Visitor Agreement.
The factory speakers are horrible, you saw them right, they are certainly not premium, and did you look at the magnets on them? small.
The magnets on the factory speakers were laughable. The sound guy told me if I'd installed an amp w/o upgrading the speakers it would have blown them apart.
I wonder if the '08 model has better equipment? I know it has the mp3 hookup and the EXL has a 270 watt unit, but I wonder what the speakers are like? Anyone with an '08 care to chime in?!
I am curious about the "break in" period on the MC's. As for your experience, how long did that take?
Despite the break in period, it is worth it!! I will stick them for all my car audio.
Did you save your old 6x9's? At least you could transfer those to the next car.
Ya, my next lease, which will be the 08 Accord EX-L 4cyl, Navi, I will go all out on the system. I am thinking I might own this next model
Do you have an 07? Mine is an 07 SE V6. I'm also perplexed how you were able to keep the front speakers, unless you have a different year model.
BTW, I called my local Honda dealer (parts dept) & asked about the front speaker situation. I wanted to know if it were possible to buy the ring housing w/o the speaker so that the originals wouldn't have to be destroyed. I was told no, there is no such part. This is going to sound like sacrilege to the Honda-heads but IF this is really the case (if my sound shop was correct) I think Honda made a poor design with the front speakers. It's ridiculous to have to destroy a speaker in order to replace it.
But to answer your question = No, I kept the factory dash mounted tweeters. I would have liked to have replaced them but it was hard enough to convince the wife to spend what I did spend! (That's why I'll wait a few months to get the amp!).
All four of the new Memphis speakers are coaxial.
You mentioned you were going for the 08 EXL. You are aware that model has the new premium sound system? Again, I asked 08 owners to chime in and tell us what kind of equipment is in the new model. Especially curious about the EXL. It is possible that despite a 270 watt radio the speakers may not be much improved over the ones found in our generation Accord. Hopefully some 08 owners will pop in this forum pretty soon.
Now as far as the Premium sound system in the 08, if you happen to look in the trunk and look up, you will see that there are 3 speakers, 2 main speakers, and 1 subwoofer, and notice that they have the same small, cheap like magnet on them. I was like wow! I told the salesmen, Great, I am going to have to replace all of them again! He probably thought I was totally nip picking, some snob. Now, the actual power might boosted, and even the 06 has decent power. Though they need to be like the Jetta, and have a separate amp powering the speakers, now thats a real premium system. Really, they need to team up with bose! So upgrading the 08 will be fine, I'll get an amp. I would though like to listen to the 08 sound system, but actually you will find that it will sound fine for awhile with the factory speakers, but after awhile, the factory speakers degrade, and fall apart, and eventually sound bad, and cannot handle too much. So you really can't judge it at first, though the factory speakers had no character at all.
Tell the wife that it is totally worth all the upgrade!! I got have the music in the car! :shades:
(Stereo: It is interesting that you mention the stereo as a positive item. I am not particularly impressed with the stereo systems offered in the 08 Accords. The base-level stereo in my 98 was much better than the stereo I listened to in the 08 LX-P. And, the "upgraded" stereo I got in my new EX-L is acceptable, but it seriously lacks mid range at higher volumes. Despite adding a separate subwoofer, it doesn't sound like Honda used cross-over filters to help the performance of the door and deck speakers by limiting their low-frequency output. It is as if they simply added a subwoofer with a 100watt amp to an otherwise average stereo (not a very high-tech way of doing things). The sound imaging is sub-par and the stereo simply does not produce a well balanced acoustic range at volume. Unlike the 440 watt system in the Camry, the 270watt system in my Accord just doesn't have the reserve to produce convincingly great sound and bass. If the in-dash unit weren't so damn odd shaped, I think you could buy an after-market system that would seriously out perform the factory system for $400.
Accord stereo: Here is what I find is "wrong" with the 270 watt stereo in the 08 Accords:
1) At anything more than low to mid volumes, the mid frequencies seem to disappear. The stereo has ok treble and good low-bass, but the mid frequencies just don't appear. The problem is exacerbated by the lack of adequate frequency control / equalization on the audio system. A stereo with 7 speakers and 270 watts deserves a true equalizer -- not simply a base and treble control (with an added subwoofer control).
2) The subwoofer seems to be nothing more than an "add on" with a separate 100 watt amp. Many systems with a separate sub use cross-over frequency limiters so that the regular speakers are not trying to produce the low-end frequencies that can be handled by the sub. I don't know if these cross-overs are used on the Accord or not -- but if they are, they aren't doing their job! The regular speakers are trying to pump out lots of bass. This might not be a problem if they could handle it -- but they can't! The regular speakers are either 1) inadequate to handle bass at volumes, or 2) are underpowered and do not have the wattage reserve necessary to produce crisp/clean bass (bad speakers sound bad as do good speakers which are under-powered). You might say, "well then just turn down the bass on the stereo" -- great idea, but the "bass" control affects about 1/2 the audio range. So, if you turn down the bass, you are loosing way more than just the low-end bass that is also being produced by the sub.
