I am hesitant to continue to take it to dealers. I don't have the time to waste with them telling me they cannot find any issues. It almost sees like Jeep/Dodge/Chrysler is penny-pinching everything even when it comes to checking out warranty problems.
SUVs and Smart Shopper
Any advice?
(BTW, i concur with the many discussions about lacking power, surging, and sluggishness that i have read in theses threads)...
My advice is sell it before it eats you alive.
lucky i have mechanical breakdown ins with geico they will pay minus 250 deduct. just wondering if its true that they replace the entire trans rather then the valve body and it's components.
The MPG was 20 to 24, but generally 21 mpg. The seats were hard abd stiff, the CVT had the engine going up and down constantly. The engine was loud and the car has no coasting, when you took your foot off the gas the car quickly slowed down almost no glide at all. The dash was a misture af ten or more parst the had huge gaps. The plastic was cheap and hard. There was no place to touch that was soft, not even arm rests. SAY NOTHING OF THE MOST GUTLESS 4 CYCLENDER ENGINE I HAVE EVER DRIVEN.
I took a royal beating trading it in, but we hated the car. Our Pacifica gets better fuel mileage that that cheap Compass.
MY ADVICE "DUMP THE COMPASS" hOWEVER THE QUALITY OF THE INSIDE IS MUCHED IMPROVED IN 2011
A few days before this, my electronic locks quit working and now my dome lights do not light up now.
I'm looking at picking up a 2007 Compass and I am wondering if you still have yours and if you have encountered any further trouble with it. It appears that most problems listed on the forum seem to have occured relatively early on in the life of the vehicle. I understand the issue of the "leaky sunroof" which seem to be the bulk of the concerns, but I am wondering if you have encountered any other issues with the Compass now that you have really broken it in.
Second time they said it was bad fuel pump. $100 warrant deductible. Waited over 2 weeks to get a new one? (is there a recall on these?)
Third time 12 hours later the same thing happened while driving on the highway. Had to wait 2 hours for a tow truck. (from the dealer, should have called AAA) This last time they are saying someone dumped something in the fuel tank.
And yet all three had the same symptoms. Any ideas or assistance would be very helpful. I am not getting a warm fuzzy from these guys at all. She is a single Mom and can't afford to get screwed over.
So is this plausible or is it just a Jeep?
Thanks for any ideas here.
Yes, I still have my '07 Compass (bought Sept. '06) and I just rolled through the 110,000 mile mark.
My one and only issue was the alternator bearing going bad. I replaced the alternator and the tensioner/idler and have not had an issue since. Perhaps I got lucky with my Compass, because mine has been a great car with none of the other problems described here on the forum.
During my recent oil change I discovered that both front struts are leaking, which isn't a surprise, given the miles driven, the condition of California roads, and that fact that I have been off-road to many a mountain top in it.
I plan on spending a little over $400 at Les Schwab Tires to replace both front struts with Koni struts, and they have a lifetime warranty.
I ask a lot of my Compass and consider myself a happy customer.
Cheers,
Andrew
About 2 months ago, the day after about an 800 mile road trip, my ETC light came on as I was leaving my driveway. Complete loss of power and could not accelerate past 20 mph. I turned the car off, let it sit for a mintue and restarted and everything was fine. I attributed the issue to the long road trip and didnt pay it much mind.
About 2 weeks ago, upon starting the Compass, the ETC light would flicker and be gone and everything drove just fine. I had the codes pulled just to get an idea of what might be going on and the code came bacl "running too rich" (dont know the code number, just what the guy told me) At this point I had the computer "flashed" and the car ran great after that.
Then, just yesterday while I am driving with my 6 month old daughter, the Compass completely gives out on the road. ETC light on, flashing ESP light on. NO acceleration, and when I came to a stop, the engine was running so rough it felt like it was going to die. I turned the car off, restarted it and same thing happens. Luckily I made it home and decided to have car towed as it was pretty much undrivable.
