Visitor Agreement.
How repeatable is the problem? The length of time it takes to have the problem, if it is fairly consistent can help determine the problem, a part getting hot for example.
My 1984 Trooper 1.9L had an engine computer in the glove box. It was possible to connect a couple pins together on the computer to cause it to blink codes on the dash idiot lights. If you can get the shop manual, there is instructions and a table of code, their meaning, and what to check to correct the problem. Do you have any dash idiot light coming on?
How long do you have to wait with the engine off to restore power? The time that takes might help, to determine what part is recovering, the recovery time is important.
Does the engine act like it is running out of spark or fuel or air?
Things that mess with timing can cause loss of power, the computer adjusts your timing based on sensors on the engine.
Something else I changed was the throttle body, a plate with the butterfly valve at the bottom of the carburetor. I noticed a significant vacuum leak around the throttle shaft because of rough idling. A vacuum leak can cause loss of power.
I drove my 1984 Trooper 201K miles. It always was reliable. I had the optional power steering, the tensioner pully for that was defective, Isuzu designed a better pully and that fixed it. The 1.9L engine is "the little engine that could". IT is very easy to work on. A friend of mine rebuilt his LUV truck's 1.9L engine and it turned out like new, the look of satisfaction n his face when it started up and purred beautifully was priceless.
For example: 3 short blinks followed by a pause then 1 short blink followed by a longer pause would translate into code 31.
Is this normal for the the troop? I am used to 4X chevy suburban front axle chatter etc. Also at one point I heard a rattling sound coming from the front a couple of times and once reminded me of a noisy shock absorber rattle / thump but hasn't sounded of since I first heard it a month ago in November.
WhatchathinkitkoodB? :confuse:
i have an isuzu trooper 1989 4 cylinder. I was driving it today in highway. suddenly the red engine light came on and i in a few second, the car turnned off. i was forced to pull out the road. i checked the engine. the oil and cords and anti freeze looked fine. i tried to restart. it did not turn on. i felt the fuel is not comming. (but i might be wrong)
is there anyone that can tell me what could be the problem? thank you.
Cameron :sick:
You need to check the auto hubs to make sure the circlip on the shaft is still in place. Since it is an open differential, neither side will feel engaged if only one side is working right. Damage can be done to the outer splines if allowed to continue. If the splines are OK, and clips are there, then the hub itself needs to be checked and cleaned and greased properly. If the splines are damaged, cheapest repair is to put manual hubs on, as they don't use the outer spline. Otherwise, you would have to replace the stub axle.
My reliable 2001 Trooper (64kmiles) started spotting my garage floor with what I thought was oil, but upon further looking, it appears to be the transfer case??
Can someone eyeball this picture and confirm this is the transfer case? The leak comes from this circular plastic insert, that I can't figure out if I can or should tighten it or replace it. It has no surfaces like an allen bolt would have so I'm perplexed. thanks for any ideas.
http://www.carspace.com/kevinm/Albums/Trooper/Trooper%20Engine%20Pic.jpg/page/ph- oto.html#pic
-Kevin
If that's the case, then you may be able to have it repaired under warranty.
PS did some research and found this from a good mechanic on this:
HI ALAN WHERE BC IS TALKING ABOUT IS ON THE RT SIDE OF THE TRANS THERE IS A SERVO PISTON THAT HAS SNAP RING HOLDING IT IN AND IT IS NOTORIOUS FOR LEAKING AND TI WILL RUN DOWN THE SIDE OF THE TRANS AND MIGRATE INTO THE EDGE OF THE BELL HOUSING AREA , BUT USUALLY NOT THAT STEADY OF A LEAK, JERRY
And this:
WOW!!!! They were really going to take me to the cleaners for this!!! I got a callback this evening and the estimate they quoted me was $540!!! Allegedly, they couldn't get just the cover and new ring without ordering the whole servo/piston package, the parts just didn't come separately. So they wanted the go-ahead to replace the whole unit!
