Buick Century Transmission
the transmission wont go into 1st gear or
over-drive. other than that i can still drive it. can anyone tell me if this is a switch problem or need new trans?
Joe B
Im new here. I am replacing my tranny this weekend and wanted any advice anyone might be able to throw at me.
Thanks :shades:
Today, trying to start from traffic light, it didn't go forward in DRIVE. PUt it in next dear and still didn't move. Then in low gear it went forward. It also goes into reverse. I drove slowly and it took me home.
Guy who put it in no longer in business.
Also trac off light and service vehicle soon and anti lock lights have been coming on and off for the past few weeks. Had it scanned and all systems passed.
Also passenger side window stopped moving a few months ago.
TRANNY is my main concern. Any ideas or opinions? Called transmission place and he said he'd have to take the whole thing apart. Didn't even see it.
IDEAS?
I jus recently bought da car and i drove it 4rm atl to savannah well half way b4 it cut off..
Some veterans dat helped me told me dat my fly wheel broke then wen i got it towed da mechanic told me i have to get my whole transmission rebuilt..
When i start da car n put it n drive it makes this loud noise but it goes in reverse..
Can yu tell me wat may be the problem could it be my gears are stuck etc
That solved the problem 70%. Then I tried the well advertised solution of adding a can of seafoam transmission treatment. That solved my problems up to 90% of the time. Now what? The next solution was to use dexron VI instead of dexron III because gm dexronVI says on the bottle that it can be used in older GM vehicles to prevent transmission shifting problems. So I put dextro VI in the transmission with one can of seafoam and guess what. I have no more problems. My 2003 Century has 345,000 kms(x taxi) and runs like new. I just wished I had tried the dexron VI before taking the transmission apart first.
Let me know how you resolve your problem.
The dealer said it was time for a transmission and power steering flush.
to the tune of almost 300.00
I do not have a manual or i would have checked the service interval.
Can anyone advise.
I apologize for your frustrations. Thank you for taking your time to explain your experience. If you would like to work with a GM dealer for your concerns please feel free to email me. If you have any questions comments or concerns please feel free to email me.
Christina
GM Customer Service
The oil change place uses DM3, which they said is the right stuff. But when I looked this up online, it said it was not approved for use by GM cars that called for Dextron III. My owner's manual says it needs Dextron III. Should I go after the oil change place?
Thanks for any advice
It will stick. You can either replace it, instead of all the other crap they try to sell you or pump the gas pedal a few times before you start it. best when engine is cold.
Try that first, I see that the fix the repair places want to do is rebuild or replace the transmission and the problem seems to come back. The real problem was the connection. Good luck and try that, it is better than replacing the transmission if it is not the problem.
My 95 Buick Century acts like the parking gear is stuck no matter which gear you shift it into even neutral. It feels like it shifts into gear but wont move. I had to rev the engine in neutral and drop it into drive and it popped, then I could drive it, but as soon as i shift it into reverse or park then it sticks again. I checked the fluid and it looks fine and is at the proper level.
I ran my scanner on it and it didn't show anything. Any ideas?
I have been experiencing shuttering and slipping in first gear even after a rebuilt transmission was placed in it by a reputable shop that we have had no issues with in the past. (These problems were happening before the swap as well).
I've also experienced what seems like a lag in full traction in my transmission. I'll be in first gear speeding up, or even second gear as well, and it will feel like my car has power and it is accelerating, though slower than normal, and then a few seconds later it will feel like it catches full traction in the transmission and be back to normal. Sometimes there will be a thud or at least a noticeable noise or feeling.
When we brought the car in initially to have the transmission replaced the torque converter passed the test it had done on it. I'm wondering if this part is the issue at all?
Also, for many years I have not completely stopped when switching from R to D. I've been switching gears at 2-3 mph, but I'm curious if that has some effect on the performance of the transmission.
Any suggestions you might have as to why I'm having this problem and any possible solutions would be much appreciated!
Mike
