http://cgi.ebay.com/ebaymotors/Isuzu-Axiom-01-04-FRONT-Brake-Disc-Rotors-Ceramic- - -Pads-/360363194004?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AIsuzu%7CMo- - del%3AAxiom&hash=item53e751f694
If it runs fine at first, that doesn't sound like a timing belt issue. How many miles on the OD?
Get on the internet for parts, they are out there and there are breakers that have a good used parts inventory available, it just takes time. And there are always Isuzu dealers but with their heavy markup.
Regards
Bert
Follow the directions and you will see a complete online parts catalog.
Bert
Yeah I was the first one to do the shock swap and others followed and did some great documentation. It's all in the archives with all the part numbers you need. I did the swap my self and it took me about 2.5 hours. I had and used an oxy-acetylene torch and a high speed air grinder to get the shocks off and just cut off the active suspension wires to the shock tops. I think it was very economical compared to replacing the old shocks with the original type shocks and I like the ride better.
Regards
Bert
The oil is fine, and the radiator fluid isn't cloudy at all. The car starts running rough only after it has over heated. Really, it runs great until it over heats. There is no residue around the filler, but I did notice some coolant pooling on top of the motor by the thermostat. It has roughly 130k on the OD. I pulled the plugs as well and found them all to be in decent shape.
Search under SUV and Isuzu, and you will see about 15 vehicles.
There might be one close to you or worth shipping to you if the bids stay low enough.
Regards
Bert
Open up the thermostat housing and remove the thermostat. Put some gasket goop on and replace the housing. Go for a drive and see if your overheating is solved. Sometimes thermostats fail in a closed position. One could always hope for a simple solution. I'm sure you can find a thermostat if that is the problem. If not, it's got to be the pump.
Regards
Bert
I noticed the shock light is now own. Can you tell me how to turn it off completely? I can't find the fuse. Thank you.
For a more general discussion (although people post about problems too), you can try the Isuzu Axiom discussion.
Regards
Bert
Yeah, my clock and all the stuff on my display work just fine.
Regards
Bert
Hope that helps.
walk_the_walk2, "Isuzu Axiom Maintenance and Repair" #61, 16 Oct 2008 7:58 am
I have people also say that they like to look of my AX also. If I wash it and wax it it does look pretty good even next to a newer car.
Hope your new Honda works well for you.
Regards
Bert
http://i1139.photobucket.com/albums/n558/a9x2/Tag.jpg
A few of us (yours truly included) also figured out that, in spite of statements to the contrary by some dealers, you can replaced the crappy electronic shocks on this vehicle with standard off-the-shelf shocks like Monroe Sensatrac or other similar shocks.
There are several postings about this topic on this forum, as Bert did it first, and I followed suit, glad to get rid of the ISC crappola sproingy shocks that never worked right in the first place. Somewhere in the prior postings on this forum, is a detailed step-by-step set of instructions on how to remove your old Axiom ISC shocks and replace them with Monroes. You can pick another brand if you like - you do not have to use Monroes, but the instructions will be virtually identical.
The rub is that if you go to a tire and shock place, and ask them to replace them, they will look up your vehicle and not find a shock to fit it in their shock mfgr.'s catalog. But you can either get the Monroes, or cross the model number to a similar shock by another manufacturer. Find a premium tire shop that does work on racing cars, and show them the step-by-step instructions and they should be able to take if from there.
The other option is to order a set of four OEM ISC shocks from an Isuzu parts dealer - some of the best discount parts dealers are also mentioned in prior postings, if you hunt around for the info. But, I can't see why anyone would want to put ISC shocks back on an Axiom - the ride is much better with off-the shelf shocks. At least, that's my opinion on it.
I bought the regular gas type (nonelectronic) shocks at a NAPA store and had them installed at a Mieneke shop. (got better parts price at NAPA). NAPA.com lists the correct shocks to use on their website.
Probably any shock, brake service shop should be able to do the work.
I am happy with the result.
I doubt that the Monroe electrics will fit and why pay such a high price anyway? Besides if you could restore the original shocks you're just left with a crappy ride at a great expense.
Go back in the archives and look up the procedure to replace the Isuzu shocks with conventional shocks. You will save a lot of money and wind up with a better ride.
Regards
Bert
As for me, I am glad to be shed of mine. If you like that ISC feature, you will have to buy Isuzu shocks. I am not aware of any after-market substitutes.
My question is, where exactly is that speed sensor, a picture would be nice, and what does that sensor look like? Thank you so much for and help. EWP Pappy
To be clearer, there are speed sensors at the front wheels, a speed sensor on the rear end for the ABS system, and one on the tranny body itself, and possibly a few more if you have 4WD. All are shown and described in the Service Manual, which you can buy and download online.
