Your environmental controls are designed that way. Little is gained by turning off the A/C. Your auto A/C is designed to maintain humidity in the cabin as well and it keeps the humidity down in the winter. In your previous cars, have you ever noticed your windows fogging up when it's raining? With the environmental controls, fogging is pretty much eliminated.
If it's 5F outside, you likely don't need the humidity reduced THAT much, and you stand to increase your mileage by not having the compressor load on the engine.
That being said, you have to make a choice if that admittedly small fuel savings is worth twiddling with HVAC knobs the "old-fashioned" way in order to keep a temp you like. I just got back from a 1200-mile round trip and did it both ways, but couldn't compare mileage because going one way, the trailer I was towing was empty - going the other way, it was full.
This is my first time ever posting so please be gentle. After years of blog lurking, I have decided to break my silence after what happened to our DEFECTIVE AC Compressor at 38,000 miles.
We bought our 07 Mazda CX7 in July 06 to bring with us to Italy and use to travel Europe. We have loved our CX7 and have taken it everywhere. BUT, that all changed on Tuesday morning when upon exiting the highway we noticed a hot burning smell (like oil and rubber mixed with electrical). We pulled onto the base and put the car in park. This is when smoke billowed from under the hood (my children ran from the car as the smoke was so thick they thought it was on fire). After clearing it out, we experimented with the car driving with no heat fan, progressing to defrost high fan and low and behold more smoke! So we took it to the Autoport where they were surprised to see a new car with an defective AC Compressor! They temporarily fixed the problem by bypassing the unit, which helped with the smoke but it still rattles terribly at low speeds.
Now, here comes the kicker. When we bought the car we asked the dealer if the warranty was valid in Italy. The manager said yes it was, I asked him that before I sign anything he call Mazda directly and verify that the warranty would remain valid. He did this - right in front of us (or did he??). Now Mazda USA says that the warranty is void because we took it out of the US/Canada. Not that it matters too much because we are at 38000 miles.
The point in posting this is that we noticed about 5 months ago that the ac was getting dimmer and that the air wasn't pushing through as strong. Since it was fall, we thought we would figure it out in time. Reading all of your posts that you have notified MazdaUSA, makes me wonder why when I called them today they stated that they hadn't heard of any AC problems and that I will be stuck with the likely $1,000 (if I am lucky!) bill. If the unit is recalled later I can submit a "request" to be reimbursed if we meet all the requirements.
Other than this recent episode though, I wouldn't trade my CX7 experience for anything. I am just hoping this will be resolved satisfactorily.
Most modern car A/C compressors (non GM) are good for at least 100,000 miles. However if it is run for any period of time with a low refrigerant charge the life will be greatly shortened. When we use our systems in defrost mode, or auto climate it is more difficult to realize that the cooling is below normal. Weak A/C output can be a sign that the refrigerant charge is low. This will cause the compressor to short (rapid) cycle on the low pressure switch and burn up the compressor in a few weeks.
"aside from the warm-air problem, which is apparently an uncorrectable design error,...."
NOT...!!
Bean-counters have struck,....AGAIN....!!
The "warm-air" problem you are describing, experiencing, now exists throughout the automotive industry, going back to the turn of the century, even in many upscale vehicles such as the Porsche 911/996 and Lexus RX series.
The hot water, engine coolant, flow control valve to the heater core no longer "exists". Most new systems now rely exclusively on the reheat/remix blend door/vane to regulate the level of heat the airflow cooled by the A/C evaporator gets before it flows from the system outlets.
Engine coolant is close to 200F and therefore so is the heater core. A heater core packed VERY TIGHTLY under the dash inside the air distribution plenum. Leave the vehicle parked for a brief period after the engine coolant is in the normal operating range and of course the "elements", A/C evaporator included, surrounding, within close range, of the heater core will fairly quickly get HEAT SOAKED.
