Visitor Agreement.
Here's another thing to keep in mind: You will also qualify for the complementary oil change service one year after the previous service was performed, regardless of the mileage remaining on the service indicator. I purchased my '05 325Ci about 11 months after its last oil change service. One month later, I qualified for a free oil change, even though my service indicator showed 2500 miles remaining. And instead of merely performing an oil change service, they went ahead with the entire Inspection I service.
That is no longer the case. Why? Apparently research has shown that synthetic oils that meet the BMW LL-01 oil spec oxidize so slowly (if at all) that time is no longer considered a limiting factor. As such, BMW has retroactively recinded the "One oil change per year, regardless of miles" guideline.
Best Regards,
Shipo
Wow! :surprise: That's news to me. I'm guessing this change of policy occurred within the past few months? Does this new policy apply to all BMWs? (Or just new purchases?)
Thinking about this further, if a driver puts in the full compliment of miles during the maintenance period, not only are they going to get three oil changes, they're also going to get coolant and brake system flushes AND a set of brake pads, rotors and sensors (if needed). On the other hand, if a car is only driven sparingly and needs to be brought in for "yearly" oil changes, there exists a fairly high likelyhood that that car will never reach the mileage limit on the maintenance program before the time limit expires, and that in turn means that the car may not wear its brakes out enough for a "free" replacement. My bet is that a couple of extra oil changes is WAAAAY cheaper than a set of brakes, so, why not throw them in as well. :P
If I come up with the notification regarding the one year rule, I'll post it.
Best Regards,
Shipo
I just called the Service Dept of my closest BMW dealer. The service advisor confirmed they provide a complementary oil change service every year, regardless of the service indicator. If the service indicator is reasonably close to zero, they will also perform the other services at the same time and reset the indicator. If the service indicator is still several thousand miles from zero, they only perform an oil change, and they do not reset the indicator. I asked if he had seen any TSB recommending against this policy, and he replied "no".
I also recall another dealer told me the same thing a couple months ago when I was requesting service information on a potential CPO X3 purchase.
So no deal today. Do your guys think I miss a good deal?
kc
I bought my 2004 325i for 20900 at Carmax with 35k mile with premium package and excellent condition. And got 5 year bumper to bumper full warranty for additional $1900 (There's a 50 deductible for that though). And that was a month back. Prices come down as the year changes since in Jan people will perceive it as 4+ year old model, and its regular 4 year warranty would have most likely expired.
Just move on to another dealer. I can't believe he was quoting $28,900 to begin with .. this is just a scam!
Also, who is underwriting this warranty? I assume this must be thru Carmax. If so, how is this warranty different from other 3rd-party warranties? For example, when you take your car to a BMW dealer for warranty work, how is the money for that warranty work actually paid to their service department?
With only 31K miles, I would also enquire on its original purchase date. In my opinion, a car originally purchased in July 2004 (with almost 3 years of warranty coverage and one year of maint plan coverage remaining) is more valuable to me than a car purchased in Nov 2003. KBB might not care how much free coverage remains on that car, but I do.
The ultimate determination is how much do you like this particular car? Is there anything about this car that stands out, in your opinion, from any other 2004 325i -- such as the color combination, or its overall condition?
Have you researched its maintenance and repair record? Any BMW service advisor should be able to look this up on their computer. All they require is the last few digits of that car's VIN. Also, you can ask to see the detailed 4-page CPO inspection report.
I disagree slightly with the previous response to your question, because I think the CPO process adds more value to the car in addition to the CPO 2yr/50K extended warranty. We just purchased a 2004 X3 3.0i with 27K miles, from a BMW dealer out of state. Thanks to the CPO certification process, this X3 was equipped with brand new brakes on both front and rear axles; 4 brand new tires; and a brand new battery. Anyone familiar with BMW maintenance will quickly point out how expensive the brakes cost to replace.
Here's my point: The CPO certification will require replacement of parts sooner than they would otherwise be replaced. For example, if I remember correctly, the dealers are normally required to replace brakes when the pads wear down to 2mm or below. However, at CPO inspection, they must be replaced if they are at 5mm. Hence, with a CPO car, you might get lucky and avoid/delay some maintenance costs you might otherwise incur with a non-CPO car.
Hope this helps...
Good question! My indie BMW shop has told me some real horror stories about 3rd party warranties that he's had to deal with- some want him to use "white box" or off-brand rebuilt parts rather than OEM or equivalent items. I'll take the BMW CPO warranty over a 3rd party insurance policy any day...
In terms of CarMax warranty, my MAXCARE plan starts from date of issue (10/12/2007) and ends after 5 years or 60k additional miles whichever one is earlier. Currently I have 36k miles on my car. I paid $1949 for it, and my warranty will expire on 10/12/2012 or 96k miles, whichever is earlier. The warranty is applicable anywhere on "any BMW Dealer". The only difference is that you play $50 deductible at CarMax and $75 deductible at BMW dealer. Also, the deductible is per visit and not per part/problem. So one can wait to go for the warranty service once you want a few collective items looked at.