3) The sound simply is not well-rounded. There is ample high frequency and great very low frequency. But, everything in-between suffers at mid-high or higher volumes. The subwoofer clearly is frequency limited and does not even attempt to produce anything other than low-bass sound. The regular speakers are then left to take up that slack and, as mentioned above, they just can't get it done at mid-high volumes. The mid-range and low-high range are very weak. I assume this is a problem with the speakers, themselves. But, it could also relate to a number of other things including speaker position (since the higher the frequency, the more direct path it needs to have to the ear.)
4) The stereo simply does not do a great job of sound imaging. I listened carefully to the upgraded 400+ watt system in the Toyota Camry. It does a great job of sound imaging (and sounds WAY better all-around). The sound imaging /balance issue is particularly hideous if you sit in the back seat of an Accord. The entire Accord sound experience is limited to the front seats. I'm not necessarily knocking Honda for this since it is very common in all budget-minded sedans. But, the new Accord's system should be more balanced given the fact that it is now a big passenger car, clearly intended to seat 4, not 2, passengers.
With regard to the LX audio systems, I am very confident when I say that the stereo in my 98 LX Accord was considerably better sounding than that offered in the new LX models. My 98 Stereo was underpowered and would not perform at volumes, but at least it sounded very balanced, with great bass, at lower volumes.
Having said all this, I think the upgraded stereo in the 08 Accords will be acceptable to most drivers. It does produce impressive bass! I am confident that the 400+ watt system in the Camry is much better, but I didn't purchase an Accord for its stereo system.
Do you plan to "upgrade" or leave it as it is?
I'm also simply scared to replace the system. I have had several bad experiences with digging in into the dash, rear door panels and rear decking. I'm embarrassed to say that I lack the expertise or time to install a new system myself, and half the time someone else installs something for me, they just don't do it right. Nothing on my new Honda sqeaks or is loose -- I'm quite confident that even the most careful installer won't care as much about my car as I do. Every time they are done, some panel has a new scratch, some clip is broken, thread stripped or a new rattle created. Maybe I'll replace it once that new car smell goes away
BTW, thanks bug for that report on the 08. I started out over a year ago looking hard at the Camry. Among the things I was impressed with was the 6 speed AT, 268 hp engine, & of course the new JBL 440 watt sound system. I probably would have bought one, but I was determined to get a V6 and when some models started showing severe tranny problems I decided to let it go and came over to the Accord. (Consumer Reports has since dropped the 6 cyl Camrys from their "Recommended" list.)
Obviously, Honda makes a wonderful car. But they are lagging behind the competition in the sound dept. That's just the way it is. I agree they need to team up with someone like Bose and offer a true premium sound system, and make it available in more models than just the very top of the line.
Thanks for the review on the 08! This will give me a heads up, and at the same time, it is frustrating, I'll have to do it.
Teaming up with a good audio company would not cost them too much, compared to the cost of the car, adding it only to the EX-L trim.
Gotta disagree with you on that last part. and it's due to the competition. For example, you don't have to buy an XLE Camry to get the premium sound system. It's offered as an option on the lower line models. I see no reason why a EX or an LX owner shouldn't be able to shop around and find a model with that option. Or at the very least, be able to order it.
Go to the Toyota web site and try to build a Camry LE with a California zip code and see what the choices are.
A Camry LE 4 cylinder with VSC and JBL would be perfectly equipped for me and those options are listed for the LE, but you just can't buy one like that because they don't manufacture and ship certain options to some regions and they won't build one like that for one person.
Yeah this is part of the Toyota/Honda business model, as opposed to something like a Ford or Chevy where you have to order it but you can pick from a dizzying array of options.
But you are certainly correct there's a chance you won't find one at a local dealership.
Also, I am actually thinking of getting an FM Modulator for my PSP and be able to play 4gig of music through that, but I have not tried it yet. I know FM modulator will not sound as good, but sounded pretty good with my moms ipod though. Although when I get the 08 Accord, I'll be able to directly plug into the stereo. I still have the 06 Accord.
The wireless FM transmitters are the ones that will disappoint most people because of radio interference.
However, if you are going to remove the radio anyway to install a wired FM modulator, you might as well get the USA Spec device instead.