Drive along with the A/C off expecting reasonably cool incoming airflow from outside and the airflow temperature will be raised due to the radiant heating from that ~200F heater core nearby. Even worse if you should leave the temperature control setting at anything other than MAX COOLING. Only with MAX cooling will the blend door be completely closed preventing even a small portion of the incoming outside airflow from being heated.
The DIY solution for my '01 AWD RX300 was quite simple. Go to Home depot and purchase/install a water flow control valve and manually shut off the flow to the heater core during the cooling season.
To get the best fuel and A/C efficiency during the cooling season always use recirculate mode, MAX cooling (reheat/remix vane/door FULLY closed), and then use, adjust, the blower speed to regulate your comfort level.
Correct me if I'm wrong, but I seem to remember that both the low pressure and high pressure (high hysteresis on/off) shutoff/disable pressure switches are in the high pressure "circuit"/side. In which case the low pressure switch, should the refrigerant pressure be "THAT" low, would never allow the compressor to start.
On the other hand if the system refrigerant charge level were just barely above the low pressure shutoff/disable level the A/C compressor might run continuously, even with low cooling demand, and never cycle "off", never reach the high pressure shutoff point.
So IMMHO it would be this latter case, the A/C compressor running continuously, even with low cooling demand that might result in premature compressor failure.
Yes, turning off the A/C during the "heating" season might not result in anything more than improving FE and.....
SAVING YOUR LIFE....!!
When the A/C is operating in a climate conducive to dehumidification (most wintertime climates are NOT!) the A/C evaporator vane cooling surface area, all 10,000 square inches thereof, will ALWAYS remain covered with a thin film of moisture. If you should happen to cycle the A/C off, or it should cycle off unbeknownst to you, the result might just very well be desastorous.
Since operating the A/C when the OAT is near or below freezing would result in freezing up the evaporator and blocking all airflow most, if not all, automotive A/C compressors are disabled below about 35F. Additionally the ability for A/C functionality for dehumidification is purely a function of the outside climate, a real WILD CARD, that.
Below about 45F the possibility that the use of the A/C will be of help in defogging the interior windshield surface, or as an aid to keeping it from fogging over, is a function of the Rh, Relative Humidity, of the local atmosphere. Since the A/C can NEVER reduce the temperature of the incoming airflow below 32F, and that only likely at the LOWEST blower speed, the dewpoint of that atmosphere must be unusually HIGH, by wintertime "standards".
If you are experiencing windshield fogging just a few miles down the road on an early "coolish" morning you can blame that on "yesterday's" use of the A/C. Worse yet, use it as an "AID" to defogging and then switch it off (both will often happen automatically, with no indication to you of A/C operation, when you first use and then turn off the defrost/defog/demist function) and you will soon get a re-occurance of windshield fogging.
Personally I disable my A/C compressor capability throughout the winter months and rely only on HEATING the windshield to remove condensation or prevent same.
That ALWAYS works and with no ILL, DANGEROUS, after effects.
Warm water in the heater core isn't as much of a problem as the exhaust manifold and turbo right up against the cowl that the fresh air passes through. $15 of heat sheild will fix that problem.
Not "warm" water, BUT HOT water, directly in the path of incoming system airflow and in a "container", heat exchanger, designed specifically, lots of heat transfer surface area, to equalize temperature differences between the HOT water inside and the airflow outside.
Whereas, as you correctly point out via the heat shield suggestion, the other hot objects can only pass their heat to the system airflow via radiation and even that only through another metal object, the firewall/cowl (heat shield..??).
warm, hot, whatever...it's 180-200 degrees. The exhaust manifold and turbo radiate heat in excess of 500 degrees (that's hot). The heat transfer of the metal firewall is far greater than the heat transfer of the plastic air box. Yes, there is heat present that does escape into the cabin but it pales in comparison to that coming through the cowl.
When "underway", traveling, the engine compartment airflow would make the radiant effects, insofar as heating the HVAC intake airflow, pretty much negligable. On the other hand when the vehicle is stopped I could well see that the resulting heat soaking of the firewall would contribute substantially to the overall heating of the intake cabin airflow.
