Specifically, my switch was centered under the control panel above the rear view mirror (centered). Not a bad location although the switch is not readily visible since it is underneath the upper control panel.
The although installation I saw had the switch on the side of the upper control panel facing the driver visor. Not sure why they didn't install in the original factory position, however I would now request that location if I had to do over again, unless there is an electrical or space configuration that prevents that position.
8.1 liter in and out of town
and/or
6 liter in and out of town
2. Doesn't use high intensity beams. Once you've used them nothing less will suffice. I first tried them on my Jeep Cherokee and I could hardly believe my eyes. The road lit up like it was daytime for at least 100 yards.
3. Climate control is analog instead of digital readout and is single not dual. Temperature control uses a thermocouple instead of infrared. This is 40 year old technology, in a $40,000+ vehicle.
4. No reading lights for the 3rd seat.
I already own a 2001 Yukon XL Denali, so my opinion is biased. I think your comments (except #1) will convince people to buy the Denali! You obviously have a very keen eye for detail, and if those are the only reasons you have for not buying a Denali, then GM has done an excellent job. #1 is a real problem. #2 and #4 are an easy fix (Did you Jeep come with high discharge lamps... No). #3 may be true, but it works great! How can you argue with that?
I picked my Denali up in Northern Idaho, and by the time I reached Bozeman Montana, it was -13F. The interior temp was an even 72F front and back with the system on full auto. This is when I noticed the cold air up front on the passenger feet. I WILL fix this myself if GM won't!
The next morning it was -15F and the Denali started up like it was 70F. You will be amazed how fast it heats up (seats are amazingly fast).
Long story longer, you can easily find a reason (as nit picky as the thermocouple) to convince yourself not to buy ANY SUV on the market. But hey, I would be disappointed if we did not have the choice of an Excursion, Sequoia, or ?????. I wish you success in finding the SUV that does meet your needs (and wants). The Denali is an amazing ride IMHO...
Dave
I keep hearing people are getting 16mpg? At what speeds are these numbers coming from, and do you all live in Florida like dapetrun where a mountain is only 50ft above sea level (no offense).
Dave
After no luck with two GMC dealerships, GMC Customer Service, or Delplhi
Delco Electronics web site, I successfully had a mult-disc changer
installed in my 2001 Yukon that did not require disabling ONSTAR and
works with the radio controls. Previously I was told that only an FM
modulator CD player would work or I would have to disable ONSTAR for a
linked version. No one seemed to have the proper cables or knowledge.
What a relief to finally have a 12 disc changer!!
I had the work done at Rickwood Audio in Nashville, TN. Everything still
works: in-dash CD, auxilliary cassette player, ONSTAR, and is controlled
by the buttons on the radio. The 12 disc player is mounted under the
second row seat behind the driver in front of the jack handle storage
area. It's a Pioneer made for Delco. It's covered by the car's warranty
once it's installed. It works great! Good luck with yours.
The cd/aux button switches between the cd in the dash and the cd
changer. The same button will switch between the cassette player andthe
cd changer. You can have something sitting in all three places and use
the cd/aux button to select what you want to play. By freshly inserting
an item into the dash units, they are given priority over the changer. I
don't know if that's clear or not.
Rickwood's number is 615-889-3270 or (800-423-4142). I have a 2001 Yukon
SLT. I imagine we have the same radio, but I'm not certain. The one I
have has a cd in the radio and an auxilliary cassette player down in the
console area. When you talk to Rickwood, I'm certain they'll be able to
tell you what will work. It only took them about an hour to do the
installation on mine. I hope this helps you.
Do you know if Rickwood is open on Saturday?
"And how would you distinguish the ride difference between the new 3/4 YXL w/autoride and Denali XL?"
The 3/4 ton had a tendency to wheel hop during corners on a washboard road. The leaf spring rear suspension on the 3/4 ton YXL did not perform nearly as well as the coils in the rear on the 1/2 ton models with autoride (std on Denalis) when it came down to comfort.
The debate about real towing power seems to be a non-issue. Anyone with 10 minutes to spare and a Yukon brochure will realize that the Denali is NOT a HD towing machine. GMC Marketing was not aiming at people towing 30+ foot trailers weighing 10,000lbs. I am only towing a 6500lb trailer, and it really has no trouble at all.
Ask yourself, "Self, how heavy is my trailer?"... The rest would seem to pan out from there. Don't try towing your 8000+ lb trailer with a Denali, and think you will be passing up hill! Personally I love the Yuppie interior
Dave
PS. I definitely did not buy the Denali with "too" much concern about mileage, I just wanted to know how the others here were getting the 16+ mpg ?
On a separate matter, I had ordered a remote start system for the truck, but the dealer advised against installation as his experience has been that they interfere with the inboard computer. Again, anyone have some info/advice? Thanks.
I hope that when you pass out at 75MPH you don't plow head on into another vehicle also doing 75.
