Buick Century Fuel System
I have a 1991 Century that I ran almost out of gas (it was literally chugging when I got to the station). Problem is, even though it has a full tank it's chugging like it's not getting enough gas. The check engine light hasn't come on yet, but I've gone from 30 mpg to about 18. I put in fuel injector cleaner, to no avail. What can I do short of taking it to the ol' garage?
Have replaced fuel filter.
I replaced my fuel filter and it didn't change, i have wondered if it may be my pump, which apparently does not prime.
TBI !!!!! now keep in mind I have replaced the Throttle position sensor, fuel regulator, and injector also the injector would randomly squirt when you hear this clicking.. I would be VERY grateful for any help in this matter thank you in advance
Bill
i have century 99 that's been sitting idle for 2 years - kept in a non-insulated garage w/ about 3/4 full tank of gas.
i wanted to siphon the gas out - but am unable to.
i'm now assuming that there is a siphon restrictor.
is there any other way to get the gas out other than bringing it to a mechanic?
i have yet to start the car.
should i just change the oil and put a treatment into the gas w/o changing gas?
He could not do the valve because he said it is riveted in; is there a trick to changing it?
My 93 Century is doing the exact same thing as noodlesknowles I am unsure of what the problem is, filter has been changed, I have also had mine in the shop and they have given it a clean bill of health. Does anyone know what is causing this problem and how I can fix it. No engine light comes on ever either and other than this one problem the car runs like it is brand new.