SHENANEGANS!!!! I called St. Charles and spoke to Merlin (the man!). I simply asked him what parts were neccessary to fix the leaking accumulator piston cover.... $10 worth of parts!!! I went ahead and ordered the stuff (it was the least I could do) and took my case to the service dept at Isuzu. In so many words I told them there's no 'right or wrong' to their repair recommendation, but let's call a spade a spade; I did not need a new $540 servo! I said this is the way I want you to repair it (per [St. Charles'] standard procedure), and they were more than happy to oblige. Damn straight!
Buyer beware!!!! Being an informed consumer saved me some $400, and I would have been a sucker if not for this community. It kills me how they insisted there was no other (cheaper) way to fix it.... well they were in for a suprise; momma didn't raise no fool! I'm sure labor ($90/hr) could be found cheaper elsewhere too, but at this point I was content to set an example. Besides, this dealership is right around the corner from me and it'd be a shame if I ever did need something serious, I'd have to go miles to find the next closest one. In short, thanks for everyone's concern.
These are the part #s in case anyone else needs 'em:
Snap ring: 8-96015-714-0
Cover: 8-96017-093-0
BTW: Although they admitted it looked like it could've been leaking for an indeterminate amount of time, there was no chance at letting it slide under any warranty coverage. I dunno how far out it was but I'm at 52K miles and the (original) in-serve date was Dec 2000. Your guess is as good as mine when it comes to warranty coverage for non-original owners.
Cheers!
Also, that narrow pan is for the trans too. I think it may have been mistaken for something else by previous posters.
Did they replace your tranny fluid once they replaced the snap ring and cover?
Also, is the St.Charles procedure available to any shop? I wouldn't mind having this done at a local shop as our local Isuzu dealer closed it doors about 2 years ago and the nearest one is about an hour away.
-Kevin
The St. Charles Procedure as you call it is just the reference to the Isuzu dealer a lot of us use to get parts from. You can find them online, and their parts department is great. Usually get parts you ordered within a day or two. The point he was trying to make is that it is a relatively minor job to remove and replace, especially if the proper care and tools are used. Many owners can do it ourselves. I have read where a screwdriver properly used can get the cover out, so the dealer tool is not always the only way to do it. Any good mechanic should be able to do this. Make sure to check fluid level when complete and refill as necessary.
How do I get to the switch and how do I repair or lubricate it?
Thank You
Appreciate any thoughts as to cause and need for concern.
Enjoy your "new" Trooper! :shades:
Yes, you can drop the pan, but it means removing the steering links and tie rods, and dropping the axle down til it rests on lower control arms (gotta be very careful of CV boots). Then remove starter and flywheel inspection plate to access rear pan bolts. It is a PITA, but doable.
However, how does one go about replacing those sensors? I unscrewed them, but I can't figure out for the life of me how to remove them without slicing the wires. Am I supposed to slice them? Is there a trick I missed somewhere? Can anyone enlighten me?
I have heard that the tensioner can make this noise, a fellow mechanic friend actually tried to sell an engine because of it. He was a bit red faced 3 days later when the customer pulled up and told him what the REAL problem was. This one i THINK is more terminal, however
the the timing cover is definetly coming off first.
But again,THANKS, that is the info i needed. I will let you know when i have a punch line to this knock-knock joke. though i myself might not see the humor
it is often called the 'upsteam 02'. Sensor 2 is after the
catalytic convertor, Its job is to monitor catalyst efficiency, its often called the 'downstream 02'.
All the sensors DO have a connector, but the wires may go a few feet before you find it. I like to get the new sensor and check the wire length to get an idea of where the connector might be hiding. Also a code for B1S2 or B2S2 (any sensor 2 code) may be a bad catalytic convertor. I check them with an infared heat gun. outlet temp. should be At Least 50 degrees f hotter than inlet
example 350 @ inlet 430 @ outlet. Good luck
I was going on a 1200 mile round trip first part of October. I ended up changing from 10-30 to 10-40 oil. After driving the trip it seems that the pressure problems has corrected. Have not seen a real drop (to 15 or less psi on the guage) since then.
