Mazda CX-7 AC problems
Smoking is bad for your vehicle's health. Is your's smoking? Discuss it here.
That may be condensed water vapor due to low fan speed setting. This is common if fan speed is low and outside humidity is high. This does not explain and smell though.
What's got me puzzled is that when recirc is off, I've discovered the A/C is completely useless. I've enjoyed riding around with the recirc off and sunroof cracked in every car I've ever owned, but when recirc is off in the Mazda, it's unbearable on hot days. It's all very ironic since the owner's manual stresses two or three times that "recirc" should only be used for cooling down the car and that the "normal" M.O. should be with recirc off. :confuse:
Vince.
-c92
Its normal...
Vince.
On a similar note, I would agree that the A/C is pretty weak if it's not on recirculate. Unless it's at night, there's pretty much no time of the day in the summer that the fan's not on "two" and the recirculate button isn't on. The A/C has been my biggest disappointment in this car!
Have noticed two problems recently.
1- Just climbed Mt. Whiteface Alt. 4,800ft. Began to notice an odor of combo hot oil and rubber on the drivers side. It soon disappeared.
2- Does anyone else get their feet roasted from the firewall?
That will be great in the winter, but now?
Thanks for any suggestions.
NMK
Was that on the way up or on the way down?
About 1/2 way up, stopped because my wife was a bit ill because of the washboard road and she was driving. I noticed this as we swapped driving positions.
I left her at a rest table and continued to the top. Checked again and it disappeared.
Have any other CX-7 owners experienced anything similar?
I'm beginning to think this is also why the A/C, when it is not on re-circulate, performs so patheticly in the summer. I'm glad for this forum so that I can see that it's not only my car! I'm taking it in next week when it's cool again to get the dealer to tell me what's up. We'll see if they own up to anything!
I did notice that my "winter" thermostat setting on the auto A/C will have to be a few degrees different than the "summer" setting, but it's the same story at my home, so I can't blame Mazda for that.
"Selection of A/C and A/C ECO is
done automatically. Although air
conditioning and defogging ability is
reduced, the A/C ECO function is
designed to economize use of the air
conditioning system."
Vince
looking at buying a CX7 in Australia. I'm most concerned about the issues with Airconditioning performance (or lack thereof).
I've seen some posts that talk about it being ineffective when not using Recirc.
And also have seen that it blows warm air when on fresh-air (non AC)
Is there any way of bypassing the 'auto- ECO' setting? I saw someone's post about the ECO setting on the Mazda coming on automatically but diminishing cooling performance.
There's no way for me to test this at present as it's coming into winter here. But our summer (Nov- Apr) is very hot
many thanks as I'm really worried about this and it's probably enough to make me wait for the Rav4 V6 which is not due for 3 months at least (but I suspect would have a good AC system)
S
As a another resource, you might want to try http://www.mcx7.com/. There's a section devoted to Australian drivers of CX-7's. You might want to post your question there.
Vince.
thanks for the reply
The model I'm considering is the 'luxury' one, so has the Climate Control
Guess I really wanted to check whether the AC system was any worse than any other modern passenger car?
My Toyota Camry's AC is quite good, though I still keep windows down for a few minutes after startup. But I don't think I ever need to use 'recirc'. (it's only a manual AC system)
What about the issue of warm air coming through the vents (when the AC is not on)?
cheers
Satz
You'll need recirc on the CX-7: I live in Texas, where it gets hot and my black leather soaks in heat through the huge windshield. A screen helps considerably, but the CX-7's system is pretty well taxed and underperforms other systems I've owned. I'm not giving up on it yet... but can understand why they may be so conservative with the recirc mode in the auto climate units...
-c92
I finally went to my dealer and FINALLY resolved it. After they upgraded all the software in my car, it is now super cool even when it is 90 degrees F/ 33C outside.
The service manager said many of the earlier batches of the CX7 had old software revisions which likely did not control the AC temperatures properly.
I have also noticed slight improvements on the automatic gear shifting responses.
Koroshiya,
Do you happen to have the TSB number for that problem with the A/C? I just spoke with my service guy and he says he not aware of any "software upgrade" that regulates the A/C.
Thanks, Vince.
Nel
Vince.
glad to see the AC issues were rectified. I read thru the TSB and it seems to say that only cars built before Oct 06 were affected.
Was your's built before then or after?
cheers
Satz
Vince.
I am worried about A/C issues especially in the back seats.
We live in texas and my 20 month old son gets really hot if no direct air circulation hits his face and neck.
Did anyone have a bad experience being too hot in the back seat??
Appreciate all feedback.
Just forget trying to run the the A/C on fresh air mode because the turbo seems to heat the cowl to a point where the A/C can barely overcome it.
The vent on the driver's side is rather weak in my car but I suspect that's just my particular car. I'll mention it the next time I have the car at the dealer for an oil change.
Still, Mazda should've provided vents in the back. I think it's chintzy that they didn't.
Yes you can say that again (Chintzy that they didn't put vents in the back). My friend has a dodge magnum and it is smaller then the CX7 and it has back A/C with controls too!!
A local dealer is offering $5500 off any CX7 2007, and they have attractive lease packages for 24 & 36 month (179/m for sport & 239/m grand touring) you can't beat that... they are trying to get rid of their 2007's most probably. So I am going to test drive one tomorrow and maybe lease it...will add DVD screens in each head rest & probably add chrome wheels too...
We have the same Issue that everybody here has, the vent throws out air much warmer then the outside air, in fact even when its 55 degrees outside the vent air feels like the heater is on a low heat setting. The only way around this is to open your windows up or throw on the air conditioner. The issue I believe is this; the turbo motor warms up the motor and vent tubes so much that the air conditioner has a hard time being efficient (its not). It's especially bad after you drive the car, go in a store, and come back out and start driving again. The first few times in for service they told us there's no problem, but we persisted that there is. I read here about climate control module and our car was old enough to have that issue. They replaced it and still no better. Once, we got back in the car after it sat for about a half hour and we drove it to our next destination 11 minutes away and found that the warm air through the vents was warm the whole 11 minutes long only just starting to get a little less warm. The temp outside was cold enough that you had to keep the windows closed (maybe 55 -60). A $30,000 vehicle should not have a defect as big as this one is. Maybe if we all call Mazda USA and complain, something may get done.
We will let the dealership look at it one more time but I don't have much faith as I believe this to a design flaw of Mazda’s and they don't want to admit it or recall it.
Thanks, Carey C.
I have exactly the same problem as you. After parking the car swtiched off for a few minutes and then driving again, the vent air is horribly hot. This affects the AC performance as well. Takes ages to cool down.
I too think it's the heat soaking in from the turbo. I think this is terrible as I've had turbo cars before, which had wonderful fresh air at near ambient temp and AC that was cold.
I just can't work out any solution to this problem which is so bad I hate driving this car anytime it's warmer than 30C (85F)
Today I measured the temps coming from the vents. The ambient air temp was a cool 20C, but the vent air was between 30 and 40C, which of course means you're heating the cabin rather than providing fresh cool air.
He did say that if enough people complain to Mazda USA directly and if there are enough complaints they might do something about it.
Not likely because the people at the dealership and the people at Mazda USA that I’ve talked to, make it sound like its really no big deal and what are you complaining about
It’s only a $32,000 car anyway
For the AC/warm air issue, it is more prevalent if the temperature outside is more 28C/82F and sunny. When it's that hot outside, it can take the AC 10-20min to even cool down with the car running.
As for the warm air without AC on, nothing you can really do about that. Just roll down your windows.
Good luck
