Suzuki Aerio Wagon Brake Problems
Get (and give) advice on Aerio brake problems here.
If you think your bearings are going up take your car to a brake shop and ask how the rotors are. If their warped it is probably caused by the heat from the bearings. Make sure the dealership replaces the rotors. They will try and claim it is a regular main. problem and is not covered by warrenty, but if the bearings heated up the wheel they caused the rotor to heat up and this causes the rotor to warp. Cause and effect. If they put up to much of a complaint tell them you want to talk to the district service rep.
My 2003 Aerio SX just turned 27K miles. At 23K miles the front brake pads had to be replaced and the rotors turned. They were worn down 90% according to the tech. Cost was $205. I took it to my nearest Suzuki dealer. I wasn't overly happy that the brakes wore out so quickly. Other FWD cars I have had lasted around 50K miles. I don't drive like a maniac and most of my driving is highway (70%). But this is the only problem I have had. I did have the occasional thunk when backing up but I never took the car in for this. Since my brake job I have never heard the thunk again.
Happy Motoring
2) You have a REALLY GOOD braking system. Your car LITERALLY stops on a dime with the slightest touch of the pedal, producing HUGE amounts of brake dust!
3) (serious for a moment) Someone installed counterfeit brake shoes. The skills of the counterfeiters are better, and access to various technical resources is getting easier. They're finding all types of ways to sell their stuff to legitimate channels undetected (February 7th issue of Business Week, "Fakes!" May be available via http://www.businessweek.com.). But then, I think that Suzuki would have noticed if the problem is widespread.
4) Defective equipment?
I can't envision a legitimate reason why a new car should have 10% of the brake pads left after only 8000 miles.
You may want to e-mail Suzuki of America about the issue. I don't think that the pads are covered by the car's warranty (at least that's true for my 2003 vehicle), but you could prompt someone at the company to look into the issue for you.
I had an '04 Aerio that I traded in for the '05 at 14k miles and no brake problems whatsoever. Also I drove about 8k of the 14k on the current car on the highway between LA and Phoenix.
Oh I took the car to Firestone and they told me the calipers weren't working properly, causing them to heat up, and in turn heating up the pads and the rotors... they want $695 to fix the problem (calipers and rotors).
We need to band together to fight Suzuki over this...It is not bad driving but defective brakes!!!
Follow this forum for more information after I see the District Manager on Friday.
I will speak very postively to the safety of the vehicle... car crumbled as designed, hood buckled, engine was pushed down rather than back... both airbags deployed, she only received a cut lip from airbag and bruise on her arm.. Based on this, am looking for a 2005 new or a 2006 Aerio with the standard side airbags..
Gas mileage could be better, but the engine is bigger, more powerful and it is generally 300 - 400 pounds heavier that similar cars in its class, which may have contributed to the safety aspect....
Overall, we were very happy with the vehicle...
Anyway, interested in their response on the brakes...
4,900 miles and just today 5,117 miles round three.The sad part is that Suzuki wants me eat the cost of pads and rotors replacement. Thats going to be round four keep you
inform.
8k miles on it now. already had front brakes replaced and all 4 tires replaced. i get on avg 17-18mpg in the city. dealer keeps telling me nothing they can do. anyone else have this problem
I remember the Saturday morning in November 2002 I picked up my brand new 2003 silver SX hatch back from Brampton Suzuki (Toronto, Canada). Right off the dealers lot I noticed a strong shaking in the front suspension whenever I stepped on the brakes. So after only 8 Kms (less than 5 miles) I’m back at the dealer sitting in the service department. The verdict ..both front discs are warped and require replacement. It seems this little problem wasn’t noticed during the pre-delivery inspection.
A few weeks later, after these new brake rotors were installed, the front brakes begin to make a slight grinding sound. They also make a fairly loud stap when applied in reverse. So, it’s back to the local Suzuki dealer and new and improved shims are installed. They almost fix the noise issue. Only the replacement of pads and discs with non-Suzuki parts actually solves the problem a year later. I tried slotted rotors from SuzukiSpeed.com / ThermoQuiet Pads from Wagner. So far, no complaints. The EBC Sport Rotors (drilled and slotted) and EBC Greenstuff pads look wild. Anyone try them yet????
I wish there was a way to know whether the brake problems that many people have talked about here is a widespread problem with the Aerio (not that it matters now).
E-brake: ugh! Assuming that there's nothing wrong with the rear brake shoes or the regular braking system, or transmission park pawl (assuming an auto tranny), you or somebody you trust must inspect the cable lines to the rear wheels:
-Are the cables connected to the e-brake lever and the lever within the drums of the rear wheels?
-Is there slack in the cables themselves? There's a nut between where the cables leave the rear of the e-brake lever that can be adjusted to tighten the connections.
-Finally, is the lever's ratchet teeth in good condition? If not, the lever needs to be replaced.
Note: these are suggestions off the top of my head, based on the description in the car's service manual of the e-brake system as I understand it. My suggestions are NOT comprehensive. Consult an expert for assistance.
Now It's november, less than a year, less than 15,000 miles and my breaks sound like they are completely worn out. I want to do something about this, please call me 410-258-5734. Suzuki cannot continue to get away with this, I thought this was only my problem but they are endangering many lives.
We traded the car in on an Infiniti G-35 Sports Coupe and took a big loss, however, we feel better about getting that Suzuki out of our hair.
Suzuki can go fish. We will never buy any more of their products!