But I still stand by my solution, block the coolant flow to the water heater core and see if that doesn't alleviate the problem such that it is down to an acceptable level.
The CX-7's poor FE is a complete turnoff for me, as is the RDX's, but out of curiosity today I went by the dealer and test drove an '08 CX-7.
Like the RDX I found the center dash/instrument panel too busy/complex.
There was no fuel computer nor a boost guage, a bit puzzling, that.
The salesman said that the fuel computer was likely a part of the nav package but the brochure doesn't indicate so.
The '08 actually had two highly reflective heat shields, both mounted to the firewall. The higher one was clearly intended to reflect the turbo's radiant heat away from the firewall, and the second somewhat larger one was to reflect the catalytic converter's radiant heating effects.
It didn't appear to me that anything more effective than what was already there would be viable. Maybe a thicker or more effective "panel" of insulation behind the existing highly reflective heat shield.
I was ready to buy a new CX-7 until I noticed the bad ac performance. I assumed that the one I drove was defective and told the salesperson that I would buy it as long as the AC was fixed. Then we got into a disagreement about payment (he wanted me to use their bank) and I walked away.
One just never thinks that something so tried and true like AC can be an issue on a modern car. BTW my other 2 cars are same refrigerant and they cool much better, so it's not that.
I found some threads about this issue with some post that mimic my experience of seeing air that is barely cool, luke cold. However, I must assume that mazda has sold many of these SUVs so if this was as bad a problem as I experienced there should be many times more posts, but there are not. Is the weak AC a normal thing on this car? Or is it something experienced only by some owners?
Any Dallas owners want to chime in? I remember one year we had 100 days of over 100 deg weather...so it gets hot. My purchase is now on hold until I can learn more about this issue. Thanks
If you happened to test drive a car that had been previously driven, cabin already "acclimated" to the environment, and the engine coolant was up to operating temperature, most modern day HVAC systems will not supply very cold airflow (DISCOMFORTING airflow for many) absent "extreme" measures.
To test just how cold, really COLD, the system airflow can be turn the temperature control to MAX cooling and the blower speed to one of the lower ranges.
It's a known problem. You'll find abundant comments on this issue, throughout these forums and others.
I've had mine since June 2006, GT with auto climate controls and now have 51K miles on it. Temps in the DC area occasionally get up into the high 90s with high humidity. The 7, sitting in the blazing sun, under those conditions, will struggle to cool the cabin, PARTICULARLY, in stop n' go city traffic. Sometimes it's simply better to open the windows, as the A/C simply can't cool the vehicle. Even when the settings are set to recirc. I've had the system re-charged more than once. Doesn't make a difference. Here's a tip: If you can park in a garage, that makes the world of difference. A/C has no problem keeping the cabin cool, even when it's 100 degrees outside.
If you do park in the sun, but you hit the freeway shortly after starting, the cabin does cool down in fairly short order.
I consider the A/C mediocre, when compared to other comparable vehicles under similar circumstances.
Most modern day automotive HVAC systems no longer have a engine coolant flow shutoff valve to prevent HOT coolant flow to the heater core, the reheat/remix vane/door is used exclusively for moderating the outflow temperature.
The problem with this technique is that it does not "allow" for the radiant heating effects of the heater core being constantly at 190F. You could probably improve the cooling efficiency substantially via blocking the coolant flow.
Oh, and don't EVER buy a black or even a dark colored interior. And a more reflective, HEAT reflective, "light" exterior color wouldn't hurt either.
I have had the same issue with my Mazda CX-7. At 40k miles the ac compressor went out, it also went out on my friends car 4 days after her 36k miles warranty expired. We bith have 2007 models. I'm not going into detail about everything I have been through with Mazda, but I am going to fight this. After all the blogs and forums I have read, this should have been a recall! The reason it hasn't is b/c no one has reported it to the office of defects investigation. I made the first report on friday of this past week and I am begging other people to do so as well. Anyone who has had this problem with their cx-7, please report this. Mazda is getting away with something, and they know about the problem, and are not doing anything about it. I will take this to the media if I have to, because this is wrong in so many ways. Here is the the link to the the office of defects investigation http://www-odi.nhtsa.dot.gov/.
I didn't have any forewarnings. I was driving down the road when all of a sudden I heard this loud noise. I immediatly turned down the radio, because at first I wasn't sure where it was coming from. I soon realized it was coming from my car. I quickly pulled over, and when I turned off the AC to see if I could hear the sound better, it stopped. Thats when I realized it had to do with the A/C. Not to soon after I got a whiff of something burning. Fortunatly I caught it in time before anything actually melted or smoked.
The AC compressor on my 2007 Maxzda CX7 has fried twice, once at 30k miles and again at 60k miles. The trend is obvious. I have sent my info to the nhtsa investigation board. I would gladly participate in any kind of customer group challenging Mazda to address my financial implications of this defective system.
They replaced my AC compressor (under warranty). Apparently with a newer-specification part.
Unfortunately the hot weather has finished downunder, but from the few hot days since the new AC went in, it does seem to have improved....slightly.
The median temp coming from the vent has cooled by perhaps 1.5 C to around 4.5C. However when the car has been parked and then driven again (when hot), the median temps are at least 3 degrees warmer, which is significant. Must have something to do with the built-up underbonnet heat, which also makes incoming fresh air at least 15 warmer than outside!
I HAD MY MAZDA CX-7 FOR 2 YEARS NOW, AND I HATE IT. MY TIRES WENT BALD WITHIN 6 MONTHS. THE DEALER NEVER TOLD US THAT WE HAD TO USE PREIEUM GAS AND NOT REGULAR. NOW THIS WEEK I WAS DRIVING AND I HEARD A LOUD NOISE AND THE PICK UP SLOWED DOWN. I TOOK IT TO THEM AND THEY SAID MY ENGINE WAS DEAD AS WELL AS MY TURBO. THEY WANTED ME TO PAY 9,000 DOLLARS TO FIX IT. THEY SAID I WASNT GETTING ANY OIL CHANGES. IM, LIKE WHAT, I WAS GETTING THEM DONE JUST NOT FROM THEM. THEY WONT FIX MY CAR. I HAD A MAZDA 3 BEFORE THIS AND I HAD IT FOR TWO YEARS AND I ONLY HAD 1 OIL CHANGE AND I NEVER HAD THAT PROBLEM. WITH THIS CAR I MADE SURE I TOOK CARE OF IT. THIS IS CRAZY MAZDA SUCKS.
I have 2007 Cx-7 and had the exact same problem, no warning one day ac stops blowing cold (should have known there is a design flaw, always noticed that AC struggled to stay cool on hot summer days) next day car breaks down on highway (belt snapped)
Tow car to dealer, think I am replacing a belt get phone call telling me compressor locked up and snapped belt....now it makes sense....
did some digging and found out design change on the following year, so that basically proves Mazda is aware they have a major problem...
the more of us complain the more likely for a recall and thus justice as I paid out 1400.00 ..... My car has 39K just passed thru warranty in March 2009.
Otherwise I love the vehicle, only other problem I have had is the white smoke about once every six months which the dealer tells me they have never seen....
Many newer systems will disable the A/C compressor if the engine coolant temperature starts to approach a level of overheating. Since there is no actual overheating, and in most instances disabling the A/C prevents same, there is no indication to the driver other than the possibility that the A/C light extinguishes temporarily, if even that.
Plus a turbocharged engine might eb a bit more prone to entering this "zone".
If you discover that the above is what is happening and/or is happening to often for your comfort, you can use the max cooling mode (adjust the blower speed manually to control your comfort level) to dramatically increase the A/C system's efficiency and thus avoid the "zone".
I have not had any problems with the A/C. (30,000mi) I've always had black cars with dark interiors - regardless of brand or style, so perhaps I am slightly more tolerant of high-interior temps and slower cool-down times; but I have no real problems with the A/C system.
I have experienced the so called "smoke," but that is simply condensation being blown off when humidity is high or the fans are run on low for an extended period of time. That happens in all vehicles under those same circumstances (I've owned GM, VW, Nissan, Ford, BMW) and is a physics issue, not a car issue.
Also, all cars cool down much faster in recirc mode. All cars that I've owned struggle with the high temp/high humidity/non-recirc combo. Some better with others but all within a range I'd consider reasonable for that circumstance. For the record I live in the Washington, DC area.
to ihatemazda, I have had my POS CX-7 for 2 years. I bought used, it had only 4900 miles on it. We noticed a/c problems, took it in once and they adjusted, but never really fixed. Then in April of 2008 we were leaking oil and coolant. Turns out had blown seals on the transfer case. How many vehicles blow seals at 5500 miles? That should have been a wake up call then. Now, the wife and I were driving home from the store on 4/8/09 and same thing as you, heard the loud noise and car had to nearly crawl home. Had towed to the dealer on 4/12/09 and was told the very same thing, that turbo was blown, I didn't change my oil and now it needs a new engine. They want $9400.00 plus tax to drop a new engine. Hell with them if they think they are going to any more of my money. I still owe a buttload on the car.
Sorry, I forgot about, neglected to mention, the extra cooling load on the engine cooling radiator and coolant due to the need to provide cooling for the PTO, Power Take-Off.
If you happened to have followed the year to year development of this "new" F/awd system, say on the Ford Escape, you will know that early on there was a serious over-heating problem. At one point Ford had a temperature sensor in the system and advised drivers to pull over and let the F/awd system cool down before proceeding.
So I'm fairly sure the need to cool the PTO arose out of that issue and I doubt that the overall cooling system capacity was considered before adding the additional cooling load.
Add a towing load and REALLY get into trouble, the A/C would likely be disabled continuously.
Go to Home Depot and purchase a water flow shut-off valve to insert in the water hose to the cabin heater. Close the flow during the summer when the A/C use is predomninatly for cooling and thereby increase the A/C operational efficiency dramatically. Much lower load on the engine cooling radiator with the A/C compressor not cycling on as often.
But nothing will make up for ignoring the need for regular oil and filter changes, especially with a turbocharged motor. I would NEVER buy a used car with a turbocharger absent a discussion with the previous owner to make sure that the previous owners wasn't of the "boy-racer", or "like", mentality.
First off I do not claim to know anything about auto's:
With that said I am looking for some reassurance and advice:
Yesterday (May 10th, 2009) my AC compressor clutch went out on my 2007 touring CX-7 Below I have listed the facts:
1. I am 300 miles over warranty 36,300 2. I had a full (top of the line) inspection at the top mazda dealer in Omaha before the warranty expired less than a month ago 3. The dealership feels bad that this has happened and offered to pay for all labor costs 4. I have to pay parts $1,200 for a new A/C compressor clutch
My question are:
1. Should they have foreseen this problem? (I understand not all things are able to be foreseen) 2. Is $1,200 sound right for a new AC clutch? 3. Would I be safe with a used AC clutch?
Thanks in advance for the help!
CDCAMP
UPDATE: my A/C compressor went out at 36,300 miles (300 miles after warranty). Dealership said they would pay for labor because I had a full inspection 3 weeks ago on the vehicle. Below is service sequence of events:
Before I go into the summary of conversation I first want to say that all the dealership and Mazda customer service personnel were highly professional and very kind. I too was professional (IMO) and was not trying to flame them but, trying to reach a reasonable solution to the problem:
1. Dealership: Woodhouse Mazda - Omaha 1. They acknowledge that this is one of the main problems on CX-7's 2. They acknowledge that the old A/C unit is faulty (Because the new unit is a redesign) 3. They acknowledge that they do not check this problem as a "preventative maintenance" check (prewarranty) 4. They acknowledge that they have a significant markup on parts ($1,200) so "Free Labor" is just another tool used for customer service
2. Called Mazda customer service 1. They said that they might be able to file a "Post Warranty Claim" 2. While on hold he spoke to the warranty and they said the "district manager" knew the situation and approved "Free Labor" as the best they could do. 3. Mazda (Customer Service) then claimed that was the best they could do.
So in conclusion, I am out $1,200 dollars because of a faulty (Poorly designed) A/C compressor. So not only was I on the side of busy highway switching my baby and baby's car seat into my surprisingly reliable BMW 5 series (with 75,000 miles) but, now I have to pay 30% margin on new parts.... But hey the Labor is Free!! Thanks MAZDA!!
Be Warned: THIS PART WILL FAIL (Make sure it fails before your warranty is up)
But seriously, I'm not sure there's anything you can do at this point except try to talk them into giving you a bigger break on the cost. Even if they had inspected the clutch, anything they might have discovered would likely have been designated as "normal wear."
I know things are often more expensive these days than I expect but even so $1200 seems more appropriate for the entire compressor/clutch assembly rather than the clutch only.
Check with an aftermarket shop and you may get by with lower cost parts AND labor included.
Just a quick check with Google indicates automotive A/C clutches sell for ~$100 and compressors for <&400.
As the rabbit said as the combine approached "I'm about to be REAPED!"
Call MAZDA customer service in IRVINE,CA and explain the situation, they know they have higher than acceptable failure rates with the 2007 CX7 AC system, as mysteriously the system was redesigned the following year. Tell them you expect them to take care of it and that you are aware of the issues with the CX7 AC system. And FYI 1200.00 for the parts only is ridiculous and is a scam, your dealer is trying to show he is helping but is just burying the cost of the labor in the PARTS..... I had my whole system replaced with labor and tax and the bill was 1400.00 but I called mazda and got them to split the bill as my car had 39.5K. So I saved 700.00 by doing some research and spending 15 minutes on the phone...
Not to be on Mazda's side, not by any means, but it was about this time period that many manufacturers began the switch to the new variable displacement compressors to improve FE.
And God knows the CX-7 could use some FE improvment.
Mine started making noise so I got it replaced before it actually went completely. Unfortunatly it happened at just under 38,000 miles so it cost me about 1200 to repair. I had no idea that this was a common failure.
i have a 2008 grand touring cx-7 which i leased brand new in september... i have had nothing but problems... my truck is going in for the 3rd time tomorrow... i just had a new compressor and clutch put in because it was blowing out hot air.. now, if i leave the a/c on, the more i drive the warmer the a/c becomes.. it's crazy i'm so fed up about this... every time i accelerate, it blows out hot hot air... then, it doesn't return to even being somewhat cool... the 1st time i went in, they said there was absolutely nothing wrong with my truck and then i went back again because i knew i wasn't crazy... it's so ridiculous, i have to leave the car to get it checked pick it up then bring it in again for them to fix it... i had a honda before this and never had one problem with it! i'm so torn on what to do they said among cx-7's it's common for the compressor to stop working
Almost all modern cars with AC will disable the compressor as a preventative/protective measure if the engine coolant temperature approaches the point of overheating, not ACTUAL overheating, just rising to a nearby level.
Most of these vehicles, if not all, do not have any type of indication to the driver as to what or why this has happened. But in most vehicles this disabling of the AC compressor would be so temporary that the driver would take no notice.
"..every time i accelerate..."
Hmmmm...
TurboCharged engine...water cooled turbo....??
Newer variable displacement AC compressor...??
Lets suppose your engine is normally running slightly hot, on the hot side of the operational envelope. Then add the extra HEAT of cooling the turbo when you are accelerating and it could be entirely possible that the AC compressor will be disabled until the engine coolant temperature declines to something nearer to normal operating temperature.
The old fixed displacement AC compressor systems always had a reservoir for temporary storage of liquid refrigerant. The compressor only ran if/when this "reserve" was exhausted. The new variable displacement compressor can be set to compress refrigerant ONLY as fast as it is being used up.
So if the compressor is disabled even for a relatively short period the loss of cooling effects will noticed almost immediately.