Unsafe at any price.
I'm sorry that you missed the 1000's (literally) of posts about this problem during the last year I have been reading at Edmunds.
When GM sent out the 2001 "Dealer only" literature, it mentioned that you would now be able to get the auto-climate control with the sunroof (unlike the 2000's). This NEVER happened and GM has it's collective thumb up its bum. Maybe they think the system will go whacco?
Trying to install the auto system after the fact would be a very difficult install due to the sensors and the cost would be prohibitive.
The auto system and rear controls for the 2nd row were more important than the industry's smallest sunroof to me, hence I passed on the option...
Dave
I guess I will stuff a pillow in it
Did they make any mention of deflecting it up or away from the passengers feet? Surely there must be way to slow it down or redirect it?
Dave
jgmilberg, you mentioned "The Denali with neutral(tan) interior has regular wood trim." I do not believe this is true. I heard here they were the same (my XL Denali has the gray interior), and sat in a tan interior Denali XL that had the black wood (plastic). The GMC web page of the colors even shows this if you look close.
Dave
Dave
PS. It is broken in by the time you get home
This is exactly what someone else here at edmunds said, and they actually saw a tan with black wood interior in person. I wanted tan, and my wife wanted gray.... I really like the gray (this comes from someone whose 4 previous vehicles had the tan).
Dave
bmoss1: The '01 Denali XL has a 6.0L, 3.73 rear, 320hp and 365 ft. lbs. of torque with a tow capacity of 8400lbs compared to the '92 2500 Suburban with 7.4L, 4.10 rear, 230hp and 385 ft lbs of torque and a tow capacity of 10,000lbs.
The '01 3/4 ton 4wd comes in 4 variations: 8.1L, 4.10, 12,000lbs; 8.1L, 3.73, 10,500lbs; 6.0L, 4.10 10,000lbs; 6.0L, 3.73, 8,000lbs
I traded the '92 Sub in on the '01 DXL in January. The ride differences are like night and day. Didn't compare the new 3/4 ton to the old one, but I am sure there is a significant improvement. The 3/4 ton however, will always have a "bouncier" ride than the 1/2 ton due to the leaf springs in the rear. This is particularly true when the rear suspension is unsprung (no load).
The whole point of the leaf spring suspension is to provide for a greater loading on the rear suspension than a coil and shock setup could provide. The combination of the 4.10 rear with leaf springs (and the xtra torque of the 7.4L) are the reasons my '92 3/4 ton had a greater tow capacity even though the new DXL has greater hp.
In the end, I traded the xtra 1600 lbs tow capacity for the greater comfort of the 1/2 ton suspension in the DXL. BTW, for those with the 8.1L and 4.10 rear, where do you find a tow bar and ball with a 12,000 lb rating? The largest I have seen in catalogs is 10,000lbs.
If you have a heavy load that will be routinely towed, there is no match for the 3/4 ton Sub or YXL with 8.1L and 4.10 rear (literally, since no other non-commercial vehicle with 4 wheels can tow more than 12,000lbs). You just have to expect a bouncier ride compared to a current 1/2 ton.
It really comes down to the size of your tow package versus how comfortable you want to be when not towing. I had an 85' 3/4 ton Sub and a 92' 3/4 Sub before the '01 DXL. All were great vehicles and each was better than the next. I just wouldn't trade the comfort of the 1/2 ton for the 3/4 ton unless I had to. Maybe I'm just getting soft after alot of years of towing.
While I have not towed yet with the DXL (waiting for boating season) I am expecting similar and hoping for better tow performance out of the DXL than my '92 SUB. Additionally, the DXL has its own transmission which is heavier duty than the 1500 but not to the same level as the 2500. In my view, unless you have a major tow package, the DXL's tow capacity is in the "sweet spot".
Additionally, while the radio has nothing to do with towing (other than making the miles pass easier), you would never go back to the standard radio in a Yukon once you have heard the Bose in the Denali. It really is tremendous and has steering wheel controls not available in the Yukon or Sub. My comparison is with the sound system in my BMW 740iL which also has a really good sound system.
The Denali's come with a separate rear pod for the rear climate controls when it is ordered without the sunroof. With an aftermarket sunroof they simply reinstall the same pod with controls in approximately the same location. The ASC sunroof I had installed is the exact same sunroof (same dimensions) as the one installed from the factory. Cost about $200 more than factory list.
No, I haven't had "cold feet" syndrome in the front passenger floor area. I have front and rear climate control set-up.
I have had no problem with the tranny and no whining.
I agree with those posts on the interior fake wood. I really like the truck, however the plastic wood has got to go. It sucks and I plan on replacing it this Spring. If anyone gets ahead of me on this project I would be interested in what kit you install.
Can't really speak to pricing since I bought my DXL under the GMS Supplier program for about $100 under factory invoice.
