Just got a 7-pin to 4-pin connector from my 4Runner to my boat trailer from my Toyota dealer yesterday. Haven't hooked the trailer yet but this should work fine. Thanks a lot for your response.
Raul
Good thing you are going to replace the factory hitch. I have read on several other boards that the V6 hitches are not built for a WD hitch setup.
Also, I have read where the later model 4Runners with the V8 hitch can fit no-problem on the V6 model. Those are made for a WD-hitch setup.
Also, remember your tongue weight (My 05 I believe 750 pounds). Good choice on he Prodigy brake controller, they are most highly rated!
Good luck!
I got my new WD hitch (like the one used on the V-8 4Runners) and installed it yesterday.
So when I was installing I ran into a few challenges. First, the factory hitch - unless you remove the bumper cover - is a pain to remove. There are 4 bolts that are behind the cover which give you very little room in which to operate - like 15 degrees or so. Takes forever to remove these 4 bolts.
That just took patience (and tired arms) to overcome.
I ran into two other issues. One is the electrical connection - is there a new bracket to use or a longer pigtail from Toyota that I need? Right now the thing just wants to hang there, and it just doesn't look finished to me.
The second is on the right side where the hitch mounts in its frontmost points, the tailpipe is in the way. How do I move the tailpipe so I can slip the 2 frontmost bolts into their threaded holes? The tailpipe is hanging on a rubber piece, but I didn't see how to remove it without breaking anything (which is what I usually do).
Any suggestions?
John
By the way, I don't recommend buying a Curt hitch if you ever do this, because while the hitch is really well made they forgot to create a place or bracket to which the 7-round connector would attach. I was able to attach the stock Toyota bracket to the frame after installing the Curt hitch, but I couldn't attach the connector to the bracket using the two holes/screws designed for that purpose because the hitch was in the way of the connector. So I zip-tied the connector to the bracket through two holes on either side of the connector, leaving about an inch of slack to allow clearance for the connector hood.
It actually works just fine, but it's not what you would expect when buying a new hitch.
Get a Draw-Tite or a Hidden Hitch instead.
I was advised (by other froums) that this could cause extra electrical resistance and problems with my brake controller. This never happened and it's been over two years.
I do wonder though if I ever get caught in the rain if it would be problematic. So I might (one day) go down to Autozone and buy some of that "electrical conducting grease" and take apart the extension and grease the leads.
Happy Camping!
It turns out the SR5 4WD 4Runner tows pretty well considering it's just a V-6. We towed a Haulmark 20' Thrifty Hauler with 500 lbs of stuff in it (total weight 3825 lbs) about 2200 miles without any issues. Yes, the V-6 was hurting in headwinds and hills, but on the flats it did well. Using premium fuel we managed to get 10.5 mpg average for the entire trip. There were 2 tanks at only 6 mpg, but we also had tanks at 12 mpg, so it varied considerably depending upon terrain and wind. We averaged 55 mph for the trip including our stops, which were frequent (15 fill-ups).
The Equal-i-zer hitch made it an easy experience and did a good job of minimizing the effect of semis flying by; it could not entirely eliminate their effect. Particularly if the difference in speed between the overtaking semi and our rate of travel was 10 mph or more, the 4Runner would get sucked towards the semi as it passed. More specifically, when the front of the passing semi got even with the front of the trailer we would get pulled left into the semi. I learned to anticipate this (steer right) and that made it manageable, but found the safest way to travel (if the least fuel efficient) was to try and keep my speed up close to the posted limit (although 65 mph was all I wanted to go). That way the difference in speed was low enough that the pressure wave coming off the front of the semi wasn't powerful enough to suck us in as it went by.
There's no doubt the V-8 version of the 4Runner would've towed better, but my normal tow from now on is less than 50 miles each way and very flat as well, so it won't be an issue.
Thanks for the knowledge sharing and assistance. It helped to make our trip a safe one.
Oh, and one final thing. The Curt Hitch is fine - just get a bracket for the connector from etrailer.com or any good towing supply store. You will apparently have the same issue I had using any after market hitch.
Happy towing!
I am relocating around 500 miles from NY to MI.
I am renting a 16 foot truck from Penske/Uhaul for my 2 bedroom furniture but would like to tow my 2006 Toyota 4runner LTD behind the truck probably on a car carrier.
Neither company would allow that saying the 4runner is too heavy for their trucks to tow. size wise I measured it and it should fit on their car carrier just fine.
Penske website states the car carrier Load Limitations is 4050lbs, the Toyota site states the weight of the 2006 4runner is:
gross vehicle weight rating (lbs) 5,330, curb weight (lbs) 4,045.
I also was reading that the 18 inch wheels are too large for the car carrier. I believe my 06 4runner LTD has 18 inch wheels.
What if I rent a 22 foot truck and leave half the truck empty to compensate for the weight of the 4runner? I would hate to have to fly one-way back and drive the trip again with my car.
Any advice is highly appreciated. I considered towing the 6'x12' trailer from uhaul but my furniture wont fit in there and the wife wants it ALL.
Mike
SUVs and Smart Shopper
Good luck!
Is it safe to make such a long trip with this equipment?
What kind of hitch would I need to install?
Do I need a cooler, etc?
I've never towed anything, so my concern is that I may damage the car. Any suggestions would be appreciated. Thanks.
They still won't connect the trailers to Ford Explorers even though it was the tires and not the vehicle.
It looks like by the specs you provided you should be OK-but check your owners manual. Make sure your tires (especially in the rear) are at maximum inflation. DO NOT EXCEED 55mph. The tires on the trailer will not handle sustained highway speeds and high heat...they will blow for sure.
