Oldsmobile Alero Electrical/Lighting
:sick: Ok, I have a 2003 Alero with 106,000 miles on it, got in it this afternoon, it wouldn't start. About 30 minutes later, it started but the radio wouldn't come on. I had not left any lights on, I got a new battery about 1 1/2 months ago, the key fob does not work. After I let it run for awhile, the battery light came on, the lights come on and they are bright, (normal). I shut it off, it wouldn't start again. Got it started a little while later, still no radio and all the lights come on like they should on the dashboard when you start the car up, but the fuel gage, tach, speedomoeter, and temp. gauge does not work. This is very aggravating. Any ideas what it could be?
I tried to claim it back from GM, as they are re-imbursing for certain turn signal/hazard warning problems, but had no success, even after an official appeal.
Sorry it's not better news.
This morning when I got in the car, the back windows and the passenger front windw worked, but the driver's window still doesn't work. What is the deal? Can anybody give me insight on what to do?
I am driving a 2000 Oldsmobile Alero - 4 dr.
On an unrelated note my Alero (which has 48k miles) also has starting issues. Whenever I take a short drive - 10 miles or less, the next time I go to start it hesitate quite a bit before turning over. Sometimes I have to start over and just turn the key again until it starts...Has anyone experienced this as well? I have brought it up to the dealership MANY times and they can't duplicate it and claim to know nothing about the problem.
Of course my 5yr warranty expired TEN days ago. Figures.
Thanks for any input!
key assembly and install it but I kept having the same problem so I remove the switch and open the back plastic case where I found 5 sets of contacts so I clean the arching burns with a bernishing tool you can find that tool at your local electronic store then I adjusted the contacts so they would make better contact put it back together 2 months ago and have not had the problem again regardless
what the weather condition are or road conditions. Bye the way this relays control your blinkers,power windows, and Instrument cluster light and gauges.
I have a similar problem. The power windows and A/C worked intermittently then stopped all together. Did you clean the contacts on the ignition switch ?
Thanks for any help!
Thanks in Advance of Solution.
Tony
Informational blog:
http://wiki.rockauto.com/2000%20OLDSMOBILE%20ALERO%203.4L%20207cid%20V6%20FI%20(E)_Blower%20Motor%20Resistor_0_0
On-line pricing:
http://www.rockauto.com/catalog/raframecatalog.php?a=G-partdescribe
then select: OLDS, the year, the model, the engine, heat and air conditioning, then Blower Motor Resistor all from the drop down menu