I'm not justifying my purchase (Though my car is made in July 2004 and have 8 months manufacturer's warranty left, it has premium package, steptronic tranny etc.!). All I'm saying is that don't worry about that deal .. just be on the lookout - you'll get better deals.
I 100% agree with BMW certification. I'm sure the company CPO processs has to stand behind its reputation, but that does not make non-CPO BMWs bad .. maybe a just bit risky if they don't have a warranty.
This car has steptronic tranny and leather. The overall condition is very good. The dealer replaced 4 tires. It still has one year original warranty remaining.
I like this car because it's an off-lease and maintained by the same dealer.
I have done tons of research in the past month. It looks like different dealer handles CPO quite differently. The one I negotiated with only CPO trade in/loaner/off lease. But several other dealers in the same area would also CPO Corporate Fleet/Auction which I don't like. Some would replace all 4 tires. Some would leave the old tires with 60% tread.
I have access to Black Book. So I am pretty sure their cost can't be higher than $20K with all the mark up. I thought I gave them the right amount of profit. Obviously they don't feel the same way.
Probably start to look for 06 models if I can't find a good 04.
KC
Usage would be for business trips and travels with the wife.
Being a " car guy" I can't just go the usual practical Ford/Chevy/Toyota route as I enjoy driving too much.
Late model certified "3" looks like the way to go but I'll be choosing between thw AWD version and the RWD.
As a track driver in my 911, I've come to appreciate RWD an light weight for pure perfomance driving but livin gin the NE, AWD is attractive.
Do the AWD models eat tires faster?
Pleas help me choose. Inputs/Comments appreciated
http://www.tirerack.com/snow/preferredpackages.jsp
It seems like the preferred package is:
Bridgestone Blizzak WS-60 (Studless Ice & Snow)(4) 205/55-16 $416.00
Optional Road Hazard Program: additional $12.48 per tire
Sport Edition E1 (Bright Silver Paint) (4) 16x7 $396.00
Package Total: $812.00
A complete set for under 1k sounds good. Is anything else required to be purchased?
Nope; the package should come with lug bolts as well, so all you should need is a good jack, a torque wrench, and a-most likely- 19mm six-point deep well socket.
Unless you plan on tracking the car, it is a great daily driver with enough athleticism to make you smile.
The tires I have are Continental SSR A/W RFT's (run-flat tire) with 13K miles wearing dead even as I have rotated them every 5K based on the advise of the great board members who know a heck a lot more than me about cars. Best car to date for me. Try to get the sport seats if you can.
Have fun shopping and check out the RS4 if you've got the cash!
OW
Good point. I might just be one of them, although I haven't driven the "ZHP", nor have I driven the '07 3ers.
But, here's my $.02 worth:
1) I don't like how BMW removed the spare for the E90 platform, and now provides RFTs instead.
2) I was given a 2006 325i sedan (auto) as a loaner over a 3-day weekend several months ago. Although the cabin was a little more quiet and refined than my '05 325Ci, I can't say I would choose it over my car. It makes no sense given the HP differential, but my car seemed a little quicker. My car has a stick, but I'm not so sure if "stick vs steptronic" fully accounts for this perceived difference?
and the M3 sedan:
If the tii makes it to production with a limited slip I could see myself picking one up on the ED plan next year. As for the M3 sedan, I think of it as an updated E28 M5- and a perfect family car that can hit the track 4-5 times per year. But I think I'd still rather have a vintage M car.
Again...
I think I'll join you...
What will the Concept tii price be...mid-40's?
OW
Try to become a new bimmer owner in the next few weeks. I just saw a CPO 2006 325i today. The car looks very nice and the price falls into the right range.
But I have several questions hopefully can get the answers from you.
1. I have seen lots of complaint over the reliability, especially the tires, of E90. This car has Bridgestone R16. Do you think it would have the same problem?
2. The car has repair history. The description is "solenoid valve for camshaft adjusting unit dirty/blocked" Do you think this defect will cause any issue in the futher?
3. This car is only 14 months old. It has already had 2 owners. The first one is a local personal owner. The type of ownership for the 2nd one, from carfax report, is blank. I am wondering if the 2nd owner is the dealer. If the 2nd owner is not the dealer, it sounds odd to me. What makes a owner hold a car for 2 months and then sold it?
I might be a little over cautious. But you know, $30K is not a small amount of money spent for a used car. Thanks advance for all your advices.
KC
2) It is rather unlikely that the dirty solenoid valve will cause any future issues.
3) It is highly likely that the second owner is the dealership that currently has the car.
4) If the car has been Certified Pre-Owned (CPO), it sounds like a fair deal, if not, I might be inclined to take a pass.
Best Regards,
Shipo
OW
That would be my guess. I'm hoping Dakar Yellow and Henna Red will be optional colors.
Remember Sinclair? I believe there was a Brontosaurus on the sign in Henna Red print.