Finally, has anyone heard if they have redesigned the Catch-all mats to accomodate the larger center console in the DXL vs YXL? Has anyone installed mud-flaps/splash guards on the rear of their DXL? If so, what did you install?
Your trans is the same as mine, in the Yukon XL, 4L80E, basically a TH400 with overdrive and a ton of electronics. It is the only trans that GM will put behind that motor. With the exception of the coming 5 speed auto from Allison. Your computer controls I believe are programmed for really soft almost un-noticable shifts, but the main guts and parts are identical.
I also believe that your engine and mine are the same as the Escalade, just uses a different PCM. I am checking into that with my uncle at the tech center, will keep you posted.
Are you sure about the overhead console? I have seen 6 different ones at my dealer and they all had the full overhead console, from the front controls just above the rear view mirror all the way to the back rear heat/air controls. All the ones with sunroofs had no rear controls, and the dealer said if I wanted a roof installed they would change the overhead consoles to the short front one and the "pod" for the rear, and that the roof installer orders them from the dealer as Yukon parts. It is just a plastic shell the stuff bolts into and gets re-mounted. They take them right to ASC, and that's who installs them. It still may be an option to get the long or short overhead consoles, and if that is the case maybe yours had the short one. If I remember you said you did not see the truck prior to the roof install, so..
Thanks, Jack
Actually, the transmissions are different in the 1/2 ton YXL/Sub, the Denali XL w/ 6.0L and the 3/4 ton YXL with either the 6.0L or the 8.1L.
All 1/2 Yukons/Subs have the 4L60-E (also called the M30), both Denali's and the Escalade have the 4L60E-HD (Heavy Duty) which is a more robust tranny to accomodate the 6.0L together with the special arrangement for the AWD, which isn't available in the 1/2 ton subs and Yukons.
All 3/4 tons have the 4L80-E (also called the MT1), which is even heavier duty than the 4L60-HD. The 6.0L engine is basically the same in the 3/4 ton Yuk/Sub, Denali and Escalade, however in each application they have a different HP rating due to different intake and exhaust manifold arrangements.
The 6.0L in the 3/4 ton has 315hp and 365ft/lbs, the Denali is rated at 320hp and 365ft/lbs and the Escalade has 345hp (5hp more than the 8.1L) and 380ft/lbs (the 8.1L is the grandaddy of torque with 455ft/lbs which is more the Fords 10 cylinder...nothing matches cubic inches for torque with the possible exception of supercharging. However, that's another story. I installed a B&M 174 supercharger myself on a 454 Chevy in my boat and there's absolutely nothing that compares to cubic inches COMBINED with supercharging).
I am sure on the ceiling controls. You need to ask to see a fully loaded Sub or Yukon XL with both rear and front "climate control" and no sunroof. Or ask to see a Denali (XL) with no sunroof and then you'll be able to see the pods and controls that are used.
I didn't see my truck before I had the sunroof installed however the dealer showed me a regular Denali before mine was shipped in. That Denali had no sunroof and had the pod with the rear climate controls. The dealer explained that is the same configuration that a DXL comes with when the sunroof is not ordered.
jjorgenson: I ordered a 6yr/75,000 mile, $100 ded, GM Major Guard warranty from the dealer (GMS-Supplier) for $1500 which was better than I could find on the internet. I didn't want to deal with the hassles of a third party warranty for the sake of a couple of hundred bucks, so I stayed with GM.
I am going to stop by ASC to find out about a controller that will auto close the roof when the ignition is turned off. Will keep you posted as to what can/can't be done. Really want that feature, only used the roof once and know I will leave it open if I am in a hurry to get somewhere.
As for the trans, I have a 3/4 ton 6.0L and the 4L80E trans. I did not know of a HD variant of the 4L60E. Learn something new everyday! Thanks.
What is the top speed on your boat?! What type of boat is it- size,cabin,ect..
I have the controls on the dash for the front climate control, a second set of controls above the rear view mirror that has the lockout feature to deactivate the climate controls on the rear pod. And then, the rear climate controls are duplicated in the stand alone climate control pod accessible to the second row passengers.
BTW, the boat is a Stingray cuddy cabin with the 454HD (roller timing chain, roller rockers, 4 bolt main, custom Holley, the B&M 174 Blower and lots of other "goodies"). The boat does 82mph which is a wild ride in a 26' boat with only the last 12" of the boat actually in the water.
obyone: I don't recall the GM Major Guard warranty for the $0 deductible exactly, however I think it was $250-300 more than the $100 deductible. I believe the thinking is that with a $0 deductible it will take approximately 3 additional repairs to pay off the additional upfront premium for the higher priced policy versus the $100 ded policy.
Wood trim/carbon fibre/brush aluminum kits, try http://www.woodtrim.com . We have a Wood/carbon fibre/aluminum trim dash kits discussion topic in the Aftermarket & Accessories message board. Feel free to participate in there if you wish.
Drew
Vans, SUVs, and Aftermarket and Accessories message boards