Or, you can send me a private message to "inboxatbancca.org" (Only replace the "at" with the @ symbol), and I can send you the 3 pertinent pages, which show the sensors in question.
If I were you, I would take the vehicle to another mechanic and get another price right off, and also an opinon as to whether the dealer is responsible for possibly damaging your speed sensor when they repaired or replaced your tranny. What may be happening here, if it is the speed sensor on the tranny body itself, and I think this is the case, is that some Neanderthal shade-tree mechanic damaged your speed sensor during the tranny repair or replacement and now wants you to pony up hundreds to replace a sensor that probably costs $100 or less. I just hope they did not do additional damage beyond the speed sensor to other sensitive modules in your Axiom.
However, do your own due diligence on this. Since it's a 2002, there is the possibility that this is coincidental failure; however the sky high repair price leads me to believe otherwise. This is where finding another professional who can give you another estimate is crucial - otherwise you might want to repair it yourself. Looks like an easy swap out - not much harder than replacing an oxygen sensor really.
Last but not least, if this turns out to be the dealer, don't forget you can file a BBB complaint, a complaint with the attorney general of your state, or you can march them into small claims court for next to nothing. Just be sure to document your side first, if you opt to do this.
Mail is on the way.
For a better ride, be sure your tire pressure is no more than 3 pounds above the standard 26PSI. Regards.
Go Farther...
I live a couple of miles to work and normally I can start the truck and let it warm up a little and before I get to work, the heater is blowing hot air. On these really cold days I have driven for up to 30-45 minutes before the blower will start working. When it does, the air is hot.
The engine is up to temp but it seems dependent on cabin temp and not engine compartment or engine temp.
I've mentioned it to people. One suggested that I had an air pocket in my coolant and I pulled the radiator cap and let it run for a while to see if the bubble would come out and the coolant level change. No change.
Any Ideas? Thanks
I did find some leaves and debris in the squirrel cage when I replaced the heater blower motor with a new one, so in retrospect, if I had it to do over, I would remove (drop) the motor, clean out the debris, and lubricate it with WD40 or similar product, and see if it works WITHOUT replacing it. If it doesn't fix it, you can always buy a new motor. I got mine on Ebay from a wholesaler, as I recall for less than $50.
So, I hope the problem that you are having is either a problem with the motor bearing lubricant, which can be easily fixed for $50 by replacing the blower motor, and is not related to the temp sensors, or the Auto A/C PCU. One test you could try, since it would not be hard to do, is to wait for a cold evening, remove the blower motor, take it inside where it's warm, then bring it out in the morning when it's cold and reinstall it and test it. This would isolate the problem to the blower motor and its bearings, which by now are probably getting old. If it is the blower motor it is REALLY EASY TO REPLACE, as described in my previous posting. Check eBay to see if the fellow I bought mine from is still selling new OEM Isuzu blower motors for $50 or so, if you opt to replace it, as I think the motor is about $100 from a dealer.
Hope that helps.
Regards
Bert
I have taken the motor out to see if something was stuck in the squirrel cage and found nothing holding the motor. I vacuumed out the crap that was in the duct work just because I was in there. It was cold out and I gave the motor a twirl and it spun like a top. So I don't think it's a lub problem.
I DIDN'T know that there were 3 sensors in the circuit, a duct sensor, an ambient air sensor, and an in-car sensor. I felt that it was electrical all along because the blower would not spin at all and then all of a sudden it would work once the cabin temp got a little warmer.
It's now 50° to 60° and it works perfectly. I'll check into replacing the duct and ambient air sensors before it gets too cold out.
Thanks again.
regards. Kent
From experience and what I have heard, even if there is just a bit of oil on the dipstick, and it looks like it is terribly low, 1 quart will usually fill it up to the full line. Be sure you have changed the PCV valve at least every 30k miles. the maintenance manual does not mention when to change it, it but a clogged pcv valve will cause the engine to burn more oil so change. It is easy, it screws into the top of the left side valve cover. right side as you face the motor. the top plastic covering comes off the 4 rubber grommets holding to the studs. be sure you work the cover off easily, the grommets can fall out. ( they look like a well nut but without the metal nut inside. I lightly tape the rubber grommets to the cover they do not fall out when the cover is put back. Be aware of parts books that list and incorrect pcv valve. earlier Isuzu have a plastic push in pcv valve, but later ones, post 2001 I think they use a metal screw in one. I think all Axioms had the metal screw in one. Still easy to do.
Regards.
Ken
http://tinyurl.com/7n6rgna
