Visitor Agreement.
Mazda's part descriptions are Link Weatherstrip No. 1, 2, and 3.
Any idea how much they cost, if I can order them without getting ripped by a dealer or how difficult they might be to install? Looks like they might just be fitted with screws.
I'd check Miata.net for an installation guide.
Does anyone know where in North Jersey a miata can be rented?. One test drive is not enough.
http://www.delval.org/motorsports.html
Miata Net has a rentals page --- http://www.miata.net/faq/rentals.html-----
but as of their last posting nothing very near to you (Maine is the closest place, of all places!). But you should e-mail them and see if there are updates, or just go to Hawaii and rent one and kill two birds with one Miata.
PS: Can anyone recommend a site online that describes pulling the head on a '93 Miata?
-sammy
Go to the site below for an explanation of how you can self-diagnose the problem.
http://www.miata.net/garage/faultcodes.html
They just screw in, and there is one wire to connect, it's easy. On my Miata, a '93 with the 1.6l engine, it's near the firewall on the driver side, IIRC. I'm not sure about your 1.8l engine.
-juice
area. Has anyone else had a similar problem?
Otherwise, about all you can do is get out a screwdriver, tape, little bits of foam, etc., and go under there and poke around. Sometimes some silicon spray in areas where two plastic pieces meet each other will also work.
I got a nice torque wrench for about $40 at Sears. Get one with a long shaft for more leverage. Mine has the dial on the end of the shaft to determine the torque setting, then it sort of "snaps" when you reach it. It's very easy once you're used to it.
Then get a socket set. Most wheel lugs are in the 17mm-22mm range, I forget which ones I use for the Miata, but IIRC they are smallish. Note: make sure the drive size matches, they have 3/8" and 1/2" drives.
Tighten the alloys to about 70 lb-ft. If the wheels are steel, 75 lb-ft is fine.
-juice
-juice
-juice
My Odyssey minivan has only 25k RPM when I cruise around 80 MPH.
-sammy
2,500 rpm at 80 mph? Are you quite sure about that?
But just try keeping up in the corners! ;-)
-juice
Disclaimer: Do not try this at home. Professional driver on a closed course equipped with proper safety equipment. Obey all posted speed limits and buckle up for safety.
-juice
Jeannine Fallon
PR Director
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
Good luck - their buyers tend to be older. Even Corolla owner's median age is 32 IIRC.
-juice
Anyway, part of the FUN of little roadsters is that you are buzzing and blowing and slipping and sliding. That's the whole idea. If it doesn't really appeal, you need a Benz SL or something to be happy then.
Some people's complaints about little sports cars reminds me of when I sold a 26' sailboat once. The prospective buyer asked me "Can I take it out when it rains?"
Remember these tips:
* driver window down
* pasenger window up
* heat directed to your hands
* hat and gloves
Happy topless driving, even in 40 degrees!
-juice
At least with a Miata is hard to blow on it.
-juice
You guys think this sniper would go after someone with the top down? I'm driving around in MD/DC top down and just thought about that.
The heater is great. I got a nice fleece-lined and water-proof jacket. It's also wind proof. Some gloves, too. Time to get out the hat, though.
-juice
