anyone have any suggestions?
I have a 1999 F350, Lariat, CC that I recently purchased with 104,000 miles. When I am driving the truck all the sudden the open door light comes up and no door is open. When I stop the truck the stop light stays on for a while and then turns off by itself. What could be causing this problem? Also, I have noticed an oil leak in the front area. When I touched underneath I could see a lot of oil build up in the area. Could this be a hose that is loose?
I'm trying to replace a bulb in the upper clear plastic lens, and access from the inside is impossible....
What is the upper clear lens light for?
Thanks...
So bought a new relay fuse (oem) from a local Ford dealer but that did not fix the problem. I've seen a few (handful) of similar threads via Google searches and but no solution other then replace the fuse.
Anyone else run into this and is there recommended troubleshooting tip to try next?
http://www.f150online.com/forums/electrical-systems/306610-1999-f150-starting-in- strument-cluster-problems.html