OW
And what's so bad about Henna Red?
Corvetts and Ferraris are bright red.
BMWs and Porsche should be be sivler,Black, white or even better some of the very cool blues or intermediate colors offered.
Internal bleeding can be serious. You should see a doctor right away! :surprise:
james
Thanks for your suggestion.
This is the car I am looking at.
http://www.shopautobahn.com/Flash/Used_InventoryFrame.html
After comparing the Carfax report and the warranty report, I find that this car was CPOed in July and was sold to a new onwer in Aug. Somehow after only 2 months, the car was back to the dealer. In another word, the car may not be a CPO, it is just a used car with extended warranty.
Do you think I should buy this car? Is there anything else I should watch out?
Thanks a lot!
KC
Look at it this way, there are LOTS of used 3-Series cars out there to choose from, and the best way to approach this is from a detached perspective. If you fall in love with a particular car before the rational side of your brain is satisfied, they you're likely setting yourself up for problems.
Best Regards,
Shipo
I agree with Shipo. There are plenty of CPO 3ers out there, so you can afford to be patient and picky. That said, if you really, REALLY like this particullar car you could always see if the dealer will give you the name of the previous owner. There are any number of reasons why the car was returned- and not all of them are bad...
Thanks for your suggestion. I test drive the car today. This time I looked at the car more carefully. It does not have the typical certified preowned sticker on its windshield. When I asked the sales guy whether it is a CPO car, he said it is and when the 2nd owner turn in the car, they would go through the CPO process once again. But when I asked him for the inspection checklist, the only thing he can show me is the inspection checklist dated on July.
I have the same thinking process as Shipo. I don't understand why someone would want to lose few thousands dollar in two months, which makes me feel really uncomfortable.
I like this car because it is only 1 year old. It has 3 more years original warranty and 2 years extended warranty which can minimize my operating cost if I want to keep the car for 5 years. But I think I'm going to skip this one and keep looking.
Several thoughts about E90
I really like its style. The key is pretty cool. The car is pretty quite and stable when I'm driving. I guess it's because the dealer change the tires to non run flat. Just like other E90 owners, I don't like the cupholders. Also I don't feel comfortable with the brake. It does not repsond quite well for some reason.
Shipo and roadburner, again really appreciate your suggestion.
KC
JR
I have been looking for my first CPO in the past couple months. I notice that different dealer handles CPO quite differently. Some dealers would CPO anything unless the car had accident before. Some dealer only CPO selected vehicles. So browse the dealer's inventory and compare with the Carfax report, you would probably know the standard of each dealer.
KC
From the previous posts, I've gleaned that you're all quite knowledgable with anything BMW. And so, I'd like to get your opinion.
Making my first BMW purchase this weekend (yikes!), previously owned a cute Toyota Corolla and Ford Focus. Finally decided to upgrade to a 2006 325 i. Have seen a few out there...ranging from $28K to $34K with mileage in the 20-30K range. Only interested in CPO. Pretty much no additional options, except automatic transmission. I'm going to try and negotiate for $25.5K. Do you think this is reasonable? I really think $34K is ridiculous, considering you can get an '07 for that much.
Two cars have caught my attention and I was wondering what people thought were fair prices.
Car #1: 2005 330i ZHP (performance package) w/20k miles (Private Party Sales)
Pretty much has everything on it, Sat Nav, Cold Weather Pkg, Xenon, all the creature comforts - just no automatic (of course)
They are asking $32,900 OBO which puts it over the PP sale using edmunds calculator.
Car #2: 2004 330i Ci Convertable w 33k miles (Used Car Dealer)
Automatic, Sports Package, Performance Package, Automatic, Xenon, Cold Weather Package
They are asking $28,700 which seems like a pretty reasonable deal (which is at Trade In value using edmunds calculator - initially suspicious given the low price).
Both cars have clean Car Fax reports, but will be taking either one to an indy mechanic.
Dave
I am about to reach a deal.
2005 CPO 325ci 26K miles, one lease return
Premium Package
Sport Package (but no 17inch alloy)
Black
Xenon Headlight
Leatherette
Asking for $24,500 which is about the same as Kelly Blue Book Retail.
Do you think it is a good deal?
A little bit info for the folks looking for a CPO. I happened to find out today that the MSRP for CPO is $1450 but the real cost for the dealer is $850. The dealer needs to do lots of work to bring the car to like new condition. However, some of the work are actually covered by original manufacturing warranty, which is free if you buy the same milegage and year car without CPO.
KC
The coupe comes standard with the sport suspension, but the Sport package includes seats and 3-spoke steering wheel.. If it really has the Sport package, I'd want the 17" wheels..
kyfdx, do you think it is a reasonable deal?
KC
I'd ask them to put 17" wheels on it... You'd probably get new rubber that way, also..
Forget the warranty info... Does it have sport seats (manually adjustable thigh pad), and the 3-spoke sport steering wheel?
