Hyundai Tucson Maintenance and Repair
Got problems? Got solutions? Discuss them here!
Does anyone know where the TCS button is?
I would never turn it off to pull out of a snow bank....
Good luck and best wishes. Let us know how you fare.
I just bought my '06 Tucson in August. It's been great so far. My only complaint is the stereo, which goes to a deep, bone-shaking hum/static when I pass under a bridge, under a gas station canopy, or at a car wash, particularly so when I'm listening to an AM station.
I pointed it out to the service department when I went in for a check engine light and was told that this is normal and that all cars do this. This is my sixth car now and the first to ever have this particular problem, so I'm not sure what I should do about it.
Is this typical of Hyundai? Am I getting the run-around? Is there a fix?
One of the prongs of my cup holder got pushed inside the centre floor console / armrest on my Tucson. I tried to remove the console and found 8 screws but still couldn't get the console out. I think I need to remove the power outlet at the back somehow.. any advice would be greatly appreciated, cheers.
Then see the dealer again.
My 2004 Volvo XC90 at 4400 pounds and with my faster driving style is still on the original pads at 45,000 miles!
Its the second Hyundai in my fleet and I can tell that they are cheap to buy but expensive to keep on the road....More so than the Volvo's. (I've got a 2004 S60 too)
Personally, it seems they are not addressing the real problem and buying time with the new battery. Time can be a real factor in the lemon law in the state of Ohio. If this new battery goes defunct 6 months from now, which is how long the other battery lasted, then this fourth trip to the dealership for the same "problem" would be over the one year period described in Ohio's law, should this come to pass, we will let you know. Please keep us posted on any progress you guys have.
I am near my 30,000 mile mark & took my vehicle in for an oil change & some other stuff. When I went to pick it up they said that since I was so close they went ahead & did the 30,000 mile maintenance & charged me over $500!! I wasn't prepared to spend that much this week. If I had known I would've taken it in when I was prepared! Help!
This FTC link may help.
Most states require a shop to prepare a written repair estimate - the requirements vary, and the law may not kick in until a certain dollar amount is reached (for example, $350 in North Carolina). If this is the case in your instance, most states have a consumer protection office you can call for advice or help.
The Edmunds Maintenance Guide will estimate what the 30,000 mile service should cost for your zip code.
It looked like everything was going to be ok...then on July 7th went to start the car and it was dead! I am going to make an appointment for it this week, but for now the charger is on it now.
I can understand sometimes after not driving it for 2-3 weeks, but it was last driven on the 3rd...
I like you love the Tucson, but not this problem! I will keep you posted if I find anything out this week.
The 2-days sit with no start is identical to my issue - then we would jump it and it would be fine. After 3 trips to the dealer, they discovered a batch of defective stereos were installed. They produce a drain on the battery. Stereo was replaced. It requires removing the dash.
Now less than a month later, I have no air conditioning in the upper vents, and a ticking noise when the car is started or when I switch to different venting on the ac. I am in my 4th rental in the last 3 months.
I bought a new vehicle for reliability... does all this repair time make me eligible for the lemon law/replacement?
Tucson owner, Tucson az
since then as the battery goes dead on the 3rd day if not driven. They have replaced the
battery and a module but now it is in the shop again. They can not find the problem
and they keep it for days and will not give me a loaner. I have since been in touch with
Hyundai consumer repairs and after threats the are giving me a rental for 3 days only.
I suguest that :sick: you call them also if you they can't fix your car. This has been a real
problem for many Hyundai owners. Have they found your problem? Good luck!
My 05 tuscon does this and is now in the shop for 6th time and they can not fine the problem and the Hyundai corp. is aware but will not do anything about it. I think it should be a recall on this as it is a large group. Let me know what happened with you. I think all of us who has this problem should write lemon on it and park it by there dealership!
This might get their attention! :mad:
We need a more reliable car than this!! We like many things about this car, but unfortunately, this battery problem will probably keep us from buying another.