Mechanic could not find the issue for the longest time. First the changed the spark plugs (as one was loose) and that has not fixed the issue. Now they tell me I need a NEW pcm, with parts and labor will run me $850. I called my dealership and they can do the same procedure for almost half the cost. SO needless to say, I need to shop around here.
After all this, my question is: what the heck can I do about this ETC? Just reading on this forum it seems like the kiss of death. Do I really need a new PCM or just a software update? Any feedback is much appreciated and I can give you more of the car's symptoms if you need.
PLEASE HELP!!!
Anyway, local comprehensive insurance rates are sky high so I'm looking to cut costs. After a lot of internet research, I've read about the RAVELCO engine immobilizier which claims to have a perfect record over 30 years of NEVER allowing a car to be stolen by driving it away! No protection against towing, obviously.
Does anyone with this Ravelco system care to offer any feedback about it? I also plan to use a deadbolt hood lock and heavy duty Unelko brake pedal jack lock to layer my security.
Typical car alarms are ignored. Lojack and GPS tracking don't prevent theft, just track down what may be a stripped or destroyed car, and very expensive. The Jeep comes with a coded ignition key that I've read can be bypassed by thieves using laptop computers and car remote decoders.
Does anyone have a better solution, short of a 24-hour armed guard, to secure their car?
on my car I am very nervous, I needed a new computer module ( $1,400 ) at 125,000Km.
I have spent over $2,000 on ball joints, tie rods and struts and to top it off I now need a muffler
available from Chrysler only for a mere $725.
I have spent more money on this car than I have spent in the last 60 years of driving.
Having driven Jeeps without problems I can honestly say this is the worst car ever made !!!.
DO NOT BUY A JEEP COMPASS
Honestly... I have come to the conclusion that most of the parts that Jeep/Chrysler/Dodge use on their vehicles are crap. The only reliable things they produce are their diesel engines (mostly from Cummins) and the flag-ship engines (ones regularly used in a large variety of vehicles).
Electrical... crap. Transmission internals...crap. Drive components... crap. Suspension parts... crap. Engine, mechanically speaking... will not die, but might not run because of the other crappy parts attached.
I have given up hoping for a train to hit my car, someone to steal it, a hurricane to flood it, or any similar situation to relieve me of the Jeep disease. I might just as well keep it "content" and running until its paid off.
I know this will stir someone's exuberant I-love-my-Compass attitude... so in all respect, don't get your internet-arguing-panties in a bunch; its just my honest opinion.
I sold it and had enought to buy a used car.
I contacted the dealer and brought it in, they had it for 2 days and finally the second day the assistant manager of service told me he experienced it and that the car does sit there and laugh at you when it happens, he said he contacted chyrsler engineering and they have no fix for the issue, he also said they told him to do an update on the PCM and reflash the computer, he said he did and it still does it. They cannot get any error codes and the transmission shift points, the transmission and everything else is fine.
I then talked to the service manager who was right away " the 4 cyl will not have power with the ac on" I explained the entie issue to him and he said "bring it back in and we will take it for a ride."
Basically the dealer is trying to say its normal for the compass and thats that, I have owned 4 cyl 6 cyl and 8 cyl cars and trucks, I know the difference between sluggish and not working right and I m not sure what else to do, besides the lemon law, or possibly suing the dealer ship.
Does anyone else have this issue? Know of a fix? Any help would be appreicated.
If I hadn't rolled my previous loan into this one I would have gotten rid of this Jeep a long time ago. Although I could trade it in now with 90,000 miles on it, I will just drive it until it dies since I enjoy not having a car payment, or until it actually stalls and puts my life at risk as others have stated.
The only great thing I can say about this vehicle is that it gets around really well in the snow and slush, even when it's not in 4 wheel drive. Other then that, I wouldn't ever purchase another one or recommend to others. :lemon:
