Pinched / shorted wiring harness to hatch ?
Malfunctioning security system ?
Try turning the hatch light off (and always on) and retry your temporary fix. See if anything changes.
Also, do you have any difficulty in getting parts for your Axiom ?
Thanks and Good Luck.
Once you try that. See if you can find the fuse for the security system and remove it as a test. See how things function.
Ultimately, you'll probably either need to have the keypad or alarm or both reprogrammed / replaced. Hopefully just reprogrammed.
How is your ease or difficulty in getting parts for your Axiom?
great site! thanks again!
I guess it wasn't the way I connected the computer mirror to the fuse box for power. This time when it didn't start, I removed a fuse and pushed it back in again,the car then started! Whether I have a electrical problem or maybe it is the alarm system that is causing this, like the guy who is experiencing the same issue in this forum, I'll have to start with the alarm system and disable it and see if this starter problem occurs again.
To disable the immobilizer to start the car:
1. insert the key
2. turn it to ON for a sec, immobilizer light will show (a car
w/embedded key, top far right)
3. then turn to START.
To enable the immobilizer while the car is running:
1. from START turn the key to ACC for a sec
2. then turn to LOCK
3. pull out key
If you can't start the car after trying to disable it:
1. turn the key from START to ACC
2. leave the key on ACC for 5 seconds
3. go to "disable the immobilizer" step 2 procedure
If the immobilzer light is flashing you'll have to take it to the dealer, to get it reprogrammed. With these procedures my car has been starting fine.
Stereo upgrade----JBL 6.5" speakers in all 4 doors---not too expensive---and makes a pretty big difference. I had them leave the stock tweeter components hooked up (I bought 3 ways for all 4 doors) so I have even better top end, and DEFINITELY more bass. But I went 1 step farther and had them install a Pyramid equalizer/booster (906VL). They mounted it on the side of the center console on the driver's side, and wired it into all 4 speakers. Now it really cranks!!! There is some ignition whine, but when you crank it up you can't hear it. You can turn off the amp/eq and it will work like stock. Overall, an excellent upgrade for less than $500.
Suspension upgrade---I had air bag suspension installed in the rear----bags that go inside the coil springs---with an air hose at the back that you fill at a tire air pump. It firmed up the ride (took the bounce and body lean way down), and took all the bottoming out of the suspension. In sport mode, it rides almost as well as my friend's 2005 Highlander. It also added 1000lbs of towing capacity.
Parts and installation $230.
That's it for now. Get in touch with me if you have any questions. CB
We have a wonderful place right here to "get in touch" and share ideas.
Also my engine light is on and the code it produces is 1120. When the mechanic looks up 1120 in his computer/books it says 1120 is a false code, anyone ever experience this?
As far as damage from running with the power mode on all of the time, the only thing I can think of is you are revving the engine to a higher rpm than normal, which is causing more wear. Also, more torque is being applied to the transmission causing more wear on it.
You may want to follow the Severe Driving maintenance schedule if you are going to use power mode all of the time.
Just my thoughts.
I don't know if it is the same problem but I had a similar situation when my EGR valve went bad. Engine would hesitate and stall. Bought a new one online, replaced it myself (10 minutes) and haven't had problem since. Did your mechanic give you the code?
Good Luck
Dennis P.
Dennis P.
When I did this I was abou 2 turn of the engine when it started revving up onits own from 1g to 2g up & down about 5 times I turned it off!
Then cranked it over again, nothing.
Hasn't done it since.
Whats up???
Im thinking egr valve or pvc valve? What do you all think!
I just bought it January 26th so I have only had it so far for 7days! :confuse:
Any help is appreciated! Thanx in advance!
Wild guess - build up of CO2 made the O2 sensor try to compensate?
SUVs and Smart Shopper
My Axiom started having similar problem and guess what the dealer said, engine wiring harness needs to be replaced! But it's going to be $616 (pt) + $834 (labor)!!!
So want to find out what happened to you finally? Or did you try what axiomguy suggested which is changing the EGR value?
Thanks...
oh and how much did you pay for yours.
is yours a piece of [non-permissible content removed] to>? :lemon: :lemon: :lemon: :lemon: :lemon: is what the hell i bought
One day, I left my lights on an drained the battery. Before that, I had been listening to either the radio, or the CD. Then I got a jump start from someone. I didn't try to use the CD until a few days later, and found that it didn't work. That's when I posted the original message.
I didn't get any information, and I didn't do anything. I was as bummed as you are.
A month or so later, I once again accidently ran the battery down, and needed a jump. Slow learner. Once I got the engine started, and driving, I decided to give the CD another try. An to my surprise, It turned on, and has been working ever since! I also have not run the battery down again.
So I hope you can get it going somehow.
BTW, for long trips, I now play an IPOD through a cassette adapter. At least the AXIOM has a cassette slot. It sounds pretty good.
Dennis P.
Sean
The brakes will make a wet rubbing sound when you stop if you set the hand brake when you park and leave it on. I set the brake when I stop and shift into park and then release it after turning off the igntion as long as I am not on a hill. This seems to prevent the rubbing noise and sensation. When I do park on a hill I have the noise / sensation of wet rubbing brakes for the next 3 uses of the truck. Then it dissappears.
The engine makes a quiet diesel ticking sound when running because it has solid valve lifters. If the tick is loud you probably are low on oil. Pull the stick when the engine is cold and off. If the ticking is very loud and you have enough oil, you may need a valve adjustment, but this is unlikely unless you have a very high mileage on the engine or unless it has been run with low oil for a very very long time.
Hope this helps you folks.
Trying not to spend the big bucks on the active shocks. Besides the sport mode seems too stiff and the non-sport mode too slopy.
Regards
Bert
Good luck
Bert
NonieRS
Any ideas?
Dennis P.
That's not always true in real life, but that's the theory.
Let me know how it turns out.
Also if your transmission begins to silp in 1st and /or 2nd gear (automatic) this is also a warantee problem and is common in the 2001 - 2002 French made transmission. There is an accumulator seal that begins to leak. It's another easy fix but initially the symptoms will freak you out. So keep this in mind.
Regards
Bert
This problem started out of the blue, went on for three or four days, then never happened again. Strange.
Best regards
Bert
thanks.
