Visitor Agreement.
What I would be interested to know is whether or not the problem is different between the LX versions and the EX versions (or perhaps those with the NAV system). I have the EX-L (no nav). The XM problem is certainly there, but I dont' consider it real significant. Is it worse if you have Navigation -- is it worse on the LX's that don't have the extra woofer and amp?
I took my car to the dealer to have them look at the FM/ XM discrepancy, and after listening to it, and trying another car, they basically said "sorry, that's just how it is. Different sources have different signal strengths.". I think this is lousy, and wish I would have noticed it right away and made a stink. The service guy agreed that you shouldn't expect too much when they say "premium" system. The service people were really nice, but just couldn't help.
Anyone know if it's pretty straightforward to add a small amp to the system?
I plan to start tearing the console apart this weekend to get at the cd player.
Are you talking about doing it yourself? Can't help there.
I was quoted a price of about $275-300 to have a 75watt (x4) amp installed on my 07, which I'll do soon. This is, of course, at a pro sound shop - not a chain store where you might get it cheaper if you want to chance it.
Also, is anybody using a USA Spec iPod adapter? Any comments for or against? Can I hookup the Honda factory satellite to the USA Spec instead of using the FM modulator?
Mrbill
Just press the XM button on your dashboard and select channel 1 or press the voice control button on your steering wheel and say "XM Channel one". You will see your XM radio's serial number. Just phone XM radio to activate service if your three months have already expired.
https://xmro-secure.xmradio.com/listenercare/login2.xm
also charges the ipod while it is hooked up, so you can leave it on, and don't need to plug into the power socket.
Oh, and it also has a set of RCA jacks so you can hook up another source. I have an XM roady connected to mine. Still have to plug that into the socket though, but no need for FM modulation.
I've seen complaints before for lack of reception, so I don't think it's a problem with the radio.
Mrbill
Based upon your post #346, I'm wondering whether you have tinted windows. If so, that might impact radio reception if the aftermarket job was done over the antenna grid in the rear window. Could be material, workmanship, or both.
Do I need a special cable to do this (beyond a standard cable that connects the iPod to the sound system)? I am able to play my music just fine, but what I cannot do is control anything from the dash or steering wheel buttons.
Do I need to purchase the Music Link iPod adapter to have this functionality? If so, how since parts has no idea what I am talking about? :confuse:
I will review the information posted regarding the USA spec adapter, but was told by someone that it would not be needed in light of the changes made to stereo on Accords for the 08 model year. But alas, I cannot operate my device without using the hand-held controls.
If you are able to shed some light on this please do so – if not save your sarcasm for someone else.
Let me know which particular speakers you bought if you don't mind, and if I may ask, how much they cost installed. I'd appreciate it!
My apologies, since your original post failed to mention your questions were related to an '08 model.
With updated pertinent information, will do sir.
You should totally pick the Memphis Audio Speakers. I was very particular, and skeptical at first, but I love them. I never even knew these speakers existed. I had asked the installers at the professional place called "SoundCheck". I asked them which ones they preferred in the models. They both said Memphis! They have Infiniti, and several other models, and they mentioned that the Memphis were the most efficient running speakers, they will work with less power. I had had them installed, and I believe it all came to a total of about $400-500 with installation. Now at first, they sound a little weird, only because I noticed that they need to be broken in, I simply just let them play for periods of time, even if I was in the house, I would let them play awhile. That totally broke them in, and they sound AMAZING!! Very high end, the highs are crisp, and the lows are good as well, it sounds like I have an amp, they have so much character. Your right the factory's are muddy, but these babies, have plenty of mid range.
Now, they said that there were 2 lines, one was the reference, and one was a line that was a bit more efficient, for those that use it with factory system with them. Definately look at the efficiency rating on them, and pick the best number, Many do not realize, that when they pick out some random speaker for there car, that it needs so much power, and in the end their unhappy with them or they simply blow them up for underpowering them.
