and I'm sure your not, they won't be a problem. However, at full flex, they will hit sheetmetal if the fenders aren't trimmed.
I agree with your take on the "turdonator."
I did some trials in Scotland before i moved out here, i used a custom built army lightweight and my father used his custom 110 land rover. However in Malaysia they are V. expensive!
So i fell in love with the jeep! but soon realised i dont really know enough to build it.
Also, there is alot of oil leaking from the top of the cylinder head, maybe a gasket or at worse i fear the may be a crack, i will have to see at the garage.
What one is more likely?
thanks for your help!
Of course u want more power out of the 4.0L, the low end is great, but the mids could be better, i think the new Edge products, Trail Jammer pkg. is the best bang for the buck, and if you use the Flowmaster w/ that, w/ maybe 3.0" out the back, or Dual exhaust, i think it would make a great combo. Rockcrawler.com, just did a test on it. check it out.......hope i helpd. peace
If it's leaking out the TOP of the cylinder head, then it will be the valve cover gasket. They are known to leak.
Have a 98' Jeep Cherokee Sport 4x4, 4.0L I-6, 5 Spd Manual.
I am very happy with this as our family vehicle. It'smostly driven on road, except for occasional camping trips towing small boat for long highway rides, then some offroading when we get there, just to get the boat into the lake.
Situation: I don't really care for the stock rims and have just purchosed a set from a 2008 Rubicon, (I think). I have always liked these newer rims but unfortunately the bolt pattern is different, (5x5 instead of stock 4.5x5). The obvious and only solution is to buy wheel adaptors which I intend to to.
Now, I do not want low profile tires, but the correct tires for these 17" rims will surely demand more space or else I could probably expect rubbing problems, etc.
Do I need to lift my Jeep, or can I get away with just modifying the fender flares?Also, as I was looking into flare kits I noticed that they all say they fit up to '96 XJ's. Will these kits fit a '98? I do realize that some trimming will be necessary for some flare kits.
I need advice on a good 17" wheel tire size that will work without turning our family car into a "Monster Truck" as this vehicle is intended mostly for an road use.
Tire size on 17" rims?
flare kit? Triming involved?
To lift, or not to lift?
I am imagining a combo like, 4in lift, 31 in tires, trim fenders and install flares.
But I think I need advice from the experts brfore begining any mods if some can be avoided, keeping in mind I want to avoid road handling problems, or having a hard time lifting kids into child seats, but want to make these rims work without rubbing, etc. I will appreciate any advice or recomendations. Thanx
RJRacer
179,000 miles and still going.
