Visitor Agreement.
1998 Forestrer S with 21,000 miles. Dealer wants $17,300 for it. Is this a good price? Is there something special I should be worried about in this model year?
Need help fast!
mike
You might also remember that the mechanic that rode with me said that it was normal for Subaru 5-spds. I guess you just have to talk with enough (or with the right :-) people.
-Dan
Ross
I expect the new Forester one year from now, i.e. March 2002. The 2001 came early, as did the 2002, so I see a pattern here.
The next Forester will be a bit bigger with either a longer wheelbase or a new multilink rear suspension to replace the struts. A turbo option should appear. It'll remain full-time AWD.
They'll continue to compete head-to-head. I drove both and found the Forester more rewarding to drive, so I didn't feel like I was giving that up just to have practicality.
As for the Honda, the CR-V is very reliable and offers good interior room for its size. You ought to ask the same question in the CR-V forum (if you haven't already).
mike: they have good resale, so the price sounds fair. You can get a new L model for about $19k, but it has fewer goodies.
-juice
Glad to hear that they're doing the repair. My understanding was that the 2001's had the chatter worked out. I guess it's still around...
Ken
-Frank P.
Steve
Steve
Ross
Ross
Ross
Ross
My Geolandars wear fairly evenly. The outside edge did wear a bit quicker, however. When I had my last alignment done at a good shop, the mechanic noted the pattern adjusted the settings for a little more even wear.
I also cross shopped the OB and Forester back in 98. My experiences were similar -- I just found the Forester more fun to drive. Plus, it was a new vehicle. The OB was looking a bit dated at the time. I might have chosen differently had it been after the model change in MY00.
Ken
Ross
I had the same problem with rough idle at about 2000 miles on my '01 5spd Forester S. The car would become undriveable because the engine would stall and buck while applying gas. I needed to have my Forester towed *twice*. I was told I filled my car with "bad gas" which was a bunch of BS. They replaced sparkplugs and injectors, which did not solve the problem. They tried emptying the gas tank and replacing the ECU (engine computer?), and that also did not solve the problem. They just yesterday replaced the O-2 sensor. I'm driving the car now, after much aggravation, but I will not know for sure if that solved the problem for another week. The problem, after every fix, reappeared within 4 to 7 days. If the problem gets worse, DO USE the Subaru Roadside Assistance. Good luck, I hope your new car experience fares much better than mine did.
At faster speeds, I have been noticing a kind of strange "wind buffeting" kind of noise when the driver's side windows are down. It seems to go away if I roll the windows down on the passenger side. Does anyone else experience this?
Skip
I has my first 7.5K service on my Forester done on Sat at Santa Cruz dealership. They told me, they recommend low 40s for Foresters! In fact, they bumped my tires up to 42 psi on all 4. Handling is terrific now but I'm not sure I like ride that bumpy. I'll see if mpg improves any.
Forester uses light truck tires on both the L and S models. I had the L, and therefore the Bridgestone Desert Duelers, rated 180-B-B. They were good in snow, OK in dry, and awful in the wet. The 180 treadwear rating is very low, and the B ratings for temperature and wet braking traction are nothing to write home about either.
I replaced them with Nitto NT460s, along with 16" rims. These are rated a whopping 460-A-A, and I can attest that they grip far better in dry and wet conditions. Only in the snow are they not as good. They ought to last much longer, too.
Consider swapping to a passenger car tire, at least if you don't do a lot of gravel or dirt road driving. For the L's 15" rims, consider BF Goodrich T/A HR4s. Honda had the Desert Duelers on the original CR-V, and when they swapped to the BFG tires it gained 0.03g's in the skidpad tests, with no other suspension mods at all.
For the S model, the Yokos are probably better to begin with, but I still think you can get better on-pavement traction by going to passenger car tires.
A bonus for me is that they don't have the outside white lettering, which I dislike.
-juice
Kate -- So what did you think of Santa Cruz Subaru? I'm suprised they recommend such a high pressure given that the Geolandars max pressure is something like 44psi.
Ken
Well, my 7.5K service was way too simple, and I had no problems with my Forester so far (knock-knock-knock), so I cannot really estimate their level of service yet. They were polite, prompt, and they're open on Sat and Sun for Subaru service. I really liked that I can walk to the beach from the dealership, and we had a lot of fun on the Boardwalk while my car was in service. I plan to do my next service there too. There are not many Subaru shops open on Sat, after all.
Ken
-juice
Anyway....took the Forester on a fishing trip this past weekend. Caught a few small trout. My girlfriend caught a real nice 16" brown trout and was the envy of many a fisherman. It was her first trout and she was very excited.