I tow a 21 foot travel trailer w/ an '05 Sport V8 (2WD). It has a tongue rating of 750 pounds and a total weight of 7,500 pounds for towing.
A transmission cooler and fresh transmission fluid is never a bad idea.
Good luck!
Make sure you have a weight distributing hitch such as an Equalizer, Pullrite, etc. When you have this follow the manufacturers installation instructions.
In a nutshell after the WD hitch is hooked up to the 4Runner the front of the 4Runner should be within an 1" of what it was PRIOR to hooking up the trailer.
This procedure will determine if you need air bags in the back.
I tow a 5,000 pound 21 foot trailer trailer with a rather heavy 750 pound tongue weight and it does fine without airbags.
It does however have the X-REAS cross linked sport suspension system. If you have this system you will not have a problem. BTW- I am assuming you are not exceeding 21 feet in trailer length. At 109.5" the wheelbase of the 4Runner can't handle anything longer safely..
The V8 has plenty of torque and is a great (if not a bit noisy) motor.
Let us know what your suspension system is.
Happy Camping!
I just went through a lot of trouble to find out about my '06 4runner V-6 and got a lot of misinformation from dealers and their parts depts. Finally, I got through to Toyota and was told that I didn't need a transmission oil cooler added because my 4runner has a towing package. As far as other questions I got my answers from good sources: go to Toyota website.
Jody Colorado
Jason
Good luck!
Any ideas? I know my 4Runner is not ideal for what I want to do, but need to find a way, if possible, to make it work for limited distances and low speeds.
Does any
Number One - you have to switch out the hitch on your SUV. I am told the one from the V8 bolts in, but please check. Or, you can buy an aftermarket hitch that can handle a WD device.
This is the WD device you should use after you switch out the hitch-
http://www.equalizerhitch.com/
This device distributes the weight across the axles of both your trailer and the rig.
The V6 hitch cannot handle the downward pressure and must be switched out.
I tow a 21 foot(5,000 lbs.) travel trailer with the Equalizer WD hitch on my '05 4Runner Sport V8.
Here is the hitch info-
http://www.racepages.com/products/?Ntt=Toyota+4runner+Hitch&N=4294963058
PLEASE NOTE-TO TOW SAFELY THERE IS NOT A CHEAP WAY OUT OF YOUR SITUATION!
I currently own a little 4x6 but I'm considering something as long as 16'. I'd plan to install trailer brakes for the larger trailer. Thanks for any insight you can shed.
You may want to think about a transmission cooler too if you don't have one already.
You can check out towing laws for the states, provinces and territories here.
Have a safe trip!
Did all V6 4Runners come with factory non-weight distributing hitches? Is it bolted to the bumper or axle?
Would I have to replace that hitch with a weight distributing one or is it an add-on? Two anti-sway bars came with the trailer and its GVWR and GAWR are 3500lbs. with standard equipment. It lists a standard built dry weight of 2670lbs. with a hitch weight of 230lbs. With some optional equipment, four passengers, camping equipment, etc. could I get by with a V6 with a weight distributing hitch and additional coolers or would I have to go with a V8? Thanks, Ruth
Take your VIN down and call Customer Care at Toyota, they should know.
http://wiki.answers.com/Q/What_is_gvrw
If your going to tow this boat and passengers with some cargo on a regular basis, I would suggest looking at a Full size 3/4 ton pickup. Look at the GVRW - it's a yellow sticker on the driver's side door jam. Also, I would assume the weight on the boat is the DRY WEIGHT. Once you add fuel, and other items it's going to be more.
I tow a 5,000 pound travel trailer with an 05 Sport Edition 4Runner w/V8. But it's rated at 7,500 pound towing. And my wife is the only passenger. Toyota, IMHO really blew it by not offering a V8 with the redesign.
Good luck!
If your in an accident, and even if in your tow rating, BUT OVER GVWR you have big problems.
If your towing-you need a cooler. In addition, if your going to use a weight distributing hitch, you need to check to see if your receiver can handle one of these. At some point Toyota started putting receivers on that can't handle the load of a WD hitch. (I believe it was after '06)
If your trailer has electric brakes, you will need a brake controller mounted in the 4Runner.
I towed a 21 foot -5,000 pound travel trailer for 4 years with my '05 Sport Edition with a V8. The 4Runners are OK tow vehicles, the 110" wheel base however never gives you the confidence you need while towing. At 98,000 miles (it still ran great) I traded mine in on a Silverado, it's a much better tow vehicle.
Check your owners manual for maximum towing capability and DO NOT exceed 21 feet in length for your trailer.
Good luck!
So, even though the dealer is stating the car DOES NOT a transmission cooler, you think it does? The dealer claims the car is good, as is (without the cooler), and it doesn't need one to tow.
Dealers know nothing about towing. Are you ready to put the safety of your loved ones at the knowledge of the dealer? Please read the following:
http://www.nhtsa.gov/cars/problems/equipment/towing/towing.pdf
Your also going to need an electronic brake controller, I would suggest the Prodigy brand.(www.etrailer.com) You can go to the Toyota dealer and buy a factory wiring harness to connect it, it makes it very easy.
I would suggest no longer than 24 feet, that is the maximum length that should be towed with a 109.5" wheelbase vehicle.
If your towing with 4 passengers I would highly recommend purchasing a bigger SUV or truck. You can get $9,500.00 off sticker on a new 1/2 ton Silverado, that is what I bought to get a proper tow vehicle for what I needed to tow.
BTW-there is alot of info out there-google is your friend.