Now, I think if Honda offered a Hard Drive with the Navigation, it would convince more people to upgrade to that, considering its a 2k option, that would make it seem more appealing to spend that much on the navi, if it had the option to upload your mp3's to it. Oh well, right? Its all good.
I have a question about that actually...if all of the music is already on your PSP presumably you have that with you most of the time, why would you want a hard drive in the car? It seems to me like that would just be a duplicate place you would have to store stuff you already have with you, and have to upload and download on and off it, etc.
Is it because of the interface (or lack there of) between your personal device and the car's stereo system?
Replacing the front door speakers is more involved, in that you need to remove the door panels and I'm not that comfortable with doing that. I'm satisfied with the front door speakers frequency response mostly since there are factory dash mounted tweeters that make up for the lack of high frequency resonse from the front door speakers. If it was easy to remove the speakers from the front doors and I had confidence in doing it, I would also replace the front door speakers. Maybe someday....
I was only stating, that if they offered that it would make it more appealing considering the navigation's price tag. I would totally use the hard drive for the navi, if it was offered. But, it is not offered with the navi, so that is why I mentioned my PSP being able to take the place of that.
Dude, totally cool. I didn't mean to make it sound like I was bashing the idea on the hard drive, but I am with you on I would rather just use my iPod and have a decent way to control the thing then some on-board system.
The bummer part of trading for the 08, is that I will have to replace all the stock speakers, that is going to be annoying, but worth it!! I am going to get Memphis Audio, with a Memphis Audio Amplifier. I'll probably leave the subwoofer alone. I am thinking its going to cost about $700 or so to get all of that done. I am thinking of trading my car this next spring, by then I'll have about 32k miles on it, and be close to the 36k allowed miles. But, I have been looking at the Jetta, because I can get more car for less!! but, I love my honda's though!!
I was actually going to get a DX or what was the VP now or what not, but the deals for the EX/5spd manuals were too good. Its been fine, it feels powerful enough and gets great mileage, but is not the most exciting thing to drive. Its safe and it holds the infant seat well enough though, so thats a good start.
I have actually thought when my lease was up, I might go ahead and own it, but I'll go ahead get the next car I want, with all the options, like the navi, and probably go ahead and own it.
The SE Accord is the best value, because it does give you a bit of everything in the line up, and looks great!! Silver with tinted windows.
Yeah I think if the SE-V6 came in a manual it would've been hard to resist, but I can't drive an automatic.
Good Luck,
Anyway, if someone out there is thinking of having an interface installed, be aware!
I think you are wise for looking for an easier to use interface for the iPod while driving. An aftermarket head unit that supports controlling the iPod and playlist selection shouldn't be too expensive. If your car has steering wheel controls for audio, there are adapters that should allow those to work with the aftermarket system as well.
I have had good luck with the Alpine units, but I am sure there are many other good options.
I can turn my volume all the way up (35) for the XM, but that volume would be ear splitting for the FM. Is there some sort of amp the XM by-passes? Or is there an FM transmission thats occurring in the radio? Is it worth taking to the dealer, will they be able to do anything about it? (I have a 2006 Accord with "premium" radio)
If I ever wanted to replace the radio or add an amplifier, is this an option since the whole climate control is built into the radio?
If you add an aftermarket stereo, you are making the car much more lilely to be broken into.
I don't know who is buying used aftermarket car stereos, but apparently there is a big demand because they are stolen every day.
They are also ugly.
If you want to take your chances with theft, eventually an aftermarket dash kit for the 2008 Accords will be made with a cutout to fit a standard radio.
It would be a similar design as the one pictured below for 2003-2007 Accords, but would be designed and sized to fit the 2008s.
If you are able to adjust the input level for your XM, which might not be possible, that would help.BUT, it should not be such a difference to be really noticeable. Take it to the dealer, perhaps it is your unit or XM unit within the system. I have used the XM in other models, and they are similar in volume between different sources. If your car is under warranty, take it in. Good Luck.
Your XM is just broadcasting at lower volume, but shouldn't be too quiet though.
People who want features that are appallingly absent from a "premium" stereo system in a vehicle made after 2003. Things like station identification, cd-text, mp3 capability, iPod interface, etc. Such features are nice if you want to do more than listen to NPR on your way to work.
They are also ugly.
Thanks for your very subjective opinion, I will file that with the other opinions.
I think a bigger issue is how some aftermarket systems incorporate additional features with complicated menus and tiny buttons. Volume should be a knob, not some tiny little button I have to hit 27 times. A knob that I can turn up or turn down. There is enough literature to support that to make it objective, not subjective. On and Off, IMHO should also be clear. Tuning should as well (ideally it too should be a knob).
It sounds like you have a unique situation that you should have your Honda dealer's shop troubleshoot under warranty.
