Suburban Tahoe Vibration Problems
12357
  • stan99stan99 Posts: 7
    I would like to know what the solution was. I just purchased a 2011 LTZ three weeks ago. Drove off the lot with 22miles on it and returned 1 hour later to get the tires balanced. They then said I needed to get 400-500 miles on the tires so I did and brought back again. they changed tires to another brand and I drove for another 100 miles and returning the truck again today. They are purchasing a new set of tires in lieu of taking off of other trucks on the lot. I will update on what happens.
  • Taking it in the next two weeks to the speciality shop - never heard back from the owner of the dealership and after several messages left he just tossed it back to the service mgr. Great customer service!! Contacted service mgr again and he stated there is nothing more they can do and it would just take up room in his bays and referred me to another Chevy dealer (#3) or to the Speciality Shop. I will update when the info is available. Good luck - sounds all to familiar.
    Still have vibration....GM contacting me on Monday. I now have 1,200 miles. 2nd Dealer says they feel the vibration but does not know what the issue is....this was my 5th trip to fix the issue.
  • Check this out - our dealerships(s) would not do it but maybe you will have some luck. Know we have newer models but looks like it could id exactly where the vibration is coming from - was thread #101 I think.
    Models:2007-2008 Cadillac Escalade, Escalade ESV, Escalade EXT
    2007-2008 Chevrolet Avalanche, Silverado, Suburban, Tahoe
    2007-2008 GMC Sierra, Yukon, Yukon XL
    with any of the following Tire RPO's:
    - QSS (P275/55R20)
    - QXT (LT265/70R17)
    - QST (P285/45R22)
    - QIZ (LT245/75R16)
    - QAS / QAN (P265/70R17)
    - QJM / QJP (P265/70R17)
    Attention: Proceed with this bulletin ONLY if the customer has commented about this concern AND the EI number is listed in GMVIS. If the customer has not commented about this condition or the EI does not show in GMVIS, disregard the bulletin and proceed with diagnostics found in published Service Information. THIS IS NOT A RECALL -- refer to Service Bulletin 04-00-89-053A for more detail on the use of Engineering Information bulletins.
    This bulletin is being revised to add tire RPOs QST, QIZ, QAS, QAN, QJM and QJP. In addition, step 11 has been revised to request the 11-digit DOT number of the tire. Please discard Corporate Bulletin Number 07-03-10-013 (Section 03 -- Suspension).
    Condition
    Some customers may comment on a vehicle/tire vibration.
    Cause
    GM Engineering is attempting to determine the root cause of reported tire vibrations on vehicles equipped with P275/55R20, LT265/70R17, P285/45R22, LT245/75R16 or P265/70R17 tires. GM has a need to obtain information during diagnosis and BEFORE repair. This information will be used by engineering to "root cause" the customer's concern and develop/validate a field fix.
    If the customer's concern can not be duplicated -- disregard this bulletin. If the customer's concern can be duplicated, complete the following steps. Be sure to note the following information on the repair order:
    Verify that the VIN and mileage listed on the repair order is accurate. Describe the customer's concern (i.e. shake, buzz, roughness, tingling). Note when (mph, idle, accel, decel, etc) and where (steering column, seat, etc) the vibration is felt. Document the tire size and manufacturer of the tires currently on the vehicle. Inspect the following components to verify that they are in good working condition. Note any "faults" on the repair order:
    • tire/wheel assemblies
    • steering components
    • suspension components
    Install the J 38792-A (Electronic Vibration Analyzer -- EVA) sensor to the component identified by the customer as the most respondent to the vibration. If no component was identified, install the J 38792-A sensor to the steering column. Select a smooth, level road and slowly accelerate the vehicle up to highway speed. Observe the vehicle for disturbances that match the customer's description and note the following conditions:
    • Vehicle speed
    • Engine RPM
    • Transmission gear range and specific gear
    • Vibration frequency reading, detected by the J 38792-A
    If the sensor was originally placed on the steering column, and the vibration seems to excite a particular component of the vehicle more than the steering column, move the J 38792-A sensor to that component and repeat steps 6 and 7. Does the frequency data clearly fall within the tire/wheel parameters? (Refer to Symptoms -- Vibration Diagnosis and Correction, found in SI).
    • NO -- continue to diagnose and repair the vibration not related to the tire and wheel assembly. • YES -- proceed with Step 10.
    Using the HUNTER GSP9700 Roadforce/Balancer, measure the roadforce variation of each tire/wheel assembly. Also, with the original balance weights still installed, measure the inboard and outboard imbalance. Record the findings on the RO. Record on the repair order, the 11-digit DOT number found on the rim flange of the tire.
    PRIOR to making any repairs, contact the engineer listed below with information from your diagnosis. The engineer will provide direction to repair the customer's concern. For vehicles located in SE Michigan, the engineer may need to physically inspect the vehicle
  • Thanks Stan 99 and brycourt I bought a 2011 avalanche ltz loaded 4 days ago 31 miles. Next day on the interstate from 60-80 started to get pretty substantial vibration sterringwheel shaking took back for balance and alignment next day over 60 same thing called again spoke with svs manager asked if he has been having a similar problem? He said some times tire will have flat side from sitting on lot? They drove and found nothing out of the ordinary vibration I guess these clowns drive washing machines to work! My last 4 vehicles have bee gm envoy, gmc Yukon,Tahoe ltz all brand new never had vibration issues. So Friday I made my annual pilgrimage to ohio from sc to see the outllaws for thankgiving noticed the vibration starts @ 60 comes in intervals every 15-20 seconds last for 25-30 seconds goes away and comes back again? worst 10 hour ride of my life 600 miles now going to dealership in Columbus mon. Any suggestions?
  • Tigsport,
    I'm sorry that this vehicle concern interfered with your Thanksgiving trip. Would you be willing to email us more details so we can further check into your vehicle's information? Please include your name/username and the last 8 digits of your VIN.
    Best,
    Sarah
    GM Customer Service
  • This is an update to my post on March 01, 2008 concerning vibrations between 65 - 75 MPH with my Goodyear 17" tires. Dealer re-balanced tires twice, and each time the vibration got better (lower vibration) but still objectionable, indicating to me it was a tire problem. On the third time back to the dealer, he said he could not duplicate the problem and did nothing, a cop-out way to give up. Due to pressing family problems at the time, I did not pursue further with GM to change tires, so I just put up with the vibration which was manageable at 75 MPH. Now with 30,000 miles on the tires and one making noise, the vibration is more managable as the tires wear, and I drive above the speed were it starts to vibrate. When it reaches 40,000 miles, I will change to Michelin tires which have a better history for smooth ride at speed. I wish GM would offer an option for Michelin tires when buying the vehicle new from the dealer.
  • I have developed a rear end vibration between 70-85MPH after haveing new rear brakes and turning rear rotors. I returned to the Goodyear Tire Store (Very Reputable). To eliminate anything they may have done they first balanced all four tires. When this did not work they replaced the rear roters at their cost. Still vibration. They put on a brand new set of tires re balanced. Still not resolved. They owner of the store has a 2010 Youkon XL. He put his tires and wheels on my Suburban and still vibrates. They feel they have done everything that would point at tires,brakes and rotors. I have read about vibrations on Tahoe's and Suburbans. What is the next thing to check in the drive train?
  • solosolo Posts: 48
    Check the vibration in the heads of G.M. execs!
    Sorry for joking, but almost every vehicle they produce has a serious flaw.
    Our premier U.S. company has become obsolete, and only aggravates its customers. ( "nothing wrong with your car, they all do it")
  • Google Propeller shaft phasing, drive line phase. It's funny because the Chev factory manual states how important this is. It even has pictures showing all the drive lines and how they should be phased. So why then when I look under my truck (98 Silverado), is my drive line 45 degrees off? This is a two piece drive line and it does come apart at the spline but it only goes together one way. So my truck and many, many others rolled off the factory floor with out of phase drive lines. W...tf?
    So I just got my truck back today from a local drive line place and it feels great. No vibration. They removed my drive line, cut it, phased it, welded it back together, balanced it and reinstalled it. Guy says he does it a lot.
    Also on the drive home I noticed the tranny was not shifting back and forth. Could it be that the drive line issue was putting "junk" into the data that shifts the tranny? And the pedal response feels better now. I always felt the truck was a little sluggish but shrugged it off as symptomatic of a 3/4 ton 4x4.
    The elliptical (as opposed to perfectly round) rotation of an unbalanced, out of phase drive line robs power and response. I suspect my gas mileage may improve as well. Thanks for reading and I hope this helps some one.
  • They had to replace the rear end of my Tahoe but that did not fully fix the problem I say do the lemon law.
  • It's not the tires it the vehicle!!! GM needs to fix it or do the lemon law.
  • cat125cat125 Posts: 36
    edited January 2012
    Caron : can you help out - purcahsed another Tahoe 2008 - GM certified and I'm having similar issues with vibration at 72-73 mph. Not as severe as previous Tahoe but still there - let me know please -
    Sabits : Where did you find a drive line place - city -state ??? need help !!
  • chadfromftownchadfromftown Posts: 18
    edited January 2012
    I've noticed that this thread is mainly about a different kind of vibration but I'm going to throw my experience out there...
    My wife and I bought our '08 LTZ Tahoe new. It has 48,000 miles on it now and the past 8k it has started with this strange vibration. It only happens when driving about 65 to as fast as you wanna go, but at the same time when you're only lightly on the pedal or gently getting back on the pedal. So on my dashboard I went to the Instant Economy screen and figured out that its vibrating on 4 cylinders. I also have owned an '08 LTZ Avalanche, '07 LTZ Silverado and '09 LTZ Tahoe and from what I remember it also seems like our "current" Tahoe is trying to drive a little more on V4 than I remember any of my past vehicles doing. This tahoe stays at 4 even once you get on the gas and it vibrates and in my past vehicles I remember them instantly switching back to 8 as soon as your foot touches the pedal.
    After a decent trip, your foot will be numb-er than heck and passengers are like "why does the floor keep randomly vibrating?"
    HELP!!
    Why do GM's fall apart after 3yr/36k Bumper to Bumper Warranty expires? This isn't our Tahoe's only funny problem... Makes a weird buzzing/fart noise when put in reverse on cold start that comes from the dash. :confuse: The outside window trim on the back door is no longer in place, it goes up when you roll up the window. And not to mention whenever I go over a bump it sounds like something major is loose in the back (like the third row or spare tire) but I took the 3rd row out and spare tire is tight. Like something in a compartment getting shaken around, but I don't believe there to be anything back there?
  • :mad: Ok i am at 3K just got my 4th set of tires on my 2nd set of rims that were ordered directly from the factory. All four times the service department said they "road force balanced" the tires but when i continue to feel vibration they suggest new tires again. This appears to be an unproductive and frustrating cycle! I also noticed my driver door is labeled "GM of Mexico". Are the new avalanches made in Mexico now?
  • There has been a problem with our 2011 Yukon XL since we took delivery on 12/17/11. Wheels have been balanced, tires have been replaced, wheels & tires have been replaced, alignment has been done. Test drove it again today & still same problem. It has less than 1500 miles on it & alot of that has been re-testing it. Service tried to tell us we had to break it in, but I know better. My wife had a 2008 that she wrecked & it drove better than this one after 3yrs & 35,452 with the original Goodyear tires. My 08 GMC Seirra PU with 27,000 miles & orignal 20" Bridgstones still rides better than this new Yukon. If anyone knows of a manufacturer defect that is causing this please let us know. Thanks!!!
  • ukondoitukondoit Posts: 28
    I know that you all keep saying that it's not the tires, but I've had two of these trucks and they both came with crappy bridgestone tires. Once I put Mich Latitudes or the X-LT2, both SUVS drove like a totally different car. I've put a runout guage on Bridgestones and measured both radial and lateral runout. Then run the same test on the Michelens and you find that the Bridgestones have excessive runout. I was at numerous dealers over the last few weeks (Cadillac, GMC and Chev) and it seems that they use those Bridgestones on everything.
    Hope that you find the smoking gun.
  • My vibration experience started with a 2005 Tahoe. I had it back to the dealer within 200 miles and the saga began. I had new wheels, tires, driveshaft, rear axle, and finally transmission. Each step seemed to help the problem but I ended up with a vehicle with 120k miles on it simply due to work commitments. At this mileage, a dealer again swapped the entire axle, swapped wheels with a unit on the lot, replaced all the planetary gears due to pitting, and the problem was worse! They could replicate the vibration with the vehicle on the lift, so road force and tires were seemingly excluded. $2000 later they returned it and stated they could not fix it...
    I had the 10-15 sec vibration mentioned here, the constant vibration at 67-77 mph, the low speed shudder and the changes during cool weather, varying surfaces and load. All these issues are mentioned by different people here. I thought I was insane and other people did not believe me until I put them in the car and made them motion sick at 75mph.
    I decided to buy a new SUV and found very few provided the load volume I needed. Based on price, and without too much research, I bought a 2012 Tahoe, brand new. I did a maiden voyage from Tifton, GA to Savannah, GA and promptly turned around and delivered the car back to the stunned dealer. I cancelled the check, grabbed my old Tahoe keys and left. The 2012 vibrated EXACTLY like my old Tahoe and I cannot face going down that road again.
    The dealer called me back a few days later to try and persuade me to take the 'fixed' vehicle. I asked for the shop card and found they'd balanced both rear wheels and had to rotate the tires on the rims to get to 'GM Spec'. What a laugh. Anyone with a brain and Google can see that there is a massive problem with these vehicles. The dealer did not deny this and tried to sell me a Traverse as a replacement. Thanks, but no thanks.
    I've since looked at Durango but the V6 and V8 both have transmission problems that come up on plenty of websites. Expedition is just too old and dated, so I am probably going to pay more (up front) and buy a Sequoia. The state of American-made vehicles (and Nissan made here) is atrocious. The apathy in the system, and in the dealers is ludicrous. I tried buying a Tahoe in Savannah from the local dealer and they treated me like a dog because I would not buy their top-of-range units standing in the lot. They all drove poorly when test driven.
    Don't waste time with tires. The first time you have them rotated / balanced etc. you'll be back where you started. Driveshaft phasing seems to be the answer but GM cannot do more than replace the driveshaft which does not fix it. It needs to be cut and aligned, not an option on a brand new car.
    When my transmission failed at 75k miles, I shared the replacement cost with GM based on my vibration history. I think it helped but it may be the source of the problems too.
    I have a 2007 Trailblazer (wife's car) that rides like a dream but it only has 26k miles so may junk out as well. GM, go to __ll, you have no right to be in the market in 2013 with your compromised engineering, poor service and incompetence. The Chinese are coming and you have no defence if your leave your gloves down like you are doing. As for consumers, go elsewhere folks as this marque is never going to survive without another government bailout, sorry.
  • brycourtbrycourt Posts: 9
    Update on the 2010 Suburban 2010 LTZ vibration from a while back - never had a chance to bring it to the brake and alignment shop I was previously discussing. About two weeks ago the truck blew the entire front end of the drive-shaft and left my wife stranded during rush hour. Had it towed to the dealer (same one that said there was no issue before and had "checked" everything) and had it replaced. Truck drives great now and has no issues, although I had no choice to buy the extended warranty.
    Just cannot imagine why all three local dealerships in San Antonio could not id.
  • We purchased a brand new Suburban LT less than 3 months ago. We've had it in the shop to be repaired for a vibration issue (I equate it to almost like the white line rumble strips near stop signs and such). They replaced all 4 tires with Bridgestones. Still vibrates. And it vibrates at low speeds, high speeds, and even while idling at a stop light. We called the service manager back (who agreed he felt the vibration issue) and he put in a claim with GM to solve this issue. Two GM engineers were brought to the area to test drive the vehicle and see if the issues were valid or not. They said today that the vehicle issues were "normal" and that they'd call us tomorrow and have a report done.
    We call "b.s." on this issue. 1. I'm afraid to drive it with little kids in it. What is the vibration slowly loosening up?! and 2. I did NOT pay $50K+ for a vehicle that has vibration issues! Absurd!
    Has anyone else run across this with 2012s? Did you fight to get it fixed? Purchased back? We're contacting a lawyer and looking to fight to get this resolved. From what I've read so far on here, seems this has been an issue with older vehicles as well. Hope Chevy tanks and doesn't get another bail-out!
    :lemon:
  • Good morning schooners,
    We're sorry to hear about the situation with your Tahoe and understand your concern with the vibration you feel in your vehicle. As GM engineers determined that it was normal, there is likely little more that we at Customer Service could do aside from documenting your concern. If you wanted for us to do so and check to see if there was anything we could do, please email the following information to us at [email protected]: your name and Edmunds username, phone and address, the last 8 of your VIN and current mileage, and the name of your dealership.
    Thank you,
    Sarah
    GM Customer Service
    My Suburban was purchased back by GM. I am now driving a Tahoe and GM bought back the Suburban via trade and I got all my money back. I drove well over ten 2011 suburban’s including Yukon’s XL and Escalade ESV’s. All have a vibration except the Escalade. The Escalade is the only one with Magnetic ride control. GM acknowledged there was a vibration and said it was normal after two dealerships could not fix it. GM rep said I could look at the Escalade and would be about $7-10 grand more…came down to it and it was $15 grand more. Not an option at that cost. I have everything documented in emails from day one as I would recap every visit and or discussion as they were weekly. I found a Yukon Denali and worked out a deal that I would by $200 over cost which included dealer hold back and all incentives. The dealership that had the truck did not want to take the deal as they had to label truck as to why they have it to sell and did not think GM was giving them enough money as a trade. GM was paying the dealer the difference to what I paid for the truck so I broke even. I ended up back at the same dealer I original purchased the Suburban and purchased a Tahoe. GM could not fix the problem and the best that can be done is to put the Michelin tires with the road force balance matching the wheel to the tire. This will get you 90% but there still will be a slight vibration. My view after spending almost three month talking to a lot of people, reading a lot of articles and driving all these trucks…. The biggest issue is on concrete roads where the dampening system cannot keep up. It is like a resonance starts and just vibrates the whole truck. It seems like the Magnetic ride control is so much faster at adjusting that it dampens the resonance frequency. The part that bothers me is that one GM person said that the way GM gets around the lemon law hassle is to buy back the truck, enter a service order on the truck to show it was fixed then put it on the used car lot with a letter or something saying why it was purchased back. My understanding is they have to disclose why it was there but not labeled as lemon law.
  • @Sarah - GM Customer Service Rep:
    First, it's a Suburban, not a Tahoe. Second, with all due respect - I really don't feel comfortable just randomly emailing out my info to someone on a social forum, claiming they are a Customer Service person, that wants my name, address, etc. If GM wanted to "help" I would think the engineers who were flown to our location would provide us with options. Not a flat-out "It's normal. Bye." and nothing more.
    @stan99 - Awesome you got your Suburban bought back! But you had to purchase another GM vehicle to get that deal? I definitely don't feel comfortable with that. We've tried all along to get them to buy back. We had it in the shop once. The service manager agreed it wasn't normal. Replaced all the tires. When we said we still felt it, he rode in it again and felt it still. We'll get it in two more shops and then we'll pursue legal action. Some dealerships are flat-out refusing to even look at it. I don't want to drive it with my little kids in there either - what if this vibration is slowly shaking something loose? Talk about a safety issue!
  • steverstever Posts: 52,462
    All the automakers are using social media (i.e. forums) to reach out to owners and Sarah and Christine are legit.
    If you don't want to communicate by email, there's also a phone number you can call. Or you can use postal mail. And there's a Click to Chat link at the Chevy site (under Help).
    Chevy Contact Information
  • I emailed Sarah and haven't heard back. Still no communication with any GM engineers. I called GM today and was told that the case says "Customer requested no further contact" or something along that line. Ummm ... we never told them that. We've been waiting two days for someone to give us their report. This is getting ridiculous! I think BBB needs to be contacted as well - for the dealership. Grrrrr.
  • Good afternoon schooners,
    Thank you for sending more information our way - you sent it to [email protected] , correct? Also, I want to apologize for misreading some parts of your original post that I responded to. I should be more careful, and not that it's an excuse but I see a lot of posts over the course of a day. Again, I apologize for not giving your post my full attention.
    I will check with my coworker Christina to see if she has received your email. In the meantime, have you heard back?
    Sarah
    GM Customer Service
  • Sarah -
    No worries. Yep, sent it to the email you stated in the last post. Let me know if you didn't get it. Thanks!
  • I have bought Chevy vehicles for over 25 years. I had a 2003 Tahoe and 2005 Suburban and neither shook. Now I bought a 2011 Tahoe and it shakes at both low and high speeds. Have only had it for 9 months and have had it in the shop numerous times. We test drove 4 other vehicles on the lot and they all shake. When we first bought ours they said that there we flat spots in the tires and they would go away. Well after 500 miles and still shaking they replaced the tires. We have been dealing with 2 different dealerships and even have talked to regional GM reps and they aren't making any good offers to help fix the issue. We are looking to use the Lemon Law. Just emailed an attorney tonight. Have you gotten anywhere? (I know it's only been about a week since your post but wondering if you have had any luck).
  • Hey 68mustang (and others following this saga) ...
    Well, we've hit a brick wall. GM won't talk to us. Apparently once the engineers look at it and make a decision, they won't even discuss the issue anymore. So we took the Suburban to a second dealership in the area here and were told that: 1. they felt the vibration and recommended swapping out the tires (at a cost to us. reason covered in #3); 2. upon inspection to fix said vibration issue, they noticed that the original shop damaged the rims we have; 3. there was no record in our file that tires were swapped out at the first dealership so we're no longer covered under warranty for tire problems; and 4. oh, but now that you're here, we'll go for a ride with you so you can show us what exactly you're talking about -- "oh THAT? that vibration is normal, so there's nothing we can do to fix it." WTF?
    We met with the owner of the dealership we purchased from and he won't budge on this either. He said that "this is just how they drive." He's offering to swap out the vehicle - for the low trade-in price and paying for the new vehicle - some deal! Hahahahaha!!! Not. Basically, those of us that feel this vibration are a small percentage of the owners that have issue with it. Not enough of a percentage of owners for GM to even care about this problem. Damn us for wanting quality!
    We told the owner that we were going to consult with our lawyer before we make any decisions. I do NOT want another Suburban (or Chevy product) - especially if this is "normal". As of now, it looks like we'll either have to continue to pay for a product that drives us insane, or eat it and unload it. I'm livid.
    The best part was - the two dealerships we had the Suburban at so far, apparently hate each other and talk smack about each other to us. Awesome professionalism!
    Hope you have better luck. I'm waiting to hear back from our lawyer still. Let me know if you find out any other options.