Now, these are the settings that I have set on my CD player on my 06 Accord.
Bass +6 Treble +1 Fader I have it faded 2 increments toward the front, I want my sound stage to be in the font.
Now, mind you the bass seems crazy, but with these speakers, it sounds great, and it needs it. Treble, you need to have it lower because the tweeters are so pronounced,These setting would not work with the factories. I really tried to give the factories a chance, but they horrible, plastic, hardly no magnent.
Anyway, go for it, let us know what you get. I got an Ipod Nano, I plan on getting an FM modulator, my mother has one, and it does sound great. I don't want to install in auxilary, as I lease, so I will be trading this next Spring.
Rear speakers. Has anyone actually installed new rear speakers in the 08 Accords? I have noticed that the factory speakers in the 08 EX-L Accords have magnets that are insanely small -- so I'm wondering if there is sufficient clearance to fit a new speaker with larger magnets?
-I'm being lazy because I assume I could look it up somewhere -- but what size are the rear speakers in the 08 Accord EX-L? (8" rounds??)
Also, if you are worried about sound, replace the fronts first or all of them, you want your sound stage to be in the front. Otherwise, you'll notice more from the back, than in front. Replace fronts, if you need to replace anything, but I am replacing all of them with memphis Audio, and getting a good solid amp. Find a good shop to do it. The Honda needs to take some advice from VW, as they use separate amps for their stereos.
You comment about VW's is intriguing. My brother has a new 08 GTI. The stereo is very nice, but . . . . whenever he turns it up more than mid-volume, he gets significant "buzzing" from the various plastic panels that surround the speakers (both front and back). Great stereo, but he can't take advantage of it because of the lack of acoustic deadening in the interior. I let him listen to the "premium" system in my 08 EX-L and, ironically, he was impressed. I am really not impressed with the system, but it doesn't distort and the interior doesn't "buzz" with the beat. . . . it just lacks mid-range and good sound imaging. The bass is really quite impressive! I'm particularly impressed with the frequency range -- I'm hearing some parts in some music that I never new existed
Thanks again for the advise!
Recently installed a metra/axxcess interface in my 07 V6 SE accord.
I have a portable xm player.My fi by delphi.The sound is barely audiable compared to fm or the cd player.The interface plugs directly in to the factory radio wiring harness.iwould think the volume level should be the same as the cd player.Previously have tuned the radio to 88.1 to listen to xm.
My next car will be an 08 Accord EX-L, I will be upgrading the stereo with memphis, and adding a memphis audio amplifier.
Good Luck.
You can do all of this on your own, but only if you have some knowledge on it.
If you do need more info, then simply go online to get more step my steps. Of course using the methods that only apply to your car and what you want.
Once you do all of this, it'll be amazing and worth it!! Time and patience is key in all of this. Research.
It plugs into the aux port on the radio, and has an ipod connector (to the dock port, not the earplug). It is even integrated into the stereo. Not the display, but you can change songs using the channel button.
It also has a second set of inputs for a pair of RCA jacks.
I have one in our Odyssey and it works great. The ipod plug even charges the ipod, so no need for a serarate power cord. I also have an XM Roady plugged into the other set of jacks, so no FM Modulation needed.
Crutchfield gives options by model/trim level of car, so that is a good start.
One caveat. If you have the factory XM, I bellieve you also need an adapter (basically a splitter) since the XM is already using the AUX port. They do make one though.
1- Is it easy to install it or we should let the professional do it. I only play some favorite songs on the CD in my '08, not the MP3 or anything else but I do not want son touches my expensive new car or he will "stained" it all over with his and his friends' stupid food & drink. That's kids' ugly habits even they are college kids.
2- How do you think about the '08 Accord EX-L stereo compared to Bose's equivalence?
Thanks a lot, Stickguy.
Also, my XM has gone out a few times, it shows all the info including ch. # and name of the song but no audio, anyone else with that experience? is it the XM receiver or the signal? Thanks.