I was using a synthetic blend 10-30 (Phillips 66 brand I think) to top off the conventional 10-30 from VIOC or Jiffy Lube. Wondering if that combination was behaving badly. Also possible that extended driving might have warmed up the oil system and 'cleaned' up some gunk or sludge? I watch the oil guage pretty close now and am wondering if warm weather will cause the pressure drops to return.
Anyone else have any ideas?
I noticed on my last trip down-island, that her power was down. It hasn't gotten any worse, and she still pulls 75mph (about 120Km/hr) on the flats without any problem, but as soon as there is any uphill grade, she sucks. Can't figure it out, and I've mentioned the problem to several mechanics, and they can't figure it out either.
Do I smell an engine overhaul or rebuild?
Please help!!
Thank you so much.
Paul, Alert Bay, BC, Canada
I don't have your model, so I can't offer more, but for the sake of discussion what engine is it? What transmission?
Welcome to forum, it helps to put your year, model and engine trans info in your signature when you post.
Try going to www.myisuzuparts.com and checking the years you have part no.s against each other. I do believe that they are interchangeable...the only major difference in body styles was the difference between 2 door and 4 door, and even then I don't think the rear changed.
I got out of work a few days ago and my trooper wouldn't start.
Here's a list:
- no change in electrical systems when turning the key. This includes the normal warning light check, the radio lighting up or any other dashboard illumination. It's all off and dark
- battery was taken to an auto parts store, and is good.
- engine does not crank or try to crank (at least that I can hear)
- also pretty sure that headlights do not work
- all fuses/relays that I could find look okay
I thought that maybe the ignition switch was bad, so I disconnected it and put a volt meter on the harness and I got voltage to the ignition switch. (not sure if it was enough/right amount) Figured switch was bad, so I got a new one from the dealership. The only one that they could get their hands on inside a week had a crack in the casing, but I tried it anyway. No luck.
Here's what I'm guessing so far (one or more of the following):
- new ignition switch is bad, needs to be replaced
- faulty grounding somewhere (where are all the grounding locations, anyway?) makes circuit incomplete
- starter harness?? some of the stuff I've read says this may contribute
- some relay/fuse/fusable linkage somewhere has fried and I'm not aware of it
-? something I haven't thought of
Any and all help would be greatly appreciated, I feel a bit dead in the water and really don't want to have to tow this to a mechanic
As you are learning, electrical problems seem to top the list on any forum but maybe even more on the Isuzu's! I don't have your model truck, but..........
Very often the alternator is the culprit....when it goes bad it wreaks havoc on the rest of the system. Try just unhooking it and see if you get any different result.
Cleaning the grounds is also another must do, and IIRC there is a fuse or link in the circuit in the eng. compt. Also, there may be a voltage regulator on the firewall, it depends on the model I believe, Under hood, center, rear engine area, mounted on upper firewall.
I hope this helps. Good luck.
I am not a pro, but I do know from my own experience that the factory brake pads from Isuzu seem to give the best service life, and they also don't squeal or stick as I have also seen. When I bought my Trooper used, it had aftermarket pads. They had worn unevenly due to no reason I could find. I cleaned and lubed the caliper pins and knock on wood have had good results. For some reason,the design of the caliper has two different style pins, but I have never seen that before or since. They are some kind of dust seal (so I am told). The calipers are prone to getting sticky if you see much salt air or snow/mud/salty road conditions, so cleaning them up and/or replacing them seems to be common.
Hope this helps. Good luck.
I have a 1994 trooperW/ac 4 dr It just started acting up by all the lights on the dash flashing and it does a clicking noise in the fuse box, the voltage goes up to 18 and just the other day it did it, then stalled out and it started right up agian and did it all again.When the defroster is put on it doesn't blow either Any help would be GREAT
