something to do with it being in with the timing belt....
anyway the kia does have all the bells and whisles even a DVD player that doesn't work.... only 48,000 miles. i just hated being put in a spot where i had no choice and got my self in debt, they would not just buy my car and i had no way to move it and know one to buy it as is and BAM i am in a car i really can not afford..... oh well live and learn thanks for your help
After I read your reply I searched my service manual CD for our 03 Cruiser to see what all the fuss was about to replace a water pump on it.
My goodness. On our turbo model it involves removing the strut shock tower, depressurizing and removing various A/C lines, upper and lower timing belt covers, timing belt, cam sprockets and more just to get to the water pump. Then there are issues with getting the timing marks lined up afterwards, etc.
All I can say is that I hope it never has to be replaced. I usually like to tinker with my own basic repairs but I'm not sure I'd want tackle this one, even at $850 in labor savings.
I am hoping the 2.4 is A freewheeling engine which would mean A couple of things ,
first , their is A space between the piston and the valves eliminating the possibilty of damaging the valves and or pistons . second , the mechanic is trying to rip me off !
But I don't know if this is A freewheeling engine so I thought I would ask here !
i'm new this site but i need help trying fix the problems with my car ..i have a 2005 pt cruiser and the code that i get is 301 which is a cylinder 1 misfire ..how do i fix that problem?? please help
It could be caused by several things. Try replacing the less expensive things first and go from there. Start with new plugs, then new plug wires, then a new coil pack if either of the first two suggestions doesn't fix it.
Once I started using them, the Fog lights would come on by themselves and then not turn off. My solution was to pull the fuse for the fog Lights. On my '01 the only thing on that circuit is the for lights.
Paperweight
I currently own two Chryslers and a Dodge. My wife and I are quite happy with all three of them.
has to be a cheaper option.Can any parts of the computer be bypassed ?A voltage regulator would normally be a $100 Aus. expense.Surely someone else has had to solve this one.
If you don't need the space of an SUV the Dodge Caliber is rated 24 city / 29 hwy and the 2008 EPA estimates are fairly close than what those stickers used to be in previous years.
If you want something a bit larger while still getting decent fuel economy there's the Jeep Patriot or the Jeep Compass, both rated at 23 city / 28 hwy.
As far as the transmission problems, you generally won't see anyone take the time to come here and post that their transmission is working fine and that they haven't had any problems with their Cruiser. This is a help forum to share ideas and look for advice, so people who are experiencing problems with their vehicles are more likely to be found here. Sort of like walking into a hospital and wondering why there are so many sick people there.
:mad: :sick:
During my most recent oil change they told me that I had a blown head gasket. What I want to know is whether this is normal, has anyone else had this issue?
To me, with only 40k miles I would not expect a head gasket to go bad, too soon. And I certainly don't want to pay the 800 to 1000 that the dealership wants to change it!
My wife has an 03 Cruiser with nearly double those miles and she's never had any problems with the head gasket. I don't think a blown head gasket at 40k miles is normal in any car.
Auto parts stores such as AutoZone used to scan your CEL for free in order to get your business. It's been a few years since I've had this done by them but I believe they still offer the free service.
I have a 2005 manual PT Cruiser with 25K. Sometimes when I downshift, it won't accelerate. I can push the gas pedal all the way in and nothing. Any ideas why it would do this?
Scott
PT Cruiser No Fuse
If a fault still exists the CEL will keep reappearing until it is corrected.
Have you had it scanned for any fault codes? Places like AutoZone will do this for free.
I'm experiencing this exact same issue and have had no luck getting the dealer to find anything. Did you figure out what the issue was?
Bill
I was about to spend $500.00 at the local repair shop.
Thanks again!
Bill
Any suggestions?
First thing that happened was that the fog lights would stay on. The only way to turn them off was to keep the blinker on. Then that didn't work anymore, so I took it to the dealer where I bought it from (not chrysler) and they replaced the Mass electrical switch (whole new blinker), then it kept having a dead battery, took it back again, and found "nothing" wrong. Kept happening, and then it wouldn't start. They replaced the starter selonoid. Then it wouldn't even crack over. Kept having to turn the key about 200 times (not joking, literally) and then it would turn over. So they decided to replace the starter. Still not fixed.... I had them remove the remote starter thinking that it could be the culprit, nope. Now I have this awful grinding noise coming from the alternator area. Still, the car won't start, or the battery goes dead. I still have to keep turning the key numerous times to get it started. As of today, I couldn't get the key into the switch. Had a service guy come out and he had to pound the key in to get it started. Took it to the shop, and got attitude cause I want a Chrysler dealer to look at it. Why is all of this happening?? Since the last time they worked on my car,( to disconnect the "remote" starter), my sun roof, tempurature, and directional gauges, and my left front speaker don't work. Called the dealer and they said that disconnecting the starter didn't have anything to do with those switches.
Please, I need someone who knows what to do with this car!! I can't trade, cause I owe too much!! PLEASE HELP !! :sick:
