Visitor Agreement.
Here in the Philly area townships are hyper about clear main routes, so I guess the Michelins weren't challenged much. Even a short cut through Valley Forge Park was mostly on black surface. What did register through the steering wheel and seat of my pants was how much more "secure" and stable driving felt on frozen pavement as compared to the regular Geos.
I was super impressed by the traction, control and stopping ability on the side roads which featured deep frozen slush and hard packed snow. 5 inches of snow on uncleared parking lots were absolutely no problem at all.
Over all, these tires are a real "confidence inducer." I think I will leave them on until first sign of spring.
One quick issue: The shop guy in a rush returned my Geos without marking their position.
There goes my careful rotation order. Do they now have to be rebalanced or something special when they are remounted?
Joseph
all at around 45 mph at over 5000 ft. altitude.
That said (without my wife looking over my shoulder to read what I wrote), I'm leaning towards either the Toyos (which I didn't list) or the BFGoodrich tires. Can ANYONE comment on those new BFGoodrich Traction series? I was told that they're basically poor man's Michelins.
burnsmr4
That bumped up my average a little, still at 25mpg, I'm not complaining. :-)
-juice
I recently replaced by original equipment Bridgestone Dueler H/T's after 27,500 miles. I selected the Michellin X Radial with an 80,000 mile warranty at Costco. The set was $420.00 with tax and disposal fees. Although it has been a limited run so far they are quieter with what seems like better traction in wet conditions (perhaps it's just the new tread making a difference). Speaking of tread they are wear rated at 680. Traction rated A. And temperature rated at B.
I hope this helps in your quest!
-Donn
-Frank P.
-juice
Joseph
If a shop is mounting them for you, sure, I'd balance them. If you're doing it yourself and you didn't have a problem with the tires before they came off, I would not worry about it.
You pattern will be off. Best I could suggest would be to get a tread depth guage. I'd put the less worn tires on the front axle, since they steer and do most of the braking. For the same reasons, they usually wear faster, and that will keep them evened out over time.
-juice
Joseph.
I've noticed quite a few people here either taking TireRack.com purchased tires to COSTCO and having them mounted OR just buying them straight from COSTCO.
How does COSTCO rank (scale of 1 - 10; 10 being the best) in terms of post installation support? If they mis-balance a tire or mis-align the wheels? Do you get any sort of limited warranty/documentation from them after the tire purchase and/or installation?
I ask simply because I've been very pleased with Kauffman Tire in north Georgia. They are TERRIFIC at honoring their service warranty. Plus, they also have a deal with my employer for a 10% discount on all services, including tires.
Please fill me in on COSTCO. Ironically, my father-in-law who made comments about my tires this weekend got his Michelins from them too. I guess I may just need to become a member.
Later,
burnsmr4
Thanks for the lighting info. I called my Subaru dealer 3 times just trying to get them to tell me whether those two buttons should be lit or not. They never called back with the answers. I wonder if Auto Zone or someone could tell me how those lights are replaced. I'm fed up with this dealership.
ohsubeguy
You get a road hazard warranty IF you buy the tires there. That catch? Prices are higher than wholesalers. So it's built-in, sort of.
They mounted my Miata's tires, but since I got them from a wholesaler they do not include a road hazard warranty on mine.
-juice
Good Luck!
-Donn
-- Mary
I seriously doubt that anyone at the local parts store will know how to replace those lights. Looks to me like you'd have to take the face of the dash off around the radio. Then maybe take the cup-holder out to get enough room. That's just a guess on my part though. Also the bulbs will more than likely have to be sourced at the dealer.
Chuck
I've noticed in the screenshots I've seen on the web it appears to attach to a hook on the internal rear wheel wells. My car does not have hooks there.
I'm wondering if anyone has these nets and how you have them attached. Are these wheel well hooks supposed to be dealer installed? (my dealer is clueless). Do they come with the nets? Any direction on how these work other than looking at tiny screenshots from subaru.com are welcome.
Stuart
John
I would assume your dealer would handle the install free-of-charge even if the vehicle isn't brand new. On my wife's Camry you just unscrew a flat plug and screw in the hook, a much simpler and consumer friendly design. Plus it free's up a dealer and their shop from doing what amounts to busy work.
I hope this helps.
-Donn
-Frank P.
-juice
Donn
I mumbled a few choice words remembered from my subsailor days...
-juice
http://techinfo.subaru.com/html/index.jsp
On the left select free publications and search.
BT
Thanks for the COSTCO heads up. I think I might get the Michelins from there. Now I have to decide which Michelins to buy -- XGT4s or MVX4s.
Those were the only tires that the COSTCO website said would fit my 2002 Subaru Forester S. And Michelin's website doesn't recommend a tire for this model and year for some reason. Lots of tire company websites fail to list a tire for this model year and model.
Thoughts and comments are welcome.
Regarding the cargo net -- on the 2002, there's top hooks for the upper part of the net, and then tie-down hooks for clips on the bottom part of the net. It was a nice setup. Sounds like they changed it for some reason.
burnsmr4
Sure enough, there are little detachable dog clips at the bottom corners.
The top corners are your standard elastic loops that slip over flanged posts, eggzactly like on our Concorde - which also uses the same arrangement at the bottom.
Subaru decided to do the tops the normal way and then confound GOG's (grumpy old geezers) on dark rainy nights by switching to a different method at the bottom.
Stupid car. I'm gonna sell it and get something else.
In ten years or so.
It's a shame that accessories like the cargo net and cargo tray have become "add-on" costs for the Forester. They were included as part of the standard features on my 2002. Although, that's all relative. I'm sure I paid for the "standard" features somewhere.
burnsmr4
Subaru bragged that prices didn't go up, but if you added these options, they did, by about $300-400.
Still, they added about 10-12 features, so we can't complain.
-juice
which didn't turn out bad for me. Got myself a set of soft mud flaps. Same shape, ideal for off road use and 5 times cheaper than OEM.
Lack of cargo tray prompted me to come out with my way to line whole trunk area (including back of the rear seats) with the plastic - same price and way more useful.
K
You must be joking. Surely by now I've proved beyond any doubt that I can find a way to complain about anything. Or even nothing.
As for the added/deleted content, I wouldn't mind the discontinued cassette player if Subaru had substituted either (1) a front-panel aux input jack for external add-on devices, or else (2) a CD-player with MP3 compatibility.
My '02 Forester L takes 205 70 R15 and it was either the Michellin's or the Bridgestone's which although cheaper lacked a mileage warranty and didn't seem to be in the same "class" as the Michellin.
I thought on my '02 Forester that the cargo net was part of the center arm rest/floor mats/cargo net pkg. Am I mistaken?
Speaking of design flaws does anybody know how I can remedy my cup holder problem. Since I have the padded arm rest above my center console that leaves my pull-out cup holders right in front of the controls for the vents and fan. Nice design idea guys!! Is there an after market set-up for moving my beverages out of the way and keeping the condensation from the bottom of the cup or can from dripping down the front of the controls and radio/cd player? If so, please let me know!
Thanks ,
Donn
Actually, my preset AC and heater settings kept my cool drinks cool in summer and coffee warm in winter.
In 2 1/2 years and 80k miles of use, I haven't had a spill yet (OK, maybe a small drip or 3). Of course, I probably just jinxed myself.
Len
John
He must be in a real hurry to get to the trail....
Craig
I am in mid-west, getting a lot of snow this year.
I drive a lot in interstates with strong winds.
Both cars are priced few $100s within each other.
Based on my very limited research:
Forester X
+ Hatchback (Legacy wagon too gaudy for me)
+ Better re-sale
+ Full size spare
- Susceptible to crosswinds?
Legacy Sedan L/SE
+ Lower to ground, better handling?
+ Sunroof
+ Leather steering, stick
+ Styling
- No full size tire
- Potenza on snow?
- Poor resale, next model few months away
Are geolanders on forester good for 1-2 seasons in snow?
Is legacy made in Indiana or Japan.
Help me decide.
We have Geolanders on our Forester XS, and they have about 26,000 miles on them. They are holding up well. We drove the Forester in ~10" of snow last year, and it did just fine. I have Potenzas on my Outback. They are also holding up well with about 33,000 miles on the clock. Had them in 10" of snow in Jan 02, and they did well too.
Legacy is made in Indiana, Forester in Japan.
I believe the Forester is more susceptible to crosswinds, given its profile and weight. We have taken both the Forester and the Outback down to the Outer banks in windy weather, and I definitely notice it more in the Forester, but I wouldn't say it's a whole lot worse than the Outback.
Craig
-Frank P.
Crosswind is not an issue with either vehicle.
-brianV
I like not having the drinks in the way when I'm resting my arm on the center armrest.
My wife managed to break the cupholder once, but she's like that sometimes... ("What, this is stuck ? Yank on it real hard and see if it moves." It's always the same thing: "But it's supposed to work." "Yes, hon, but yanking on things with your foot on the dash for extra effort is a bad idea...").
She's a real sweetheart, but a bit mechanically challenged.
-brianV
I may just stick with the Toyo Proxes TPTs from my local installer. My wife's Toyos have worn very well.
So -- are people buying the MXV4s or XGT4s for Michelins on Foresters?
burnsmr4
First off, I figured out how to get the infant seat to the center position. This left the front seats with more than enough room. As far as loading the car with everthing else, (baby jogger, port. crib, baby accessories) I found enough spare room for my gear (1 snowboard, 1 cooler full of beer and food!) Needless to say, we were fully loaded! (not from the beer) ;>p
Our 5 hour drive was comfortable enough and averaged about 23-25 mpg. Even with the extra weight, we were able to cruise at 80+ mph. The only weather elements we came against were heavy rain and wet snow on bare roads. The car handled great!
While climbing out of Vancouver, I came upon and passed (yes, passed!) a black XT with BC plates. You were female, about 55+ years, grey hair. I flashed a peace sign. Did you see me?
One thing to note is that the side mirrors really collected water in the rain. I found myself turning on the side heaters continuously. They seemed to do the job and thoroughly dried the mirrors after several tries.
For you XT owners and enviers, I did find myself wishing for more ponies. The XS is adequate, but still...
Oh well, next car.
Matt
http://www.bitman.com/SoobMods/
bit
That's exactly what XT 5-speeds turn. It's what I'd expect in a lower-powered vehicle, or one with a 7- or 8-thou redline, but not in one as powerful as this. V-8 type power calls for V-8 type gearing, IMO.