But it sounds as if your engine/turbo/coolant may be always running slightly HOT.
I found this forum as a result of searching for AC Compressor problems on my 2007 Mazda CX-7. I was about 250 miles from home when my vehicle became non-drive able. I would like to add the following information:
1) The vehicle has just under 44,000 miles on it. 2) Dealership tells me that the cost to repair just the compressor (which seized) is $1,400 (I do not know if this includes labor, but I suspect that it does NOT). 3) Dealership tells me that there are NO parts available in the United States! 4) Dealership tells me that there are over 300 orders a head of mine for AC Compressors. This tells me that this is a KNOW FAILURE! 5) Dealership states that even if he gets my part prioritized (as my car is non-drive able) that I can't expect to be back on the road until at least the end of June.
Oh yeah, let me mention that my battery cables have melted due to this problem.
I'm going to report this to NHTSA and find any other forum that I can to air my complaints. I can NOT afford a repair that will cost over $2,000 for a vehicle that is just over 2 years old, especially when I'm learning that this is a KNOW FAILURE.
The ONLY time I have seen that happen was with the ignition key stuck in the "start" position keeping the starter engaged with the engine running. The starter, accordingly, acted as an engine driven generator and attempted to charge the battery to an "infinite" voltage.
Melted the insulation off of the battery cables and the ground wire burned open.
I can think of NO other reason for melted battery cables, not even a "runaway" voltage regulator.
You need to call the mazda service center (1-800) and tell them you are not paying 1400.00 they will split the bill with you at least. And everyone needs to report to NHTSA on their website. Maybe someone should start a class action
Drove from Detroit to Fort Wayne, Indiana (3 hour drive) to speak directly with service adviser and return rental car as I can't afford to keep this. I was informed that the battery cable is part of a wiring harness, and isn't as simple as a battery cable as I know it. It appears that the part has some sort of resistor part (like a fuse) that broke in two. I took pictures in case anyone wants to see this. The serpentine belt had threads holding it together and it would have broken within a short amount of time. Was told that my part has been "prioritized" and that it should arrive at the port on or around June 29th. Not sure how long it will take before it gets to the dealership.
Good news is that the Mazda rep has agreed to pay for 75% of the cost of the repair (includes new O2 sensor, serpentine belt, AC compressor, and now a complete wiring harness/battery cable (dealership was originally going to repair this). I'm still not happy that I will have to pay up to $680, but this is better than the $2,000 originally quoted.
Plan to file complaints with NHTSA later today as I see this as a potential "thermal event," also known as a fire. If the serpentine belt would have broke, I would have been stranded on the freeway with two other adults and a dog. Luckily, I had pulled into a rest area, so we were all safe.
It's obvious that this is a common problem with the 2007 CX-7 as there are numerous complaints already on NHTSA's website.
thanks so much... it's just ridiculous and they keep telling me o well there's nothing we can do about it!!! i'm so fustrated.. i practically live at the freakin dealership!
I bought my 2007 Mazda CX7 in November of 2006. I did not use the A/C until summer of 2007 then again summer of 2008. My mileage is approx 44,000. I live in a rural area so I have long distance driving to go anywhere. This being my 3rd summer of A/C I was totally dumbfounded when the air started blowing warm in May 2009. Reading these posts I see I am not alone. I am ready to go after Mazda to fix this problem especially knowing the problem is there and having so many people dissatisfied. Even though I am over my warranty, I will fight this!
I have to travel 120 miles just to get to my dealership. When I took it in to be looked at, they told me it was the compressor and it would cost $1500.00 Then they tried to sell me an extended warranty to use to get it fixed. Is that a scam or what? Has anyone out there had some satisfaction from Mazda? I'm just now looking into what can be done. Thank you your input on this.
After reading so many stories about CX-7 AC compressor failure on this sites, I think Mazda needs to recall this model. Here is my experience.
