Visitor Agreement.
Also if you have trouble disengaging the 4-wheel drive system, make sure you are driving on properly inflated tires and that you are driving straight. From what I have read and what others have said, this can be normal. The 4X4 system is not meant to be used when you have good traction. It could bind up. One big reason for the binding improper use, but if you are certain that you are using it right, it could be mismatched tires, improper inflation, and other tire related problems. The tires must all be rotating at the same rate to properly disengage the system.
BTW, much of the talk on the timing chain issue seems to indicate that the use of bad filters and the wrong oil either causes the problem or makes it happen quicker. Many of the recommendations are to use the lightest weight oil for the truck, and to use a good filter like the OEM Suzuki filters. Some have said that the Purolator Pure One and Wix filters are just as good. I have used many different brands, but never generic or Fram filters.
Frank
I am assuming Suzuki did not extend the warranty for this particular item. Unfortunately, 2001 was 3/36 warranty.
many thanks for the help.
Jason
Also had a problem with the remote not working, Service manager wouldn't do anything about it till he saw it happen, so that was about 3 trips to the dealer, then one of the reps tells me that its a known problem with the contact plates on the doors. Had them replaced and it worked fine.
cheers, poppins6 :confuse: :lemon:
Check your owner's or car warranty manual - if you have less than 80,000 miles on the SUV, the catalytic converter may be covered under the federal emissions warranty.
Ivan, kc5yti
Ivan, kc5yti
Lots of people think the best way to let the powertrain warm up is to hop in and gently drive it the first mile or two. Excessive idling can damage components like the catalytic converter. (link)
Ivan, kc5yti
If you get ambitious maybe you could email Suzuki and ask them to clarify the manuals.
Ivan, kc5yti
2002 XL-7
2007 XL7
http://www.leemyles.com/faq2.htm
Q. Can one place the shift lever in drive or reverse when the engine is in "fast idle"?
A. This again like the previous question can cause abrupt transmission engagement leading to the early failure of clutches, bands, gear sets, driveline components and engine or transmission mountings.
http://www.tigardtransmissions.com/faq.html
I can't find to much more, but they make sense. If you place it into gear while the vehicle is at fast-idle, would be like dropping the clutch on a manual transmission.
I have also seen people saying not to wait for the engine to warm up. I think it depends on the vehicle. If you have a manual tranny, sure, you could get going right away. I have a 1990 Honda Accord, and I do that, but not with either XL-7 or any auto. tranny vehicle.
Oh well, I am sure this could become a hot topic.
Ivan,kc5yti
Anyway, it says let the engine idle for 30 seconds after starting and don't race the engine. Drive at moderate speed for a short distance first. And use caution when shifting when cold since cold engine idle speed is high. I suspect the Suzuki one is similar.
I'm guilty of rarely using my parking brake either btw. I did use it today while messing around in the garage and then wound up driving 2 miles before I realized it was on.
Hope this helps.
SUVs and Smart Shopper
kc5yti
Ivan
Ivan, kc5yti
Ivan, kc5yti
Ivan,
The camshaft ,,,along with the rocker arms have to be changed...????
This is completely blowing my mind.
Has this happened to anyone else? The dealer service guy said that this has happened to a few other 2007 xl 7s.,,but after the repair,,everything should be fine. I believe this is a huge job for a brand new vehicle. Engine work??????
Can anyone shed any light on this for me...??
Thanks for letting me share.
I work at Cami automotive, the company that makes these for suzuki, in Ingersoll ontario, i have heard of no particular probs with the camshaft, or misfires, but i will take a trip up to our quality department for you and see if they know anything i don't!!
Jeff
I have heard thru the grapevine that this has happened to a few other xl7s because of the manner in which it is shipped thru Canada. The interior of the engine is not covered and rust has been forming on the whatchamacallits. This sounds crazy but I hope they can fix this or else I want my money back. Its been 8 days in the shop already. I have to start looking up lemon lawyers.
At this rate ,,,I will be in line for a refund or a new vehicle,,,I ll take the money.
I thought I had a good deal,,,but.............we shall see.
I bought a new 2007 XL7 Limited AWD in Dec 2007 here is my list of issues:
Jan 3rd 2008 heater will not work while in Aspen Colorado.
Jan 5th 2008 DVD/Radio/CD will not work in San Antonio, Texas. Rear defroster 1/2 broken. (dealer replaced rear window completely)
Feb 11th 2008 Engine shut off completely while driving!!!! rough idle heard and felt through out car, dealer check all OK. Two roof rack bindings will not stay down, dealer fixed per tech bulletin. Now all four will not stay down. Dealer order new roof rack rails with attached bindings. Climate control face plate/bezel will not stay in assembled location, pops out, Dealer replaced bezel.
Mar 11th 2008 1st oil change. dealer suggestes replacing all wipers, under warranty.
Mar 14th 2008 tighten fuel cap warning.
Mar 16th rough idle and hesitations while accelerating from stop.
Mar 17th check engine light (7865 miles) and tighted fuel cap warning, again, but I never touched it since tighten it last time and the light went away. Dealer witnesses lights and mentions that the tach was not moving between shifting from M/D/N/R/P. Rough idle witnessed by dealer, finally.
Mar 18th in dealer service shop this morning - I'm completely frustrated and do not want this lemon anymore. I had a new 2006 Grand Vitara 4X4 never one issue that's why I bought the XL7.
The dealer told me it was a misfire caused by a defective camshaft.
They were going to put a new camshaft and rocker arms but someone told me that there are no rocker arms because it is variable valve timing or something.
Its funny you mentioned the climate control face plate not staying in position. Mine is doing the same thing,,,,I keep pusjing it back on but that is not my problem right now. I am waiting ....
cHECK ENGINE LIGHT came on at around the same mileage as yours. Weird...
Regardless of the dealer's cover story your defective camshaft should have never made it to market, there is more to that story. The same with the auto accelerating XL7's posted here , that alone is enough for me to dump this vehicle very soon.