When the AC started giving me problems in 105 degree heat, I had enough, and traded it in favor of going back to Toyota. I had more rental cars in the 1 year I owned my Hyundai than I had in a lifetime, due to the dead battery issue.
I do miss the tall ride and high clearance, but not the gas mileage or the unreliability.
Try the stereo replacement. A bad batch was sent out. Also, until that is replaced, don't let it sit so long.
Good luck!
Tucson, AZ
Thank you for your input we are taking your data into our dealership, when we hear their song and dance next week to pick up the Tucson.
dziak
The dealers are in there to make money and they will get it from you one way or another. When my car was 30K miles I changed all the fluids, eg. coolant, engine oil, ATF, Transfer Case, Differential, and brake fluid. I have also replaced the brake pads (I bought them like a kit), engine filter, PCV valve, caliper cleaning. I have also installed PIAA driving lights. The manual is also useful because recommended torque is given for the different tasks. Parts were order by me directly from the dealership and I have made use of the On Line Hyundai Parts site given (unfortunately the site has been removed by Hyundai without any reasons).
Because the car is near to 60K miles I think I should take the car to dealership to replace the timing belt, tensioner, iddler and V-belt in addition to the replacement of the spark plugs. I think I do not have the tools to do these jobs and also I do not have the experience and I will have to pay for the job. However this will be a specific job not a service (or routine service).
I am from Canada. My Tucson 1 year old and I am starting to feel the same problem with my transmission. The dealer could not find anything. May be you can give me information what country are you from, in which dealership and when the repair was done. This way my dealership can contact yours and may-be they can get any clue what should be done for fixing my car.
perah911@yahoo.com
How do I remove the dash board to access the switch assembly.
ray_h1, "Hyundai Online Shop Manuals Access" #, 21 Nov 2006 11:06 am
Online Repair Manuals
Removing the dash is pretty radical surgery that can probably (hopefully!) by avoided by some gymnastics under the dash.
The 2005 finally got the radio replacement that it needed, as the original radio would drain the battery if the car sat for more than 3-4 days. So, the 2005 is finally working and reliable. It was a very frustrating problem for awhile cuz Hyundai refused to recognize the defect. It took my college-age-daughter to demand more attention to get the radio replaced (she can whine better than I can). Supposedly the warranty was off, but the problem was well-documented in our service record, so they did finally cover it.
The 2007 Tucson had a sensor problem within the few few months that was taken care of and no problems since then. The Hyundai roadside assistance has been helpful, but luckily these problems have never been on a Sunday. The 2007 has been great in the winter weather with the stability control.
We love our Tucsons, and hopefully they will continue to be good for us!
Another thing while I'm on here, anyone else with the sunroof notice that when opened in the slide mode it stops about 6" shy of fully opening? I did the reset routine noted in the manual to be used after manually operating the roof with the crank but this changed nothing.
These are both minor glitches and I do have to say that if my Tucson was a person I'd marry it!
I have had the following items replaced on warranty in the past 3 months:
Radio/stereo
oxygen sensor
catalytic converter (took 2 months to get it diagnosed))
alternator
battery
I've also paid for a full brake job (which is probably about right)
No sooner did I get it back from the shop last week from the alternator death than it was leaking something... but of course when I went to the shop it did not drip for them, and they tried to tell me that the stuff I wiped off the pavement after it sat at work was from some prior vehicle.
Saturday morning, it boiled over and left me stranded out while I was bird watching.... 3+ hours to get a flatbed.... Managed to get a friend to take me to the dealership so I could get a loaner before they closed....
Is this a known series of problems ?
What else should I expect to go wrong ?
Any tips for getting customer service to to anything more than just fixing this thing 1,000 time over -
They are starting to sink some bucks into this thing, and because I have an extended warranty, there's still another 40k+ bumper to bumper to go !
-Beth the paranoid
