GMC Jimmy Fuel System
My jimmy would run for awhile then stop. Let it sit for awhile then it would start. Changed the fuel pump same thing, changed the relay same thing, changed the ecm same thing. was told to check the oil presure swith but don't know where it is. Dose anyone know (help)
gator14
gator14
gator 14
Did you check the ECM (may be 2) and ENG fuses also? CPI needs higher pressure like 60psi to start while TBI is like 12psi.
Gator 14
From other discussions, I could not find this issue addressed for specifically the 99 Jimmy. It is a 4wd.
Additional incidents that may be related:
The service engine soon light was on for about a week, then was off for about two weeks. It came on again two days before this situation.
The fuel gauge would read accurately until it got to about 1/4 tank, then it would jump to either full, or completely empty. I only ran out of gas one time due to this problem and that was about a year ago. Since that time, I have always kept fuel level high to avoid this and have used my trip odometer to keep me posted on fuel level.
Otherwise, possibly unrelated, the dash lights for the radio and steering wheel are half lit, but recently the lights for the radio are completely dark. The heated seat for the driver's side stopped working during the last two weeks.
I am having similar problem with my 98 4x4 Jimmy did you figure out what the problem was?
David
David
countryboy276@insightbb.com
A new stock fuel pump is not one of them.
After much experimentation and diagnosis I believe the fuel pressure regulator is at fault - somehow it is tellin the fuel pump that there is 60 pounds of fuel in the line so the fuel pump does not need to run!!!
A political simile, the CIA report on WMD in Iraq...
I believe the item responsible is inside the throttle body on top of the engine - or maybe Saddam has it so well hidden we can't really prove it exists?
Ha ha ha...
If the vehicle was mine, after installing a new pump and it repeating the same symptoms after four days of running, I would put in a new pickup line (fuel from the tank) eliminating the stock fuel pump, install an inline external fuel pump (on the inside of the frame) with a fuel filter before AND after the fuel pump - (due to the way the fuel filters are a part of the fuel line design on some vehicles removing the second fuel filter is both bothersome and really beside the point).
The pumps such as available on Ebay are about $129, hit up to 120 psi - and are more accessible than dropping the fuel tank every darn time... just my two copper plated zinc pennies worth. Good luck. I am sticking with my 73 Dodge van.
The pressure regulator is part of the injection assembly located under the upper intake manifold plastic cover and under that big electrical connector behind the throttle body.
then just replace the plastic pump casing/housing thingie WITH the fuel level sender still intact and in place.
If you look closely you will find that the pump housing is a two piece snap together assembly. Easily separated to access the pump unit.
Pardon my impatience, but I am only too aware of the design defect of this modern moronic piece of so called engineering that is designed to fail due to a 'too empty fuel tank'.
this kind of engineering is proof that cousins should never marry - their mothers.
Somehow I seriously doubt that I, and all the many many others with the same results, managed to 'wear out' a new fuel pump in four days. :lemon:
www.airtex.com
Many GM vehicles from 1988-2005 have electrical connectors on the fuel pump module that may become loose over time due to vibration, leading to faulty, high-resistance connections. The symptoms- burned or melted connectors and pins- lead to a voltage drop situation where low or no voltage can cause the module to stop pumping.
Solution: Airtex products latest fuel system solution provides a quick and reliable fix for burned or melted wiring harness connections on certain GM in-tank fuel pump applications. Airtex has replaced the faulty OEM design that eliminates the burned or melted connectors and pins problem.
one had voltage all the time i assume this is the gas gauge.
because it was low voltage.then you will have two that is the ground.
then the other one don,t have voltage on it with just the switch turned on.
but as soon as you turn the switch on over as to start it it has voltage is this the way it is suppose to work
I need Help! THANK YOU
After 1 month the fuel pump failed - no big deal, done this before with the in tank fuel pump on my 99 suburban. Replaced with a Airtex fuel pump from Oreilly Auto Parts and all was good.... For 5 days - broke down again.
Checked the fuel pressure at the fuel rail and fuel squirted everywhere, so I THOUGHT I had fuel pressure... and the truck would run with starting fluid - SOOOO I went down the route of replacing the Fuel Injector Assemby (Spider). This did not fix it. Luckily, I bought a used working one on ebay for $40.
Finally bought a fuel pressure gauge (hind-sight 20/20) and realized I had 12 psi.
Replaced the Fuel Pump with a new one from Oreilly no questions asked.
Getting very good at this at this point - Thought I was good to go - Bad pump I thought.
Week later, after pumping gas, the truck would not start again.
Fuel pump wiring harness? Don't think so since the Airtex came with a new one
Clogged Fuel filter? will check, but doubt it. Already replaced on the first swap.
Cough up the money for the AC Delco? Thinking this may be the fix.
Hitting the truck to free up a stuck pump? Will try this tonight to see if it starts.
Blowing out the fuel lines? Need to do this
Here's my conclusions, based on everything I've gone through.
1. Check fuel pressure - Buy the $50 high pressure gauge kit - worth it! Just because you hear it whinning does not mean anything - You need at least 56 psi.
2. Be ultra careful with the plastic fuel connectors on the lines/pump
3. Be sure to keep your little fuel line plastic clippy things if you're returning your pump
I'll update tomorrow after I troubleshoot this second failed fuel pump.
The second Airtex fuel pump never completely quit and would keep the truck running just fine if I started it with some fuel dumped in, but never made more than 50psi which is not enough to start the 4.3. It needs at least 54psi to start.
My advice would be to pay the extra $30-40 bucks for the OEM Delphi or AC Delco fuel pump. Don't waste your time on other brands - You only want to do it once, right?