I drove Mazda CX-7 that I leased on 2008 September to Lake Tahoe for family camping activity on 06/12/09 from San Jose. After about 3-4 hours drive, we almost reach Lake Tahoe but air condition went off and we smelled something like burning plastic. I know something was wrong but luckily I arrived safely in camping sites.
On Saturday (06/13/09) morning when I went to gas station to add fuel, the engine generated heavy smoking and I have to stop to call roadside assistance. My CX-7 was towed to Carlson Neveda, which is about 30 miles away. I had to use a rental car to continue my camping activity and drove back the rental car back to San Jose which was 250 miles away. One week later on 06/19/09, Carlson Mazda dealer called me that my CX-7 was fixed after replacing AC compressor. I had to drive up total 10 hours round trip to get my car and return rental car. It was bad experience.
Since my car was less than 2 years old about 25k, I asked Mazda manager whether this CX-7 ac compressor problem is common or not, his answered was a simple 'no'. But I think CX-7 was a defect product and lack of quality control from Mazda.
Although I did not need to pay for repair because under warranty, I will never trust Mazda again. I hope Mazda file bankruptcy soon like other GM cars because their products should not be in the market. In my opinion, this kind of problem caused engine smoking on its belt is highly dangerous and fatal error that could cause severe tragedy on the road. This problem should not occur on a 1 year new car.
The mazda dealership wants to charge us almost 3k to fix our 2008 Mazda CX7. :mad: Apparently the service guy said that it was in fact the AC pump that failed and caused all the other problems. He said that the pump, clutch assembly, tensioner, belt, and some crank bolts need replaced. He also said the it would not be covered under the power train warranty. The gentlemen I spoke with there before, said that if the service dept. deemed that it was the AC pump that caused the problem, that it WOULD be covered. That’s why I had it towed 75 miles down there!
Just went to the Defects and Recall website and reported the defected AC compressor in my 2008 Mazda CX7. I have a feeling more and more 2008 owners will soon have the same problems. It only took a minute to fill out, just have your vin# handy. PLEASE report this if you have a similar problem with your CX7. Here's the website again:http://www-odi.nhtsa.dot.gov
Well, just got home from my long drive (3 hours to be exact) to pick my 2007 Mazda. After a phone call from the Service Mgr, I was seeing more red than you can imagine. Basically, he threatened me and told me that if I didn't accept Mazda's offer of 75% off of my repair bill, I was going to have to pay the full $3300! He told me that Mazda was upset that I was making such demands of 100% payment of the bill, reimbursement for rental car, etc. and that they were going to rescind their offer of 75%. After I calmed down a bit, I could see a little clearer. I put on my "happy face" and had a friend drive me down to pick up the darn car. I figured that I could fight things once I paid the bill. On the advice of NHTSA, I will be contacting my State Attorney General and will put the car up for sale tomorrow! On my drive home, stopped for gas (was down to 1/4 tank) and upon restart, the vehicle sputtered and stalled. Same thing on second attempt. Third attempt, I gunned the engine a bit and was on my way. Called the dealership on my way home to give them a "heads up" that I was experiencing problems. What a headache.
Vince.
Well, nothing but fuel efficiency...
-c92
Thanks for listening to my rant.
NOT...!!
Block the water flow and see for yourself.
could someone describe to me the type of heatshielding and where exactly you installed it, to prevent the heatsoak from turbo and exhaust?
I tried some flat thin reflective ceramic heat shield directly over the turbo heat shield, but that seemed to make little or no difference at all...
cheers
satz
I took the tim e
Pancho
:mad:
Vince
to those who had the compressor failure, did you have any symptoms leading up to that event?
eg.. did the AC cooling get worse? Or was it always bad?
Or did it work in some situations but not in others?
cheers
S
still unhappy.
I will be filling out the NHTSA info tonight...
Always noticed on hot days here in SO Cal that the AC struggled to stay cold...
Mick
My question are:
CDCAMP
CDCAMP
Exactly how would one go about doing that?
SUVs and Smart Shopper
Hmmmm...
MELTED...??
Those are pretty damn healthy cables.
