LS 400/LS 430 Electrical Questions & Problems
I have a 91 LS 400....running great, but I have a small issue I need answers to. When I apply the brakes the reverse light indicator on the dash lights up. Also, the car automatically downshifts as soon as the brakes are applied. I think it is electrical posibly to do with anti-lock brakes. Brake lights and reverse lights operate perfectly but, just wanted to see if anyone knows how to fix this problem
Thanks for any help given.
cn
What was the outcome to this issue. I am having the same problem. Please let me know as soon as possible.
Brich
Any ideas??
Look for a wire bundle on the drivers side trunk hinge that flexes and breaks. this cause your reverse indicator to light up when the brake is applied and also feels like the transmission is disconecting or downshifting. Fix that wire, and your car will not jerk anymore when touching the brake.
movinonout
I replaced the battery and the car starts fine now - but all the warning lights (as mentioned) stay on. What could this be - and what needs replacing?
JL
Dallas TX
I hooked up a charger and let the car charge for a while and the car started right up, but nothing electric worked. The steering didn't come out, the dashboard didn't light up, the windshield wipers didn't move. I checked a few of the fuses and changed the interior dome fuse and now the interior lights work, but the dashboard doesn't work and I checked to make sure that the dashboard fuse is ok and it is. What could be the problem. I obviously need electronics. Also, I had a garage check the batter and they said that it was ok, not great, but fine.
Also, once the car was started I tried to put it in gear and the gear shifter was locked. I pressed the Shift Override button or something, but nothing helped.
Thank you for your help.
Josh
Springfield, IL
I don't want to break anything. I would appreciate your help.
did you ever find out the cause of your problem?
I am experiencing the same thing on my 1992 L S400 and I have a brand new battery, the oil is full, the radiator is full and the engine is not overheating, etc
It seems to come on when I'm going slow (under 30mph) or stopped but when I speed up, it goes off.
It drives fine too.
http://www.carstereohelp.com/stereoremovalLexusLS400CDChgrR.htm
anyway I found the cause of my problem; the Alternator was going out; it's all fixed now.
Mine was located in the trunk, drivers side, just left of the gas tank. Of course I had already found the site " carstereohelp" and pulled my CD changer out before I realized that mine wasn't under there. Still a good site and will go there for info. again.
Everything ran fine for about a month and then I started having a problem SIMILAR to yours and to #10 on page 2.
Same thing: car will jerk like it's downshifting when I apply the brakes and the Reverse indicator on the dash will come on and the whole instrument panel will fade out.
Also if I turn the headlights on and I'm going faster than 30mph, the speedometer will drop to 30mph and it won't go any faster and the engine rev meter will go up to 4 or 5 and it sounds like you are driving in neutral.
The first time this happened I was driving home from a friend's house at 3 am , 16 miles away, and I pretty much limped home at 25 mph max.
One more thing is the O/D indicator will flash saying it's off and then it disappear.
I took it back for repair and they replaced a cable in the taillight that was shorting out and it caused a brake light to go out.
After that, it's working fine now and I hope it stays that way.
thanks vguthrie
I would wager that a small garden tractor battery would supply enough AMPS to start an LSes V8 but accordingly would not have a very long life.
:mad:
Except for lightening your wallet slightly more than necessary he did you no harm.
Manufacturers of late have become a bit more conscious of weight vs MPG issues so while the higher capacity battery will undoubtedly weight more than the OEM it will also likely last longer.
same I have on my 1992 LS 400?
same happen to mine, wouldn't open or change disc and I even try the reset on the remote control on the dash
took it to Lexus, they couldn't fix it
took it to a car stereo place, they told me don't bother
so it's still in the trunk, just doesn't work anymore
but I wouldn't even spent the money on a new car stereo for a 16 year old Lexus with 200,000 miles on it
my nephew is turning 16 next year and is going to start to drive - I am thinking how selling the car to him - his first car, a Lexus!!
my first car was a 1976 beat up old dodge van with no ac and am stereo
Anyone have experience with this...??
Radio aways operates even with the fusible link blown and CD works perfectly until the fusible link blows, days or weeks apart.
Over $100 at Lexus of Memphis and needed to order.
In stock (92 Camry) at Hutton Toyota for ~$70.
The OEM seat heaters are designed poorly in that the elements can too easily come in contact with the metal frame of the seat. That's why both front seat heaters had failed.
It turns out that there is a TSB that covers this flaw for the '95-'00 LS400...5 years to discover and correct an obvious design flaw. The TSB reads that it only applies under specific customer complaints and only while the car is still under the factory warranty.
So if you own a '95 to '00 LS400 and your seat heater(s) have failed now you know why, TOO LATE...
I have been in contact with Lexus, but unforntunately they were not much help. The dealer suggested that I don't fix the car, because it will cost thousands of dollars to repair. I went back to Lexus and they said take it back to the dealer and the dealer will basically rebuild the car, at my expense. That's a bit scary folks.
Does anyone have any suggestions or experience with the keyless entry, because I don't really want to give my dealer a blank check to fix it. ( I'm not sure they know how for starters )
Thank You
Mike
Thanks for the suggestion though
Mike
The keyless entry problem in my 2004 LS 430 with 56,000 miles on it, has been solved by Burdick Lexus in Syracuse,N.Y. These people investigated the problem and found two major components at fault, and they only had my car for a week. The first component was the Theft computer assy ($892) and the second was the Reciever door control unit in the trunk ($754), along with labor ($1,100) for a grand total of $2,746 to repair my LS430. The car is working like it should now and is enjoyable to drive again. When I first reported this problem to the Lexus Corporation, asking for some help in paying for some of this, because Dorschel Lexus in Rochester, N.Y. had no clue what was wrong it and didn't even want to try to fix it, and that's after they had my car for two months, Dorschel did offer some lame suggestions that I just live with it, or they can install an aftermarket remote to lock and unlock the doors on my $65,000 Lexus, for only $200. Lexus Corp thanked me for bringing this problem to their attention and informed me that they have sent this issue to the Lexus Headquarters in California, so that they can make a better product. How do you make a better product without the solution to the problem. Well now, thanks to me for paying for their research and development on this problem, they now have the answer. Lexus Corporation dropped the ball on this issue as far as I am concerned. It's too bad that I couldn't sell them the solution to their problem.
On a very bright note though, for people in Upstate New York. Burdick is an outstanding dealership and they are huge in automobiles not just Lexus. I personally would like to test drive one of their BMW's and they also have Hummer along with too many more manufacturers to mention.
I thought that anyone that has seen the keyless entry problem that I posted might be curious about the solution to the problem. Well here it is, so if your car has the same problem that mine did, it will cost you a smooth $2,800 to fix and don't count on Lexus Corporation for anything. I should state that my car is out of warranty as the Lexus Representative pointed out to me several times and they did not have to do anything toward helping with the cost of this rare component failure. I'm fine with that, I don't have to purchase another $65,000 Lexus either and neither does anyone else in this country.
Have a Great Day
Mike McNeil
If anyone has experienced this problem, please advise!!
Thank U
Most likely the lighting system "integration" relay assembly/module mounted in the dash panel approximately above the driver's left knee.
Check to see if the "flash to pass" headlight function works and if so the integration relay has failed.