Took the Forester on some unpaved, bumpy, muddy surfaces for a short distance...it was pretty fun getting the Forester so dirty
Skip
I bumped my Forester tire pressure up to 40 psi all around, and my gas mileage is currently hovering around 25mpg. I'm quite pleased. You do feel the road a bit more (especially the grooves on Hwy 580), but I don't mind.
Drove up to visit friends in Santa Rosa, in the wine country, this afternoon-- it's a gorgeous spring day here in Northern California. Had my three parrots in the Forester, and the moon roof open, and everyone singing happily away.
Karin in California
You might try asking the other Forester owners in the Subaru Crew owners' club topic about this. Perhaps they could offer more suggestions, in addition to what Ken has already mentioned above.
Good luck!
Drew
Thanks for your patience,
Drew
I added a "Windflector" to mine, though it installs with two-sided tape. You may want to check if the OE one is available now, since it bolts on more securely.
-juice
After a lot of research, I've decided to buy a new Forester S. I'm still back and forth on transmission, though. I've always had great service with my stick shifts; my '92 Nissan Sentra (which currently has 202,000 and is still going strong) just got its first clutch replacement 2 months ago, at 197K. However, I know I'd also enjoy the "luxury" of an auto. I have a 100 mile daily roundtrip commute, which is mostly highway driving. I plan on doing some test drives this weekend. Any opinions would be greatly appreciated.
I'm also still undecided on color. I actually prefer the gray bumpers and cladding on the L model, but want the other features on the S. I'm thinking gold with Titanium looks pretty nice.
I'd also like to hear from anyone in New Jersey about a good dealer in the Middlesex, Monmouth or Bergen County areas (where I live and where I work). I'm more concerned about service than pricing, because I want a dealer that really knows Subarus, and not one that also just sells them along with other makes. I found one in Rockland County, NY, that is close to work, that sells Subaru exclusively, and always has a good selection on the lot, though I'd have to pay the higher NY sales tax.
Any help would be greatly appreciated, and I look forward to joining the ranks of Forester owners shortly.
Thanks in advance,
Len
The 2002s have arrived at some dealers, I've heard. Check them out - the lower body cladding is now a different color, more gray than before.
Price did not go up, but freight did a little. They made the cargo cover standard, DRLs, and the rear wiper has 2 speeds now.
Unless you get a much better deal on a 2001, I'd get a 2002.
-juice
4AT vs 5MT- Get the auto if you like the convenience of one and/or you do a lot of stop and go driving. Many people who know how to drive a stick prefer them as it makes them feel more connected to the driving experience. In most cases, a 5-speed will slightly increase both fuel efficiency and acceleration.
L vs S: The L probably offers more value for the buck and is more utilitarian. However, the S's are much more popular. My guess is that the majority of owners want the extra goodies that come with the S so they rationalize paying the extra $2500 that the S costs by convincing themselves that they really need rear LSD and 4-wheel disc brakes for the safety factor (I know I did) :-) Oh, and if you convince yourself that the S is worth it, then you might as well spend another $900 for the Premium package and get that huge moon roof + side impact airbags (for added safety of course!).
-Frank P.
Have you looked at the Premium S with the monochrome paint? If you don't care for the two-tone look, the Premium S might be your cup of tea.
The auto on the Forester is well matched to it's engine. I've driven a couple and it feels quite peppy. My preference is for a 5-speed, however. The boxer engine in the Forester likes mid-range revs and a 5-speed will let you tap into the power band better. The current Forester benefits from several years of tweaking the 5-speed tranny so it should be nice and smooth.
Ken
A smiling, HAPPY new Forester owner! Kris in NJ
By the way Len, I also prefer the grey cladding of the L which is why I bought one, however, I would like to have the aluminum wheels of the S and the moonroof that comes with the premium package. In my opinion, the S is a little too pretty to get dirty and I tend to be a little hard on my vehicles
Thanks to everyone who commented on the wind buffeting, fluttering, or whatever you want to call it. It still happens if I roll down the rear window. The only thing that seems to help is rolling down the windows on both sides. My old wagon was fine with the windows down on one side.
Skip
Drew
ejp
My question is will I now be a Subaru covert? You all seem so happy with yours.
Also are there any possible problems areas I should look at before take delivery? i.e. I have read about poor front end alignments on new foresters.
Linda: the Forester's cost of ownership is very good, but I imagine the RAV4's is as well. Resale is good, and gas mileage about best in class. Drive both and pick the one you find more fun - the Forester! ;-)
Scott: congrats. Love that moonroof!
Take a thorough test drive before you take delivery. Make sure it tracks straight and the engine does not hesitate. Do a walk around, twice maybe, looking for any little dings or panel gaps.
IMO any faults will be glaringly obvious on a Soob.
-juice
Thanx
